https://www.badcaps.net/donate -
Hi, I have a issue for a Thinkpad W540 after pach of my dump bios to remove password
the laptop make a 2 X 5 Bips sound, then nothing! After a reflash again with dump bios working but askme to put password. Please I need a good pached bios. Any help would be appreciated, thank you.Last edited by SMDFlea; 03-25-2023, 11:57 AM.Comment
hi, i have a issue for a thinkpad w540 after pach of my dump bios to remove password
the laptop make a 2 x 5 bips sound, then nothing! After a reflash again with dump bios working but askme to put password. Please i need a good pached bios. Any help would be appreciated, thank you.Attached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
Hi everyone, I am new around here.
2 things.
1. I just used this tool for a supervisor password on an L480 I bought used (seller did NOT disclose this issue!). It fixed the problem just fine, worked easily and without an issue.
2. Would this script/method work on a Thinkpad T14 Gen1?Comment
Why don't you try it if you own a Thinkpad t14 Gen 1.Hi everyone, I am new around here.
2 things.
2. Would this script/method work on a Thinkpad T14 Gen1?↵
Here is my bios file.
Could some one test it and patch it please ?
I have made a verify after copying the bios from my laptop Thinkpad X1 Yoga 3rd gen.
Thanks.Last edited by SMDFlea; 03-25-2023, 11:57 AM.Comment
Code:253794
Hi, this is my second post in the forum, and my situation is the following:
I have a Lenovo Laptop with this features...
Lenovo Thinkpad T460P (Late 2015 ) intel Gen 6th
Motherboard model : BT463-NM-A611-Rev -1.0
BIOS CHIP:
Winbond
25Q128FVSQ-1549
The BIOS has a supervisor password and it is locked. I tried to make a backup with the CH341A using a programmer clamp, apparently it was not done correctly and the .bin file is corrupt (The patch found errors). My question is the following, I hope you can clarify and help me... Can I download a clean/patch .BIN file without passwords for any T460p and flash the IC? Or is it that I necessarily need the original of my BIOS? I await your responses, thank you! Greetings!
NOTE: I have the complete information like UEFI BIOS version, System Unit and board serial number, UUID, MAC adress, OA3ID, etc.Comment
What makes you think that if you haven't read it successfully, you will program it correctly?Hi, this is my second post in the forum, and my situation is the following:
BIOS CHIP:
Winbond
25Q128FVSQ-1549
The first rule when you start playing with the bios chip is to make a good verified dump of the original bios.----------------------------------------------------------------------------------------------------------------------------------------------------------
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Yes, I understand that I had some fault for not taking precautions before deleting, but I made two backups of my original BIOS, both with an identical size of 16,384 KB and at the time of making them they had no errors, the errors were given to me during the patching: "xxx. bin is corrupted or does not contain a valid dump. There was an error... Aborting."
Honestly, I thought I could put any patched BIOS on it, I think I made a rookie mistake...Comment
You can, but how do you plan to complete step 8?Yes, I understand that I had some fault for not taking precautions before deleting, but I made two backups of my original BIOS, both with an identical size of 16,384 KB and at the time of making them they had no errors, the errors were given to me during the patching: "xxx. bin is corrupted or does not contain a valid dump. There was an error... Aborting."
Apparently you haven't read the procedure carefully.
Do I understand that you have already managed to delete the original BIOS without having a good dump from it? If so, you've really made a rookie mistake.
[ HOW TO USE THE PATCH ]
STEP 1: Flash and replace current BIOS with the generated patch file
STEP 2: Boot the machine
STEP 3: Press ENTER/F1/etc. to enter BIOS settings
STEP 4: Enter any character when asked for Supervisor Password
STEP 5: Press enter when it shows Hardware ID
STEP 6: Press space bar 2x when asked
STEP 7: Turn off machine
STEP 8: Restore original BIOS
STEP 9: Reset BIOS settings to factory default----------------------------------------------------------------------------------------------------------------------------------------------------------
https://www.badcaps.net/forum/showpo...postcount=1191Last edited by Vesko356; 01-18-2022, 01:56 PM.----------------------------------------------------------------------------------------------------------------------------------------------------------
So as you understood hehe I only have those two corrupted backups and the chip of my BIOS erased
I tried to flash with a .bin (downloaded from the forum) that was for the same type of board and chip, with AsProgrammer 1.4.1, but after booting and showing the logo, it shows me : "Boot error: 0183 Bad CRC Security Settings in EFI variable" and shuts down. Then I think I'll have to get a new board, I feel bad, it was my first attempt at this BIOS, but it helps me a lot of experience. Thanks!
Hi, I have a issue for a Thinkpad L390 after patching original bios to remove password
the laptop make a Bips sound, then nothing! blackscreen After a reflash with original bios it work but still password . Please I need a good patched bios. Any help would be appreciated, thank you.Last edited by SMDFlea; 03-25-2023, 11:57 AM.Comment
Is it possible that the Intel ME region on the original bios is defective.Hi, I have a issue for a Thinkpad L390 after patching original bios to remove password
Lenovo boot screen starts slowly.
I had the problem once too.
https://www.youtube.com/watch?v=aHSP...nnel=SureCanDoComment
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by piratiHello everyone,
Product ID: RZ09-0421
Motherboard: CH580
Bios File Size: 32,768 KB
Dear Forum Readers!
!!! MY RAZER BLADE...-
Yesterday, 05:52 PM -
- Loading...
