  • ThinkpadMounty
    • Sep 2023
    • 14
    Oh the Lenovo T480s model is tricky the resistors are placed way too close to
    the EEPROM they can be damaged very quickly with the clip.
    This interrupts the signal path so that the BIOS can no longer start.
    Please be sure to look at the pictures, I've already had to repair it.
    Good luck ...
    looks like i did exactly what you said and knocked off resistors with the bleeping clip should have read this post and waited for my hot air station to arrive. Is it poosible to fix? will bridging the pads work? these things are so tiny i cant imagine fitting new ones
    • PTMQ
      • Aug 2023
      • 7
      #2822
      Hey, so far I have used this tool successfully on two other ThinkPads and I can't be more grateful.
      However, today I used the tool as per usual but came across an issue when going through the sequence on an x280.
      After booting into the patched bios I have the option to enter setup, and so I do. At this point I can no longer proceed as the ThinkPad is at a constant state of, "Entering Setup".
      After a quick search through this forum someone else seems to have had the same problem. For them it was a problem with their original bios being corrupt.
      I am not experienced enough in this subject and therefore do not have the knowledge of finding out whether my original bios is corrupt or not, let alone the knowledge of how to fix said corrupt broken bios.
      Can anyone confirm whether or not this issue is as a result of my original bios being corrupt? I have attached the original bios file.
      Many thanks, PT
      • Markus1741
        • Sep 2020
        • 994
        • N/A
        #2823
        Hello, you can try to bridge the resistance with a solder bridge.
        I can't guarantee that it will work.
        I've also read that this was done.
        It's all too good that these resistances are very small.
        Design 0201
        Here is a size comparison.
        Good luck.
        • Markus1741
          • Sep 2020
          • 994
          • N/A
          #2824
          Many thanks, PT
          Hello try this me clean file ...
          Good luck
          • krissdmtz
            Laptop burner
            • Aug 2021
            • 15
            • México
            #2825
            Tried it with a T540p, works as intended, just remember to take the EC dump (4mbit file) instead of main bios
            Forced to love badcaps.net
            • PTMQ
              • Aug 2023
              • 7
              #2826
              Good luck
              Excellent, thank you, I will let you know later how it goes.
              Many thanks, PT
              • Markus1741
                • Sep 2020
                • 994
                • N/A
                #2827
                Many thanks, PT
                Hello, yes, try it out.
                If it doesn't work, I think it's not your BIOS file.
                Because in my opinion it was OK.
                I would then suspect a hardware error.
                Good luck ....
                • PTMQ
                  • Aug 2023
                  • 7
                  #2828
                  Good luck ....
                  Hi Markus,
                  Just to make sure, I will patch the bios file generously attached by another user, flash that, then flash the un-patched version of that file after going through the steps as opposed to my own original bios?
                  *Edit: Oh and how would I convert the .bin file into an .ext so that I can use it with the autopatcher.
                  Apologies if these questions are a bit silly (I'm still learning)*
                  Many thanks, PT
                  • ramkaskad12
                    • May 2018
                    • 58
                    • ukraine
                    #2829
                    Hello, help, remove the password from lenovo p50 lenovo autopather does not create a file
                      • 22420
                      You must post the laptop serial number https://www.badcaps.net/forum/showthread.php?t=103570
                      • ramkaskad12
                        • May 2018
                        • 58
                        • ukraine
                        #2831
                        Originally posted by smdflea
                        you must post the laptop serial number https://www.badcaps.net/forum/showthread.php?t=103570
                        s/n pc-0g0388
                        • Markus1741
                          • Sep 2020
                          • 994
                          • N/A
                          #2832
                          Try ...
                          • ramkaskad12
                            • May 2018
                            • 58
                            • ukraine
                            #2833
                            Try ...
                            thanks it works
                            • PTMQ
                              • Aug 2023
                              • 7
                              #2834
                              Good luck ....
                              Hi Marcus,
                              So what I did was rename the file you sent so that it was an ext. I then used the autopatcher to generate a patched file. I flashed that but I still have the same issue.
                              Is what I did correct or did you have different intentions for the bin you sent?
                              Many thanks, PT
                              • PTMQ
                                • Aug 2023
                                • 7
                                #2835
                                Hey, me again,
                                forget everything I said, I don't know what I did but I ended up with a stable unlocked bios.
                                I didn't go through the process of pressing space when asked to on the patched bios etc as I didn't have the option to but I eventually ended up with an unlocked bios.
                                Apologies for the silly questions and constant pestering.
                                Many thanks, PT
                                • singh4lfie
                                  • Sep 2021
                                  • 11
                                  • uk
                                  #2836
                                  hi, new to this programming of bios, i have attached my dump, made 4 copies. can some one confirm nothing is corrupt before i patch?
                                  its a winbond 25q80dvs1g1844
                                  thanks
                                  its a lenovo x8380 yoga sorry for typo
                                  Last edited by singh4lfie; 09-27-2023, 06:44 AM. Reason: not mentioning model number in original post
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12520
                                    #2837
                                    thanks
                                    its a lenovo x8250
                                    Wrong chip.
                                    • singh4lfie
                                      • Sep 2021
                                      • 11
                                      • uk
                                      #2838
                                      sorry i had the wrong model number typed. which chip do i have to look for?
                                      this is of the ut2.
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12520
                                        #2839
                                        this is of the ut2.
                                        You choose the chips W25Q64..., W25Q128..., W25Q256...(for winbond chips)
                                          VIP Moderator
                                          • Aug 2018
                                          • 4386
                                          • Bulgaria 🇧🇬
                                          #2840
                                          this is of the ut2.
                                          Read the rules before posting:
                                          You MUST:
                                          Become a Badcaps supporter
                                          Thanks to all supporters.
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • istvanszasz99
                                            Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                            by istvanszasz99
                                            Product ID: RZ09-0421
                                            Motherboard: CH580
                                            Bios File Size: 32,768 KB
                                            Dear Forum Readers!
                                            !!! MY RAZER BLADE...
                                            11-24-2025, 05:52 PM
