    hi,please someone help me.i have 2 laptops with bios pass supervisor.one is t450 and the other t 560.i tried to patch and nothing.only black screen and beeps...
      RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
      You MUST:
      • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
        Corrupt t450_bios_pw.bin file
        bios_T560_pw_PATCHED ok
          Thanks a lot, it worked like a charm! Quick question? Can I use this BIOS on another T560 with the same "problem"? If not, I will read the chip in a few days, and upload it here.
          Also, not related, can I do something about my T450 if the BIOS i read is corrupt? I erased the chip by mistake, trying to write another BIOS.
          Thanks again, and have a nice day.
            hi,
            anyone who may have a good bios backup for thinkpad x1 yoga 6th generation?
            currently the bios is empty,the old backup probably corrupted( when is written error : “file and chip in disagreement “
            sn PF3ZQLDN
            bios in the picture attached.
              SMDFlea commented
              Editing a comment
              If you have a CH341A programmer use NeoProgrammer software. Make a backup.
            https://www.badcaps.net/forum/troubl...37#post3266837
            Unfortunately, after 4 days the screen is still black and the device no longer responds.
            I think that the so-called password unlock chip I bought caused the problem. I soldered it on.
            After starting, the NB showed a hardware ID and requested a code. An empty code was sent to the TPM.
            I suspect this is the cause. Is there any way to save the device? I have tried both of the files you patched.
            Unfortunately without success. Does anyone have any idea how and whether I can bring the notebook back to life? I am grateful for any
            hints.
              hints.
              bios backup?
                Hi , the autopatcher doesnt seem to work with X1 carbon gen 5 (20UC), anyone got a solution?
                  Originally posted by danito View Post
                  bios backup?
                  You mean I should install the original BIOS? Does that make sense? I don't have many more attempts because of the solved PAD 5.
                    Hi all !!
                    I got a LENOVO Thinkpad T480s with a password - this message comes from a screen showing message System Security - Bottom cover tamper detected, after press ESC it ask for a password, please generate Bin for me Please so i can unlock.
                      i need a clean BIOS file for X280 20KF
                        BIOS guides, methods, resources and tools
                        https://www.badcaps.net/forum/troubl...rces-and-tools
                          Ok
                            Original bios backup gives error when flashing. Chip is empty/blank now
                              Hi all !!
                              I got a LENOVO Thinkpad T14S with a password - this message comes from a screen showing message System Security - Bottom cover tamper detected, after press ESC it ask for a password, please generate Bin for me Please so i can unlock. I tried a lot but unfortunately it didn't work. It creates a 16mb file with autopatch.py. But it cannot create the patch file, which is 32mb.
                                SMDFlea commented
                                Editing a comment
                                Please read the PM i sent you.
                              Originally posted by Maxpower3 View Post
                              your file t460 patched 32 mo
                              my ori t460 patched 16mo
                              very weird
                              I don't understand why your file is 32mb while mine of the same model (t460) is only 16mb
                              Hello. Autopatcher does not patch for 32mb.
                                Oh the Lenovo T480s model is tricky the resistors are placed way too close to
                                the EEPROM they can be damaged very quickly with the clip.
                                This interrupts the signal path so that the BIOS can no longer start.
                                Please be sure to look at the pictures, I've already had to repair it.
                                Good luck ...
                                Hey Markus,
                                Any chance you have the model of resistor that is used? I've broken one of mine while patching the T480S with a clip
                                Gonna want to resolder it to fix it as it's dead
                                -S
                                  You guys are legend, thank you so much for your continued efforts! Recovered a Lenovo X1 Carbon Gen 4, worked like a charm!
                                    Need a bit of help here, although I was able to remove the password and recover my Lenovo Carbon Gen 4 with the procedure in the first post, for some odd reason my laptop keyboard is no longer functional, only the Windows key works, all other keys are DOA?? Any ideas? If I plug an external keyboard everything works fine, so does the screen keyboard, but the laptop keyboard is dead. Did I forget something when recopying my original Bios ? Please help and many thanks!
                                      Here is a copy of my original bios (locked) in case someone wants to look at it.
