    hey, i tried flashing one of these bins here but it didnt work, ill attach my original bin here please help me remove the bios password.
      post S/N, full name and model, motherboard model, TYPE,etc.
        i got a x380 yoga Type: 20LJ-S0JK0A with S/N MP-1L34LQ | 19/07
        the motherboard is DTZS1 LA-F421P (2017-10-26)
        thank you so much for the help!
          I'm pleased to share that I've successfully recovered my Lenovo T480.
          As I mentioned earlier, I used an older version of the firmware, and everything worked as expected.
          One important detail was to patiently wait for the system to boot, with the patched firmware, it took over 15 minutes, but eventually it started up and I was able to unlock it.
          Many thanks to everyone for your support.
            Hi there. I'm stuck. I got a T480 (Type 20L6-S4XG00, I can't find the S/N, the one I see on the laptop is PF-1LEYQQ but it doesn't show on Lenovo's website).
            I'm using https://github.com/nofeletru/UsbAsp-flash/releases 2.1.2 and trying to patch a winbond 25Q128JVSQ 1849, using the option for the SPI winbond W25Q128JV but after flashing the patched bios the screen stays black and there is a chime. Searching online I found that there is a Lenovo app to interpret it and doing just that I get the code 0285 with the message "TCG-compliant functionality-related error (might be the TPM initialization failure)". After this I flashed the original bios back and my laptop worked again.
            I'm not sure what I'm doing wrong. Here is a list of things that I figure are related:
            - CMOS battery still connected
            - Storage still connected
            - Linux OS installed on storage
            From the original post (But honestly, I don't get it):
            > When booting the patched BIOS you might have to:
            > - Hold the anti-tamper switch down the whole time (use tape)
            > - Remove the hard disk or replace it with a locked one
            That's pretty much it.
              1.- Write this patched dump and follow the instructions.
              2.- Write back your original dump.
              3. - If you don't have original backup write the ME_Clean version.
              4.- Go to https://pcsupport.lenovo.com/us/en/p...4xg00/pf1leyqq and download the latest bios for your laptop.
                I'm looking for some assitance. I used the T495Main_PATCHED file to knock out the admin password.
                The notebook entered the menu asking if i really wanted to delete it, i pressed the spaces multiple times, and it restarted.
                After that only a blank screen showed everytime it got restarted, so I went to write the flash again now the original that was on the notebook.
                But now for some reason there was continously too much voltage on the writer, so I had removed the chip, and used the elevated 1.8v board on the CHA341-A-PRO instead of the clips.
                When I tried to write it again, I had multiple cannot read sector errors and probably killed the chip, so i purchased the only avalible replacement that I could get my hands on: MX25U12835FM2I-10G
                Today I wrote the old dump, to the new chip and soldered it to the board, when I first turned it on the screen had the backlight glowing, and it turned off after around 10 seconds.
                I tried going into the BIOS, and I succeded once, cause I heard the beeping sound that it is supposed to make. But I couldnt make it any further than this.
                I was measuring 1.8v on most lines and 300mv on a few lines, I tried removing the SSD, the extra RAM, externals monitors, but I couldnt get an image.
                Now after a few restarts I measured 1.8v to all lines from the ground, except to VCC, which is probably the issue, but at this point I have no idea on how to fix it.
                I also bought multiple chips in case I killed it again, so that won't be an issue, if needed.
                I see that you guys recommended to reinstall the BIOS, but I don't think I can do that without a screen.
                Any adivce or tips on how to fix it are appreciated!
                  Thanks. You don't know how grateful I am. Following your instructions made all the difference.
                  I just wanted to add, for the sake of documentation, that my laptop restarted two times before even the screen turned on, let alone access the BIOS.
                    P.S. Checking the BIOS the UEFI BIOS Version is N24ET79W (1.54) and the Embedded Controller Version is N24HT37W (1.22). Checking Lenovo's site for the latest BIOS it seams these are the ones, kinda, https://download.lenovo.com/pccbbs/m.../n24uj41w.html I updated my firmware using `fwupd` (https://github.com/fwupd/fwupd) which uses `LVFS` (Linux Vendor Firmware Service, https://fwupd.org/). The firmware I'm using is https://fwupd.org/lvfs/devices/com.l...XW.firmware
                      Hello guys...
                      I want to unlock my T480 with supervisor Password..
                      Just a general question for dumping.. I use the CH341A Programmer.. Did you use the clamp or desolder the whole chip?
                      Kind regards..
