lenovo IdeaPad S145 bios needed
  • hardware1
    • Sep 2021
    • 2940
    • N/A
    #301
    Re: lenovo IdeaPad S145 bios needed
    Originally posted by bejaoui
    can someone fix my bios dump,, problem is power led blinking and no display, thanks in advanced
    model S145-15IWL
    serial number PF1Q3SH0
    THANK YOU
    Here's your New BIOS, it's a Virgin BIOS from Lenovo with your DMI.
    all donations are welcome,
    • CeeEee4
      • 40
      • EU
      #302
      Hello
      I have same problem 81MV , blinking white light, no display, all voltages present apart from PL5901
      I try virgin bios from lenovo but it not work, i program with CH341A but still same problem.
      Here is original bios dump if anyone can help.. thank you
      • peste
        • 12964
        • ROMANIA
        #303
        Originally posted by CeeEee4
        Hello
        if it doesn't work with post #15, you have another problem..
        • lennito
          • Apr 2021
          • Spain
          #304
          Good evening, I recently updated the BIOS of my Lenovo S145 15IWL 81MV from the official Lenovo website, but since then, I am only getting BSOD screens when trying to access or install Windows, and the information displayed by the BIOS is incorrect. I no longer have the original BIOS, so I am providing you with the information, and if you could be so kind as to help me recover it. Thank you!
          Code:
          Lenovo Ideapad S145-15IWL
          Model Name: 81MV
          S/N:PF1KE318
          MTM:81MV00U9SP
          FACTORY ID: JVHFC1
          MO:PF9XB96270011
          • hardware1
            • Sep 2021
            • 2940
            • N/A
            #305
            Code:
            Model Name: 81MV
            S/N:PF1KE318
            MTM:81MV00U9SP
            FACTORY ID: JVHFC1
            MO:PF9XB96270011
            Why you don't have the Original BIOS? We need anything from your Chip even if it's corrupted. That will help us to confirm your BIOS and transfer your DMI.
            • lennito
              • Apr 2021
              • Spain
              #306
              Unfortunately, I don't have the original BIOS. I performed a complete wipe after several attempts, and used a dump that I obtained here with the similar hardware specs. It starts and runs fine with Ubuntu 22, but when I try to install Windows, I get numerous BSODs except in safe mode. I suspect it's because of the BIOS. Is there any way to obtain it, or should I give up on it? Thank you for your help.
              • hardware1
                • Sep 2021
                • 2940
                • N/A
                #307
                Try the file in Post #301, it's a Virgin BIOS for your Device.
                • Burnek
                  • Mar 2023
                  • 10
                  • philippines
                  #308
                  Someone Help pls blinking white led dont know how to copy dmi heres the original corrupted bios
                  Lenovo Ideapad S145-14IWL
                  Model Name: 81MU
                  • Burnek
                    • Mar 2023
                    • 10
                    • philippines
                    #309
                    Model Name: 81MU
                    Heres the file
                    • peste
                      • 12964
                      • ROMANIA
                      #310
                      Heres the file
                      try bios post#97..
                      https://www.badcaps.net/forum/showth...ht=81MU&page=5
                      • Burnek
                        • Mar 2023
                        • 10
                        • philippines
                        #311
                        Unfortunately it doesn't work still blinking led light I'm using a ch341a programmer btw and neoprogrammer
                        • Burnek
                          • Mar 2023
                          • 10
                          • philippines
                          #312
                          Originally posted by peste
                          Unfortunately it still doesn't work still blinking led, I'm using a ch341a programmer btw and a neoprogrammer software
                          • Burnek
                            • Mar 2023
                            • 10
                            • philippines
                            #313
                            On the other programmer it always says "Chip Main Memory with the contents are in disagreement, and when i checked it with HxD and compare it it's not identical with the file i write and the file on the chip
                            • Burnek
                              • Mar 2023
                              • 10
                              • philippines
                              #314
                              Also when I use flashrom on ubuntu and do md5sum checksum after programming the results are the same on chip contents and the file I was flashing
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #315
                                ...btw and a neoprogrammer software
                                Which version?
                                Clamp, or wires, or adapter, or ... is used to read the chip?
                                Become a Badcaps supporter
                                Thanks to all supporters.
                                • Burnek
                                  • Mar 2023
                                  • 10
                                  • philippines
                                  #316
                                  Originally posted by Vesko356
                                  Which version?
                                  I used ch341a usb programmer and desoldered the chip from the mb and soldered it to the programmer
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    #317
                                    How about the version of the NeoProgrammer?
                                    • Burnek
                                      • Mar 2023
                                      • 10
                                      • philippines
                                      #318
                                      I have able to flash the file @peste give and the laptop works, just curious why the led light keeps blinking
                                      • Burnek
                                        • Mar 2023
                                        • 10
                                        • philippines
                                        #319
                                        I change my software to Ch341a V1.18 the laptop turns on now using the file peste told me just didn't it works because the led keeps blinking i thought its not working but when I leave it on for about 30secs. the laptop boots. The only problem now is the led light keep blinking like it was before.
                                        • Burnek
                                          • Mar 2023
                                          • 10
                                          • philippines
                                          #320
                                          It's working now, I just leave it to charge then after turning on the blinking light is now steady thanks to all of you kudos.
                                          • joven016
                                            Lenovo Ideapad S145 need working bios HELP!!
                                            by joven016
                                            Problem is blinking power led only
                                            i don't know exactly if it's s145-15igm or s145-14igm
                                            have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                            Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                            Already tested some of posted bios here
                                            S145-14igm - success but invalid serial and not booting on OS
                                            S145-15igm - success with serial and some other info in bios but still not booting on OS
                                            already tried installing new windows but always booting on bios setup
                                            windows installer flash drive detected on...
                                            08-21-2025, 10:55 PM
                                          • mximiliandz
                                            help bios lenovo ideapad s145-14iil type 81w6
                                            by mximiliandz
                                            Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                            06-20-2025, 06:50 AM
                                            Lenovo IdeaPad S145 Notebook S Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad S145 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S145 boardview and S145 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad S145...
                                            09-06-2024, 04:40 PM
                                            09-06-2024, 04:00 PM
                                            09-06-2024, 03:30 PM
