LA-E361p Rev 1.0 anyone have this
  • Bimad99
    HP ELITEDESK 705 G2 BASE MODEL SFF - NEED WORKING DUMP
    by Bimad99
    i need a working bios for an HP elitedesk 705 g2 base model sff machine, the problem is the machine turns on but there is no display.
    SERIAL NUMBER : CZC615CDTY
    BOARD MODEL NUMBER : 798073-001 REV 0C
    THE BACKUP DUMPS ARE ATTACHED DOWN BELOW.
    And this model has three SPI FLASH ICs, two 64mb (U19 and U68) and one 8mb (U11), i need clarification which one is the main bios chip ???!!!...
    05-19-2024, 04:51 AM
  • TyMercer
    Can I flash a working BIOS from one computer to another of the same make, model, etc?
    by TyMercer
    Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
    11-13-2025, 09:39 PM
  • FedorovV
    MSI Alpha 15 B5EEK-237XRU Need BIOS working DUMP from a laptop, not from the site.
    by FedorovV
    MSI Alpha 15 B5EEK-237XRU SN:K2209N0193161
    Came without initialization. Before that, it was not under repair. With BIOS from the official website, there is a start Ok, after a while the fans gain speed and the laptop turns off.
    The cooling system is cleaned, the contact spot is good.
    I need a working dump from laptop to check.
    This is an original, not working dump....
    03-10-2024, 07:26 PM
  • edward card
    BIOS Request: MSI Raider GE68 HX 14VGG-287US (Board: MS-15M2) - No POST
    by edward card
    I'm requesting a working BIOS dump for my MSI laptop, which I plan to provide to a repair technician.
    Make/Model: MSI Raider GE68 HX 14VGG-287US Board Model: MS-15M2 (Note: I have the serial number ready to be provided to the technician for DMI transfer)
    Problem Description: The laptop fails to POST. The only sign of life is the GPU fan spinning up after a couple of minutes. The screen remains black.
    Background / Fault Event: The system was working perfectly. The issue occurred immediately after entering the BIOS advanced menu and exiting with "Discard...
    10-06-2025, 05:41 AM
  • tofuSCHNITZEL
    Fujitsu Lifebook E547 vPro
    by tofuSCHNITZEL
    I have a Fujitsu Lifebook E547 vPro that does not boot anymore after Windows Update tried to install a new Bios version. Screen stays black no post - only the numblock light blinks.
    What I've tried:
    I have used my CH341A to read the bios chip (25Q128FVSQ) (Dump attached) - I think the dump is "good" because I could find the Serial number in the data and also the Winkeyfinder found a windows key.
    for the lack of any other Idea I took the bios from this post (https://www.badcaps.net/forum/troubl.../troubleshooti...
    10-15-2025, 04:26 PM
