  • webdan
    • Jun 2023
    • 14
    #2801
    Works.
    When I write works, that mean that works. It is true, when you use that soft must to be very concentrated.
    • jabovav959
      • Sep 2023
      • usa
      #2802
      Hi, new to the forum here. I have a T470s with unknown supervisor password. I'm not all that tech savvy. Can someone please explain to me how to do this like I'm a 5 year old? Do I need to back up my original bios first? How do I do that? I'm running Ubuntu 20.04.2 LTS. Thanks in advance for your help.
      • hoaca388
        Badcaps
        • Jan 2022
        • 11373
        • Viet Nam
        #2803
        You must backup your bios and make sure the backup is successful.
        Drag and drop your backup file into the Autopatch file.
        • Markus1741
          • Sep 2020
          • 842
          • N/A
          #2804
          Two things are very important.
          1. After downloading the script, it is important in Linux that autopatch.py can be executed.
          chmod +x autopatch.py
          2. Also very important is a good backup from the original BIOS as haoca388 says.
          You should be particularly careful that no resistor or capacitor is damaged during reading.
          See image 4 as an example
          This happens more and more often with newer models due to their compact design.
          It is better to de solder the chip and not use a clip.
          • robagp
            • Jul 2023
            • 19
            #2805
            After a month I was success.
            Thank you so much
            • Markus1741
              • Sep 2020
              • 842
              • N/A
              #2806
              Originally posted by wuyaping
              Can you share it with me? thank you
              Hello i found this in the Internet ...
              Lenovo Golden Key - U1 Tool V1.18
              https://github.com/HackerajOfficial/Lenovo-U1-Tool
              • murkywalrus
                • Sep 2023
                • New Zealand
                #2807
                had this work beautifully on a x380 yoga (20LJS1AJ00). thanks for this tool!
                • krizzy123
                  • Aug 2023
                  • Switzerland
                  #2808
                  Bought a second hand T470s but surprise it came with a password.
                  Came across the forum and did my research. Bought a CH241a and installed the respective softwares (AS Programmer v1.41 and latest)
                  Been reading this thread and trying many different things but coming across two issues:
                  1) how to verify that the BIOS backup is successful? See attached my dump
                  2) the .cmd file does not seem to run. have python and all installed but no luck
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11373
                    • Viet Nam
                    #2809
                    1.Backup at least 3 times then compare them with each other using HxD editor (the file you posted is corrupted).
                    2. Install Python 3.8.
                    • Szymon_Zy
                      • Sep 2023
                      • Poland
                      #2810
                      I would like to say "Thank You" to the author of these piece of software. I used ezp2019+ (modded) + clip cable on Yoga 370 with supervisor password in place. Around 1h and done.
                      Great work!
                      • krizzy123
                        • Aug 2023
                        • Switzerland
                        #2811
                        1. Extracted and compared the 4 versions.
                        Think is not corrupted now
                        2. have python 3.11 installed, managed to run it by dragging the .bin through the .py file
                        Thanks !
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11373
                          • Viet Nam
                          #2812
                          2. Have python 3.11 installed, managed to run it by dragging the .bin through the .py file
                          thanks !
                          ccc
                          • Kugaman2021
                            • Sep 2023
                            #2813
                            Hi, I tried this yesterday with the ch431a, followed everything to the letter and everything worked up until reprogramming the bios with the original bin file. It programmed and verified ok but my laptop won't turn on now. Not sure why this is. I am a noob at this stuff so I don't want to do anything else without some advice. I have a Lenovo Thinkpad t480 if anyone can help I would be eternally greatfull. Many thanks in advance.
                            • Markus1741
                              • Sep 2020
                              • 842
                              • N/A
                              #2814
                              Hello make a picture from your BIOS chip ....
                              • Kugaman2021
                                • Sep 2023
                                #2815
                                Image is available here as I don't know how to upload sorry. https://*******/pQ0QfgH
                                Last edited by Vesko356; 09-23-2023, 09:44 AM. Reason: External url removed. Image attached to the post.
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  #2816
                                  Become a Badcaps supporter
                                  Thanks to all supporters.
                                  • Kugaman2021
                                    • Sep 2023
                                    #2817
                                    Thank you for that, I had not even noticed I’m not sure how that happened unless I was a little to rough with the chip clamp, I will need to find out what they are and how to source them if I can’t find a donor board online. Thank you for your help Vesko356.
                                      VIP Moderator
                                      • Aug 2018
                                      • 4386
                                      • Bulgaria 🇧🇬
                                      #2818
                                      Thank you for that, I had not even noticed I'm not sure how that happened unless I was a little to rough with the chip clamp, I will need to find out what they are and how to source them if I can't find a donor board online. Thank you for your help Vesko356.
                                      You're welcome.
                                      No need to buy a donor board for that, according to the schematic the capacitor is 33P_0201_25V and the resistor is 33_0201_5%, you can source both easily.
                                      • Kugaman2021
                                        • Sep 2023
                                        #2819
                                        Originally posted by Vesko356
                                        You're welcome.
                                        I will look into them this evening, thank you again your a fountain of information. Again I really appreciate your help.
                                        • erikpeke
                                          • Sep 2023
                                          • Spain
                                          #2820
                                          Hello, My Lenovo Yoga Type 80X8 computer does not allow me to enter the BIOS.
                                          Does this auto patch help to solve it?
                                          Thanks in advance.
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • Bloodhoundje
                                            by Bloodhoundje
                                            03-16-2024, 03:12 PM
