lenovo IdeaPad S145 bios needed
 Good day!
 Can someone help me.
 No Display problem.
 Lenovo S145-14API
 sn: PF13FBQD
 Thank you.
 Attached FilesComment
 S145-14API Laptop (ideapad) - Type 81UV
 https://www.badcaps.net/donateComment
 Hello forum. The power button for Lenovo S145-15ıwl is blinking white. I think it is a bios problem. I am uploading the bios on it here. Can you please edit it? Good work.Also, do I need to install the software for ite8536 here? Or is just editing the main bios sufficient?
 MODEL:LENOVO İDEAPAD S145-15IWL / fv440/fs441/fs540 nm-c121 rev:1.0
 SN:PF13EJC7 MTM:81MV0010TXAttached FilesComment
 you have everything you need at post#45..Hello forum. The power button for Lenovo S145-15ıwl is blinking white. I think it is a bios problem. I am uploading the bios on it here. Can you please edit it? Good work.Also, do I need to install the software for ite8536 here? Or is just editing the main bios sufficient?
 SN:PF13EJC7 MTM:81MV0010TXDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
 Every donation made will go towards server fees and maintenance costs.Comment
 Hi guys!
 I have a Lenovo S145 under repair with the problem of the LED flashing at startup with a black screen,
 Is it possible to know if the bios that I extracted from the eeprom is damaged or is it working?
 the technical data are as follows.
 Ideapads: S145-15API
 Model: 81UT
 S/N: PF14XV6Y
 MTM: 81UT0034IX
 MO: PF9XB9911013
 Attached is the original extracted bios.Attached FilesComment-
 Thread merged.
 Please use the forum search to find related threads where you can post your request. You're NOT allowed to start a new thread if there's an existing one!!!
 You have everything you need at post #29Hi guys!
 Model: 81UT
 S/N: PF14XV6Y
 MTM: 81UT0034IX
 MO: PF9XB9911013
 Attached is the original extracted bios.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
 Thank you for your answer!
 I flashed the bios released in post 29 but the problem changed, at the first startup the LED remained lit with the black screen then after 5-6 seconds it went off, at the next startup it was the same, 5-6 seconds then it went off, at on the third restart the LED remains lit but the screen is black, the fan starts turning normally again as soon as the CPU warms up.
 fs440fs541 nm-c111 rev 1.0
 No display, no led light. i want to try dump bios
 p/n : 5B20S42282
 s/n : pf259he8
 model : lenovo ideapad s145 15igmAttached FilesComment
 UPDATES: I fixed the problem, discovered some low quality silver conductive thermal grease under the CPU cooler causing shorts between the filtering SMD capacitors, did a deep clean and flashed the bios previously recommended by PESTE post #29 and that's it worked fine worked again, later formatted with windows and returned. Thank you very much for the availability of the forum technicians!Comment
 please use this orig bios bin not the ived sent already
 please helpAttached FilesComment-
 RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
 You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
 anyone fix this bios
 Lenovo s145
 FV440/FS441/FS540 NM-C121 REV:1.0
 Power light and fan spin few seconds and restarting
 battery charging is fine
 original bios attached
 please anyone fix
 Thanks AdvanceAttached FilesComment-
 Post the full laptop model number,and the serial number -> https://www.badcaps.net/forum/troubl...before-posting
 Hello together,
 I have a problem with Lenovo IdeaPad S145-15IWL, Model: 81MV
 After trying to update the BIOS, the notebook is dead. I got 1Hz blinked power LED. Read a lot of topics on the forum and probe to repair the BIOS image myself. I cannot find the DMI sector in my old image, and by getting the new BIOS image from .exe file I have failed.
 Could someone help me to repair the old BIOS image?
 Model name: 81MW
 S/N: PF2214Q9
 MTM: 81MW019
 Motherboard: FV440/FS441/FS540 NM-C121 Rev 1.0
 Original BIOS attached.
 Thanks in advance.Attached FilesComment
 you have everything you need at post #46Hello together,
 Model name: 81MW
 S/N: PF2214Q9
 MTM: 81MW019
 Thanks in advance.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
 Hi guys!
 I NEED BIOS
 lenovo ideapad s145-15IWL D NM-C121 REV 1.0 I5 8TH GENComment
 Hi guys!
 I NEED BIOS
 lenovo ideapad s145-15IWL D NM-C121 REV 1.0 I5 8TH GENAttached FilesComment-
 Thread merged... .You MUST post the laptop serial number -> https://www.badcaps.net/forum/troubl...before-posting
			by joven016Problem is blinking power led only
 i don't know exactly if it's s145-15igm or s145-14igm
 have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
 Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
 Already tested some of posted bios here
 S145-14igm - success but invalid serial and not booting on OS
 S145-15igm - success with serial and some other info in bios but still not booting on OS
 already tried installing new windows but always booting on bios setup
 windows installer flash drive detected on...-
							Channel: BIOS Requests ONLY!
			by mximiliandzGood morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...-
			by mkdjDear all,
 I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
 Here the steps I have taken to fix the laptop:
 - downloaded latest BIOS from Lenovo Website...
			This specification for the Lenovo IdeaPad S145 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S145 boardview and S145 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad S145...09-06-2024, 04:40 PM
			This specification for the Lenovo IdeaPad S145 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S145 boardview and S145 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad S145...09-06-2024, 04:00 PM
- Loading...
