Hp15-p228na (day12emb6c0 rev c)
  • m3g4tr0n
    • Aug 2011
    • 88
    looking for bios for
    HP15-P228NA
    DAY12EMB6C0 REV C
    Model: Y12E
    thanks
  • peste
    • Dec 2016
    • 12859
    • ROMANIA
    Re: Hp15-p228na (day12emb6c0 rev c)
    bios extracted from the HP site update, use the HxD program and find out the BID of your bios and use the respective bios sent ... if you fail, post the original bios.
    • basic
      • Oct 2017
      • 229
      • 86357289244
      here you have 5 dumps , so try
      • m3g4tr0n
        • Aug 2011
        • 88
        i'll try and find out the BID after work. but i have attached the bios.
        I think i attached the wrong bios
        • m3g4tr0n
          • Aug 2011
          • 88
          thanks, gonna try them after work.
            • 20977
            Wrong chip, its only 128KB ,its the realtek USB 3 firmware
            • m3g4tr0n
              • Aug 2011
              • 88
              correct bios attached
              • peste
                • Dec 2016
                • 12859
                • ROMANIA
                try...DMI
                6FF000-6FF0F0
                WINKEY
                430000-43002F
                • m3g4tr0n
                  • Aug 2011
                  • 88
                  try...DMI
                  6FF000-6FF0F0
                  WINKEY
                  430000-43002F
                  flashed the bios, then screen came on showing something about dmi pool, then showed something about maintainance or config mode (bottom of screen there was a message about press a key to enter startup) and then it loaded to no boot device / PXE screen.
                  i only had the screen connected. no drives or keyboard. it turned of and samething as before is happening black screen.
                  i've tried reflashing the bios again and nothing.
                    • 20977
                    Flash the 0227A bios from post #2 and attach the hard drive before boot,see what happens .
                    • m3g4tr0n
                      • Aug 2011
                      • 88
                      flashed the 0227A and still nothing on screen. also tried the old bios and again 0227A.
                      • m3g4tr0n
                        • Aug 2011
                        • 88
                        can it be the ITE EC chip?
                        • Vesko356
                          by Vesko356
                          08-11-2023, 03:27 AM
                        • Wahaz
                          by Wahaz
                          10-30-2023, 08:42 PM
                        • traxformania
                          TONGFANG "GM7TG7P" Bios Password Problem?
                          by traxformania
                          I tried :
                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                          11-15-2023, 07:32 AM
                        • razor_amd
                          by razor_amd
                          12-15-2020, 07:07 PM
                        • intelg
                          HP Elitedesk 800 G6 lost BIOS admin password
                          by intelg
                          Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                          Here is the hardware identification specs:
                          HP EliteDesk 800 G6 Desktop Mini PC
                          Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                          BIOS ver S21 Ver. 02.05.01 01/05/2021
                          Born on date: 07/26/2021
                          SN MXL11841GN
                          SKU 3X8V9UCHABA
                          UUID 8116E79EF6FFE94DB0B98A3188270C5C
                          SYSTEM BOARD ID 8710
                          SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                          11-03-2023, 02:05 AM
