  • Badurson
    • May 2022
    • 13
    • Poland
    #1541
    Hello, i cant get this patcher to work, can someone help me with file for my x260? Thanks in advance
      • 22286
      See the post above yours,have you tried from the command line.Have you installed python. What is the error message,if any ,or what is the problem you`re having.
      There`s an X260 bios prepatched in another thread - https://www.badcaps.net/forum/showpo...42&postcount=4
      • Badurson
        • May 2022
        • 13
        • Poland
        #1543
        I have python, when i try to run autopatcher in cmd i get this...
          • 22286
          What is "Nie mo" ,isn`t your bios named something like "locked.bin"
          • Badurson
            • May 2022
            • 13
            • Poland
            #1545
            I get this „nie mo” massage every time i try to do any thing with autopatcher, I tried to put only autopatcher.cmd, I tried autopatcher.cmd + file name, tried changing name thinking many the name is causing an error. I'm using windows 10 with latest python so nothing unusual 🤷🏽*♂️
              • 22286
              Thats weird ,i can only suggest you try the prepatched one for now https://www.badcaps.net/forum/showthread.php?t=81573
              • Badurson
                • May 2022
                • 13
                • Poland
                #1547
                I didn’t want to use different one because I read somewhere that for this to work it need to be based on my original bios ��
                • teranova75
                  • May 2022
                  • ALGERIA
                  #1548
                  Originally posted by Vesko356
                  Command prompt (cmd.exe). Run as administrator.
                  OK, so what? Can you please tell me in detail the procedure to follow?
                  thank you
                  • kwnteen
                    • Jul 2015
                    • bbk
                    #1549
                    ThinkPad Edge E431 need help to unlock supervisor password,,thankyou
                    • SRajanrana
                      SRajanrana commented
                      Editing a comment
                      Need Hhelp To UnlockThinkPad Edge E431
                      need patch file if u have.
                      thxx..
                  • Markus1741
                    • Sep 2020
                    • 983
                    • N/A
                    #1550
                    Try this ...
                    • Ldee247
                      • May 2022
                      • 7
                      #1551
                      Hi guys, first-time poster newbie here I hope everyone is good.
                      I've been following the thread from the beginning referencing some important tutorial links on youtube and other great extensive shared ideas on here which are really helpful. Thanks to the creator of this forum and all contributors bringing really good stuff to share and learn.
                      HELP needed I've got a Lenovo T460s 20FA model and want to unlock the BIOS password. I recently bought the Dealikee SOIC8 SOP8 Test Clip EEPROM Flash BIOS USB +1.8V Adapter + Soic8 Adapter Programmer Module Kit Set for EEPROM 93CXX / 25CXX / 24CXX + CH341A 24 25 Series
                      I have already moded the CH341A downgrading voltage from 5v to 3v as instructed from the start of this forum.
                      Is it possible to use that croc clip shown below on a chip and save the original BIOS, Flash and replace the current BIOS with the generated patch file and send it back to the chip again without desoldering the chip from the motherboard?
                      Do I need to remove or unplug the CMOS battery during the process or it's just the 2 main batteries?
                      Thanks in advance
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12441
                        #1552
                        If you use a clip, you have to remove the main battery and CMOS battery from the main board, but sometimes the CH341A is not compatible with the clip. Then you have to remove the chip from the main board.
                        • Ldee247
                          • May 2022
                          • 7
                          #1553
                          Originally posted by hoaca388
                          If you use a clip, you have to remove the main battery and CMOS battery from the mainboard, but sometimes the CH341A is not compatible with the clip. Then you have to remove the chip from the mainboard.
                          Thanks for the prompt reply I really appreciate it. I will try and give it a shot hopefully I won't stumble.
                          Of the 3 programming software, NeoProgrammer, Colibri, and AsProgrammer which would you recommend using?
                          Also, do I need to plug in a 1.8v adapter into the CH321A together with the clip or 3.3v from CH321A is good enough for the process without needing the 1.8v adapter?
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12441
                            #1554
                            I don't use the CH341A so can't give you any advice on what software to use.
                            If your bios chip is 1.8 volts then an adapter must be used.
                            • Ldee247
                              • May 2022
                              • 7
                              #1555
                              Cheers thank you for your input let me dig a little bit more hopefully someone using it will respond.
                              • Ldee247
                                • May 2022
                                • 7
                                #1556
                                Hi, help needed Lenovo T460S 20FA,
                                1. I did a BIOS OG backup using CH321A black version moded to 3v and As programmer.
                                2. I uploaded my chip with a patched file supplied here: https://www.badcaps.net/forum/showthread.php?t=81573
                                3. Laptop won't boot up only using adapter charger, all 2 main batteries removed + CMOS battery during boot up.
                                4. Tried pressing the reset button underneath the laptop no joy still.
                                Am I missing something any help I would greatly appreciate?
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12441
                                  #1557
                                  Why don't you use the auto patcher on the first page of this thread and are you sure you have successfully dumped the bios file from your computer? where is your bios file?
                                  • Ldee247
                                    • May 2022
                                    • 7
                                    #1558
                                    Tried again this morning and it worked the laptop booted ok. I managed to patch it ok.
                                    After restoring the Original BIOS procedure at what point do I install all the 3 batteries?
                                    Do I need to boot 1 more time with the original BIOS restored while the batteries are still out or restore the BIOS, insert batteries then boot?
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12441
                                      #1559
                                      You can also pack everything up before you turn on the machine.
                                      • Ldee247
                                        • May 2022
                                        • 7
                                        #1560
                                        Thank you very much for your great support machine up and running I've managed to boot up. Now just need to set up and disable stuff inside BIOS and restore to defaults.
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • cr4zychriss
                                          by cr4zychriss
                                          • Rebrand: PC Specialist
                                          11-14-2025, 04:04 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • istvanszasz99
                                          Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                          by istvanszasz99
                                          Product ID: RZ09-0421
                                          Motherboard: CH580
                                          Bios File Size: 32,768 KB
                                          Dear Forum Readers!
                                          !!! MY RAZER BLADE...
                                          11-24-2025, 05:52 PM
