Need bios for HP 15-ax004np
  • ZOrd_Z
    • Jul 2013
    • 80
    • Portugal
    Hi.
    Need bios for HP 15-ax004np.
    Thank's...
  • peste
    • Dec 2016
    • 13774
    • ROMANIA
    Re: Need bios for HP 15-ax004np
    Originally posted by ZOrd_Z
    Hi.
    Thank's...
    post the original bios
    • ZOrd_Z
      • Jul 2013
      • 80
      • Portugal
      Original file.
      • peste
        • Dec 2016
        • 13774
        • ROMANIA
        Original file.
        bios extracted from the HP site update
        This laptop model has five different bios, yours is 0820D
        DMI 6AC000-6AE0FF
        KEYWIN 278000-278030
        • ZOrd_Z
          • Jul 2013
          • 80
          • Portugal
          Thank's, i'm going to test...
          • fddizon
            • Sep 2011
            • 555
            • Philippines
            If above will not work try this
            • ZOrd_Z
              • Jul 2013
              • 80
              • Portugal
              It worked with "Peste" bios...
              Thank's...
              • jaycarinal
                • Nov 2019
                • philippines
                please rebuild no display hp tpn q173 G35A
                • peste
                  • Dec 2016
                  • 13774
                  • ROMANIA
                  you have everything you need at post#4..your bios is 0820D..the DMI and KEYWIN range...
                  • bondminer009
                    Need Bios for Latitude 7650 (No Original / dump bios file)
                    by bondminer009
                    Good Evening,
                    Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
                    Thank You
                    Salam,
                    Three
                    11-12-2024, 07:48 AM
                  • Citymin
                    by Citymin
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
                  • maanee11
                    Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                    by maanee11
                    Hello Everyone,
                    I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                    It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                    In the website, you can only see specs etc.
                    I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                    11-08-2025, 04:08 AM
                  • joshAU
                    BIOS file for N550JK (original dump attached)
                    by joshAU
                    Hi all.
                    I'm looking for a BIOS file for an Asus N550JK.
                    I have a Asus R552J, which I believe is identical to the Asus N550JK.
                    I downloaded the latest BIOS (210) for the R552.
                    It is named N550JKAS.210.
                    The BIOS file is however only 6mb in size.
                    I've read the chip with a CH341A programmer and verified the file.
                    That file is actually 8mb in size.
                    I'm wanting to remove the BIOS password from this unit.
                    It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
                    08-09-2022, 08:06 PM
                  • adelage
                    Merge ECS Z77-H2 bios cap file with original dump
                    by adelage
                    I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?
                    03-11-2025, 03:07 AM
