6-71-w65e0-d03 bios
  • bondminer009
    Need Bios for Latitude 7650 (No Original / dump bios file)
    by bondminer009
    Good Evening,
    Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
    Thank You
    Salam,
    Three
    11-12-2024, 07:48 AM
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
  • joshAU
    BIOS file for N550JK (original dump attached)
    by joshAU
    Hi all.
    I'm looking for a BIOS file for an Asus N550JK.
    I have a Asus R552J, which I believe is identical to the Asus N550JK.
    I downloaded the latest BIOS (210) for the R552.
    It is named N550JKAS.210.
    The BIOS file is however only 6mb in size.
    I've read the chip with a CH341A programmer and verified the file.
    That file is actually 8mb in size.
    I'm wanting to remove the BIOS password from this unit.
    It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
    08-09-2022, 08:06 PM
  • adelage
    Merge ECS Z77-H2 bios cap file with original dump
    by adelage
    I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?
    03-11-2025, 03:07 AM
  • m1ch43lzm
    Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
    by m1ch43lzm
    Hi everyone
    I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
    Programmer models: XGecu TL866II Plus / T48 / T56 / T76
    Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
    There's also an extra OTP Secu.R...
    09-06-2025, 05:47 PM
