Lenovo S340-14IWL, S340-15IWL, S340-15IWL Touch, C340-15IWL, FLEX-15IWL Type:81N8
  • Bonzas
    • 472
    • Indonesia
    Working Bios, Extracted from lenovo site
  • Simon16
    • Sep 2017
    • 102
    • España
    Lenovo s340-15iwl 81n8 el5c3 el531 el431 la-h101p rev 1_0
    Please can someone help me with this bios.
    Copy attached.
    Ramon
    • peste
      • 13421
      • ROMANIA
      Re: Lenovo s340-15iwl 81n8 el5c3 el531 el431 la-h101p rev 1_0
      Copy attached.
      Ramon
      try the bios from post # 1.
      • Simon16
        • Sep 2017
        • 102
        • España
        Re: Lenovo S340-14IWL, S340-15IWL, S340-15IWL Touch, C340-15IWL, FLEX-15IWL Type:81N8
        Thanks!
        The laptop is working again.
        • slowgrind
          • Feb 2014
          • uk
          Do I need to copy 'MACHINE DATA' and 'WINDOWS KEY' from old damaged BIOS to a new virgin BIOS from lenovo in order for Ideapad C340 to boot again?
          What data from the dump has to be copied? Something like UUID etc?
          Thank you
          • peste
            • 13421
            • ROMANIA
            Originally posted by slowgrind
            do i need to copy 'machine data' and 'windows key' from old damaged bios to a new virgin bios from lenovo in order for ideapad c340 to boot again?
            What data from the dump has to be copied? Something like uuid etc?
            Thank you
            DMI
            620000 - 621FFF (0x0620000 - 0x0621FFF)
            A90000 - A9003F (0x0A90000 - 0x0A9003F)
            • ziko07
              • Jun 2021
              • 99
              • Somewhere
              Need bios lenovo ideapad s340-15IWL
              When power button pressed led goes on and after second goes off. I think bios problem. In attachment is ori readed
              Tnx
              • peste
                • 13421
                • ROMANIA
                Re: Need bios lenovo ideapad s340-15IWL
                Tnx
                read post #3 and #6...
                • gigasi
                  • 98
                  • Argentina
                  Hello, I have a Lenovo C340-15IWL notebook, I have already tried the bios in post1 but it remains the same, it turns on but there is no video. I do not have the original bios since it went to another place and they brought it to me without the bios chip installed. Is there anything else to do? thank you.
                  • peste
                    • 13421
                    • ROMANIA
                    maybe it has another problem.. check voltages on the coils, change the ram memory, check the display, LVDS cable, video chipset.. is there a picture on the external screen??
                    • gigasi
                      • 98
                      • Argentina
                      I have tried other ram and hdmi. and it doesn't do anything else. With the LVDS connected the screen tends to blink but without brightness. but as you say it obviously has to be another problem. thank you
                      • brock-s
                        • Dec 2010
                        • 48
                        Trying to remove a power-on password on a Lenovo Ideapad S340-15IWL, serial number MP1LXEN3. I tried the method in section 3.7.3 of BIOS guides, methods, resources and tools​. Specifically, I read the bios (actually, read it twice (removing and reinserting the chip from the programmer between 1st and 2nd read) and verified SHA-256 checksums to verify good read), cleared the chip, then programmed the bios that I had read back to the chip (I then re-read the chip and verified the sha-256 checksum to verify it programmed correctly).
                        After doing this, upon power-on, the power led comes on for about 4 seconds, then the laptop shuts off. No fan, no other lights, nothing on the screen whatsoever (the laptop booted normally to a power-on password prompt prior to this).
                        I've searched the forums and could not find a solution to this problem.
                        The eeprom is an XMC QH128AH1G, and was read as a W25Q128FV using a TL866A programmer.
                        The embedded controller is an ENE KB9022Q.
                        Motherboard is labelled as "EL5C3/EL531/EL431" LA-H101P Rev 1.0.
                        Not sure if I lost something important from a protected region of the eeprom chip when I erased it, or if the bios needs some work after doing a read->clear->program.
                        Wondering if anyone has any advice or seen this before?
                        • peste
                          peste commented
                          Editing a comment
                          merged post..
                      • peste
                        • 13421
                        • ROMANIA
                        you have everything you need at post #1 and #6...
                        • brock-s
                          • Dec 2010
                          • 48
                          "It's ALIVE!!!" [in my best Dr Frankenstein voice impression]. In all seriousness, I sincerely appreciate your help and pointing me to the right spot. It now works as it should. Thank you!!
                          • coasterghost
                            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                            by coasterghost
                            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                            System Hardware:
                            Processor: AMD Ryzen 7 PRO 5850U
                            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                            09-08-2025, 10:46 PM
                          • ElectricDoodler
                            Lenovo Thinkpad X230T Convertible - display assembly and touch digitizer
                            by ElectricDoodler
                            I need the schematics and boardview for the display assembly and touch digitizer for an X230T convertible tablet from Lenovo. Would anyone happen to have them?
                            I have one in perfectly working condition, and I've been primarily using it as a drawing tablet for a while. But the CPU is showing its age with it not being able to handle larger canvases, so I would like to remove the display assembly and use it as a USB drawing tablet, and I need to verify the pin-layouts of the touch digitizer to do so.
                            Model: X230T (type 3437-23G)
                            Display FRU 04W3919
                            Display P/N...
                            01-19-2025, 12:57 AM
                          • trepachka
                            Converting HP EliteBook 840 G7 non-touch to touch if possible
                            by trepachka
                            I am trying to convert a HP EliteBook 840 G7 notebook from a non-touch to a touchscreen. I purchased a complete touch LCD assembly with a screen/back cover/bezel/video cable and swapped it out with the original non-touch LCD assembly.
                            The screen works but the touch does not. I know the new LCD assembly is completely functional because we tried it on a similar touchscreen EliteBook 840 G7 and the touch works there.
                            I contacted the seller and he said screen conversion like this will not work due some difference in the motherboard for non-touch and touch capable EliteBook 840 G7.
                            04-27-2024, 11:15 PM
                            Lenovo IdeaPad U430 Touch Laptop Schematic
                            Lenovo IdeaPad U430 Touch Laptop Schematic...
                            10-12-2024, 11:47 AM
                          • purepower
                            Lenovo laptop IdeaPad C340 touch screen not working,
                            by purepower
                            Good day to all any one here ,,I need Lenovo laptop IdeaPad c340 touch screen driver , I installed driver ,,but it's doesn't work,I go to Lenovo support ,I installed right driver from there and still no luck ,, touch screen not working ,,
                            01-04-2023, 12:44 AM
