hp probook 450 g7 da8mmb18d0 rev: d
  • comprica
    • Oct 2015
    • 24
    • palestine
    #81
    hello friend
    hp 450 g7 constantly blinking chraging port
    SN: 5CD0386VFD
    dax8mmb18d0 rev d
    • danito
      • Jun 2016
      • 1095
      #82
      Originally posted by comprica
      hello friend
      SN: 5CD0386VFD
      dax8mmb18d0 rev d
      try
      • comprica
        • Oct 2015
        • 24
        • palestine
        #83
        same problem
        i need both files
        • shiyab
          • Sep 2023
          • 1606
          • india
          #84
          hello friend
          SN: 5CD0386VFD
          dax8mmb18d0 rev d
          HI try new file
          • mcevahir
            • Oct 2016
            • 15
            • türkiye
            #85
            Hello, I have a hp probook 450 g7 notebook.
            Endpoint security gives problems at startup
            device serial number 5CD0371RVK Prod ID 8MH55EA#AB8
            can we edit the bios.​
            • mcevahir
              • Oct 2016
              • 15
              • türkiye
              #86
              The device shows an image, I get this error at startup
              hp end point security problem.
              • hoaca388
                Badcaps
                • Jan 2022
                • 12330
                #87
                End point security problem
                • mcevahir
                  • Oct 2016
                  • 15
                  • türkiye
                  #88
                  In the bios file you provided, there was no power to the device, only the caps lock light turned on once and did not make any movement.
                  • mcevahir
                    • Oct 2016
                    • 15
                    • türkiye
                    #89
                    • mcevahir
                      • Oct 2016
                      • 15
                      • türkiye
                      #90
                      I rewrote the old bios file and it gives the error shown in the picture.
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12330
                        #91
                        You have used the wrong bios. The bios posted is HP liteBook 840 G4 (P78), HP ProBook 450 G7 Notebook PC is S71.
                        • mcevahir
                          • Oct 2016
                          • 15
                          • türkiye
                          #92
                          I'm sorry my friend, I sent the wrong file. The main bios file is 25q1228.
                          • mcevahir
                            • Oct 2016
                            • 15
                            • türkiye
                            #93
                            After formatting, they updated the bios with the HP Assistant program. Later, this error appeared, we did not understand how it happened, I would be glad if you could solve it.
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12330
                              #94
                              Why ? Because you used the wrong file. The serial number 5CD0371RVK is for HP ProBook 450 G7 Notebook PC (S71) , but the two files you posted are for HP ProBook 440 G7 and have the serial number 5CD0388SBC.
                              • mcevahir
                                • Oct 2016
                                • 15
                                • türkiye
                                #95
                                Hello friend, this is the first file. Could you possibly edit this bios file? Thank you for your interest.I would be very happy if you could fix this error.
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12330
                                  #96
                                  Here
                                  • mcevahir
                                    • Oct 2016
                                    • 15
                                    • türkiye
                                    #97
                                    I flash these two files
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12330
                                      #98
                                      Yes.
                                      • mcevahir
                                        • Oct 2016
                                        • 15
                                        • türkiye
                                        #99
                                        Hello my friend, the device sent an image, the error seems to be gone, but the image arrives late. At startup, it says system is booting manifacturing program mode 28 in the upper left corner.
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 12330
                                          #100
                                          Every time the machine restarts number 28 ----> 0
                                          • studdy05
                                            Bricked HP Probook 450 G7 Bios questions
                                            by studdy05
                                            Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                            Ive got...
                                            07-08-2025, 09:24 PM
                                          • DiddiAb
                                            BIOS Backup / extract 16MB .bin - Lenovo ThinkBook 13s G3 ACN - 20YA0005GE
                                            by DiddiAb
                                            Recently I used the official Lenovo bios updater software on my ThinkBook 13s G3 ACN (20YA0005GE). The updating process failed and I got a black screen after powering the device. Of course I did not make an own backup before using the Lenovo bios updater.
                                            I bought a CH341A programmer and was able to make a connection to the chip while it is still soldered on board. But I did not realise that the chip was a 16MB size and selected the wrong size (8Mbit / 1 MByte) before reading the content of my chip. So the dump I did before erasing the chip is only 1MByte big. I fear that I lost...
                                            03-11-2023, 03:15 AM
                                          • the_raz
                                            Need (unlocked) bios for HP Probook 450 G3 Notebook
                                            by the_raz
                                            I'm requesting a bios .bin for 2 of my hp Probook 450 G3's. Both of which I had forgotten the bios passwords. I stupidly flashed both of them with firmware "made" by the RCUnlocker software and I guess I shouldn't have. The last thing I did was flash both of them with RCUnlocker-fw thinking it would 100% work and left my programmer etc behind and won't have access to them for another 2 days so I figured I'd create a thread to see if I'd be so lucky that someone might have a working file laying around 😝
                                            Laptop number 1:
                                            Model: HP ProBook 450 G3
                                            Motherboard part number:...
                                            12-17-2024, 03:37 PM
                                          • Chris_stand
                                            Clevo PD50PNN won't boot after BIOS Backup
                                            by Chris_stand
                                            i hope to find help her in the forum. It is a littlebit tricky. I searched many Days about disabling IntelME that was may major task. So i have a Clevo PD50PNN motherboard.
                                            At first i tried to Backup the BIOS with tools direcly from Windows(normaly i am a Linux user). But no full success because not every part of the bios was readable. So i bought a modified CH341a for a Backup.
                                            Backup worked but since the backup the Laptop is not booting anymore. I flashed the newest Version oft the BIOS with success, verfiy everything ok.
                                            But the...
                                            04-28-2023, 03:08 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
