    Originally posted by giokxan View Post
    You mean writing default/original bios of this model,right? Not the initial one I read & save at beginning before patch?
    Any X1 Carbon bios bin would be ok or 20HQ model level compatibility needed?
    initial bios restore
      i cant reach bios menu, because its getting stuck "Entering Setup..." after pressing F1
        post your initial bios
        someone will provide you with a cleaned or new one
        don't forget to indicate the serial number​
          https://filetransfer.io/data-package/XXWffcco#link
          Cant upload as attachment, it doesnt allow .bin extension
          I put in link initial and patched one I did as instructed
          Its 20HQ - DX120 NM-B141
            with winrar (.rar) or .zip
              attached now
                attached now
                try initial patched, see open setup
                  your attachments are same with what I uploaded, do you mean I should try with initial (original bin with svp)?
                  What is open setup
                    not same try
                    Cliquez sur l'image pour la voir en taille r?elleà  Nom : 		Nouveau Image bitmap.pngà Affichages :	3à Taille :		4,3 Koà ID : 			3464473
                    What is open setup
                    Bios menu
                      not same try
                      Bios menu
                      ok sorry ,saw it wrong. I will try now with that new patch
                      Does it matter if I keep SSD removed and attached during this trying?
                        try normal ,keep all
                          it worked, thanks man you are the king,
                          im in bios settings and spv disabled, i did "load setup defaults" as well. I closed computrace from enabled to as "permanently disabled" , do you know if extra steps needed further?
                          can I use laptop with this bios bin or I need to find clean default bin?
                          Thanks!
                            Thanks!
                            use this one, see if everything works ssd /lan etc ..
                            you lost the windows key, if necessary ask for it​
                              Hi, I have used the search function copiously, and tried to follow a few leads in regards to getting a beep code of 0285, TCG-compliant functionality-related error (might be the TPM initialization failure). I've tried disabling TPM through powershell, tried autopatch script several times, and each time I try and boot with the modified BIOS I get a 0285 beep code. Using the dumped bios works fine. Any tips or knowhow on how to fix this? In UEFITool I found that the patched bios has a "FfsParser::checkProtectedRanges: Phoenix protected range [970000hA0000h] hash mismatch, opened image may refuse to boot" message on it, which the dumped bios does not have. I don't have the technical knowhow to calculate and patch in a new hash
                                https://www.badcaps.net/forum/troubl...40#post3345540
                                  Many thanks
                                    So I tried following the guide, but hit an immediate roadblock. The hash range 970000h: DA0000h doesn't match with the hash ranges in the security tab in UEFITool:
                                    Code:
                                    FfsParser::checkProtectedRanges: Phoenix protected range [970000h: DA0000h] hash mismatch, opened image may refuse to boot
                                    Code:
                                    Phoenix hash file found at base 00F88018h
                                    Protected ranges:
                                    RelativeOffset: 000A0000h Size: D0000h
                                    Hash: 873294B3EBBB3329BBA6ABED75392C98891C38BAF1A934FD01B45132EE4162AD
                                    RelativeOffset: 00170000h Size: 430000h
                                    Hash: F346D4820EAC0C54FF7B7D342BBEDC1773C839936B53F366B50CE7CC92DEF45B
                                    RelativeOffset: 005A0000h Size: 40000h
                                    Hash: B8B7D897008E232E13A2982BA212ED9F7DE467424B2D4BCB266A032E0A64F13A
                                    RelativeOffset: 005E0000h Size: 10000h
                                    Hash: 34669869FF876E3118FE418D5359ECB71CC02B2132BD6F68CE12C406AA4AF6F0
                                    Unless I'm missing something from the tutorial?
                                      [QUOTE=Tokeri;n3465637]
                                      [QUOTE]
                                      Post your bios
                                      model and serial number to respect the rules
                                        [QUOTE=Maxpower3;n3465640][QUOTE=Tokeri;n3465637]
                                        Post your bios
                                        BIOS in attachment (unmodified)
                                        serial number PF-1QP25J
                                        Type 20L6
                                          [QUOTE=Tokeri;n3465647][QUOTE=Maxpower3;n3465640]
                                          Type 20L6
                                          try
