    Originally posted by kordex35 View Post
    ok
    thanks!!
      Originally posted by Markus1741 View Post
      Hello, you've caught quite a bit of fraud, the chip is worthless. After patching, you have to reinstall the original BIOS of the notebook. (which you don't have) I would read the original BIOS chip three times and compare the contents to see if everything matches. Patch the original BIOS with the autopatcher and then restore the original BIOS. Forget about the chewed chip.
      ALL RIGHT. I bought a CH341 and read out the BIOS. Can someone patch the file for me? Thank you.
      Sorry!
      Lenovo E490
      Type: 20N9-S20M0K
      Serial: PF1-1X5NTY
        Sorry!
        Lenovo E490
        Type: 20N9-S20M0K
        Serial: PF1-1X5NTY
        try
          Hello friends. I have two Lenovo Thinkpad X1 Gen 3 devices and their bios are encrypted.
          No matter what I did, I could not understand the program shared here. Can you patch my encrypted bios please?
          Thinkpad Yoga X1 Gen3
          20LES3481T
            Ok
              Ok
              Thank you so much it really worked. Will this file provide a solution on my second device or do we need to back it up and patch it as well?
                You need to create a new backup
                  I couldn't figure out how to create a patch, I try it but it gives an error and autopacher doesn't open. If there is a simple way, can you teach me or if I send my second backup, would you patch it?
                  20LES34800
                    Ok
                      Can someone help me? I programmed and checked the patched dump. Battery, HDD and BIOS battery disconnected.
                      When you plug in the power supply, the power button flashes 3 times. After switching on, the power LED lights up,
                      goes off and comes on again after 5 seconds. That's it. No LCD, nothing? What can I do?
                        Ok
                        It worked perfectly, thank you very much man.
                          I did the same thing on both my devices and it was resolved. Wait for a while on the black screen. Even if it is late, the screen will come back. If not, there may be a problem with the patch.
                            try with this bios
                              thank you
                                Thanks to Knucklegrumble, works like a charm with L470.
                                  I wrote the dump on the chip. The device behaves exactly as before. Since I am not here for the next 4 days I will keep the NB on all the time to see if the state has changed. Unfortunately, with the CH314, I can't program on the board. Some component on the PCB pulls away so much power that I just can't get the dump clean on the chip. That means I have to get the chip out and in every time I try. And because an accident rarely comes on its own, the pad of Pin 5 has dissolved itself from the PCB. I'm gonna have to figure something out on the next solder. I hope the notebook wakes up again.
                                    Hi. Please help. The patcher doesn't work. I have a sound signal. Screen black.
                                    Lenovo P1
                                    type: 20QT-00MPB
                                    S/N: R9-0WWCB7
                                    MB: 18809-2
                                    CPu- i7-9th gen
