HP SpareKey issue with my HP Spectre x360
  • tansoftware
    • May 2020
    • 13
    Hi there,
    I've come across an issue with my HP Spectre x360 13-ac033dx laptop after clearing the "Administrator" and "Power On" passwords. Originally I had the same password for both and that worked fine, until I decided to go into the bios and clear them. I'm sure I cleared both passwords as well as save my changes on the bios setup screen, but for some strange reason, my laptop continues to ask for a password and now refuses to accept my earlier password no matter what I do.
    The laptop does not produce any halt or error code, instead it asks for HP's SpareKey USB which I'm not sure what that is. The laptop is way past its warranty period and HP's tech support were not helpful at all.
    I tried disconnecting the main battery as well as the RTC CMOS battery for more than 24 hours to force the laptop to clear the CMOS but that did not work. I also tried to conduct a BIOS recovery by pressing the "Windows Key + B" button combination at power up, but even after re-flashing the BIOS, it continues to ask for the password.
    I am comfortable using the CH341A with a Pomona SOIC 8 Clip to make a bios dump. I'm just not sure which is the bios chip on my laptop's motherboard. I was able to locate a "Winbond 25Q80DVIG" chip, but I'm not sure if this is the correct one or if there are multiple chips that must be dumped.
    If anyone has any experience with this laptop, I'd really appreciate your help and guidance.
    Here are my laptop's specs:
    Model: HP Spectre x360 13-ac033dx
    Product ID: Z4Z22UA#ABA
    Build ID: 17WW1PXT603#SABA#DABA
    Motherboard: 918042-601
    Specs: 16GB w/ i7-7500U 2.7GHz CPU
    Thank you for your time and support.
    Best regards,
    • 21609
    Re: HP SpareKey issue with my HP Spectre x360
    When you set the "Administrator" and "Power On" passwords you must have opted in for HP SpareKey Enrollment .Enter the wrong pass 3 times,sparekey will ask you 3 security questions such as your mothers maiden name,first pet etc.If you can`t remember those... then post your bios backup,the largest size bios chip ,not the 25Q80DVIG.
    • tansoftware
      • May 2020
      • 13
      HI @SMDFlea
      I don't recall creating an HP SpareKey USB stick for that purpose. I don't have one. When you say the largest bios chip, which chip would that be ? I've taken photos of what I thought are the relevant chips, but when doing some research, the "Winbond 25Q80DVIG" comes up as being the BIOS chip.
      I've attached some photos to give you an idea. If you want me to take more photos of different chips, I can certainly do that.
      I'd really appreciate your advice.
      Thanks again for your time and support.
      Regards,
      Terry
        • 21609
        Spectre x360 DAX31MB1AA0 the bios is 8MB /8M-byte
        W25Q80DV: 8M-bit/1M-byte
        I can`t show you the bios location on the pictures but look for one with 64 in the name
        • tansoftware
          • May 2020
          • 13
          I did check my bother board again, and this is the only chip that shows that kind of number. I even scanned my motherboard and attached it for reference. Unfortunately most of the numbers on the chips are unreadable. But I'll follow up with some Hi Res shots of all the chips on it hoping it would help.
            • 21609
            Can you see the part number on the chip in the yellow circle
            • tansoftware
              • May 2020
              • 13
              Here are hi res photos of all the chips on the motherboard excluding the CPU.
              The only chip I could find that is relevant to this is the Winbond chip. There are no other Winbond chips on it.
              • tansoftware
                • May 2020
                • 13
                Please find hi res photo of requested chip.
                It's:
                BH61A
                25B64CSIG
                P13192
                Thanks for your help.
                  • 21609
                  It's:
                  BH61A
                  25B64CSIG
                  P13192
                  Thats the one !
                  Added datasheet.
                  • tansoftware
                    • May 2020
                    • 13
                    Ok great. So we've been able to identify which chip needs to be dumped. So now, I just need to attach a dump of this chip ? Or are there other chips I need to dump as well ?
                      • 21609
                      The CH341A doesn`t support the 25B64CSIG .Use AsProgrammer software instead. That doesn`t support the 25B64CSIG either but does support MX25L6473E, its cross compatible, change the hardware to CH341A,then choose the (MXIC) MX25L6473E from the list .
                      AsProgrammer - https://www.badcaps.net/forum/showpo...6&postcount=10
                      • tansoftware
                        • May 2020
                        • 13
                        Thank you for the instructions. I just found out my CH341A is damaged. I ordered another one which should arrive in a week. Will post my dump as soon as I get the new CH341A adapter. Do I need to de-solder the chip prior to dumping it ? Or can I just dump it using the Pomona Soc8 clip while it's still soldered to the motherboard ?
                          • 21609
                          Its better to desolder it if you can. I`ve got three ch341a`s ,one with a blue pcb,the other two green.Both green ones were DOA ,resoldering all the pins brought them both back to life .
                          • tansoftware
                            • May 2020
                            • 13
                            I tried resoldering all the pins on the ch341a hoping it would fix it, but it still doesn't work.
                            In fact, if I leaving my ch341a plugged in my PC's USB port for 20 seconds or more, it gets super hot, you can literally fry an egg on the pcb.
                            I don't want to damage my desktop's USB port or short its motherboard. I'll wait for the new ch341a to arrive before I continue with the BIOS dump.
                            I can't thank you enough for all your help and support.
                            I'll report back once I've successfully dumped my BIOS.
                              • 21609
                              ok , no problem .
                              • tansoftware
                                • May 2020
                                • 13
                                I just got my new CH341a and was able to run three read / verify tests to ensure that the chip is detected and read correctly. Here are the results:
                                Current programmer: CH341
                                ID(9F): C84017
                                ID(90): C816
                                ID(AB): 16
                                ID(15): 2020
                                AsProgrammer automatically identifies the chip as GD25Q64B, but as instructed, I manually set the chip type to MX25L6473E
                                1st Read
                                Execution time: 0:01:07
                                CRC32 = 0x45897089
                                2nd Read
                                CRC32 = 0x45897089
                                3rd Read:
                                Execution time: 0:01:06
                                CRC32 = 0x45897089
                                I've attached the BIOS dump as requested. Appreciate your help in removing the Administrator / Power On passwords from it. Please let me know if you require anything else.
                                Thanks again for all your help and support with this.
                                • tansoftware
                                  • May 2020
                                  • 13
                                  Hi @SMDFlea
                                  Quick question, I'm trying my luck with the HP Unlocker Tool, and it seems to have successfully generated an unlocked version of my bios.bin file. Do I need to erase the chip using AsProgrammer first before writing the unlocked bios.bin file ? Or can I just overwrite the chip as is ?
                                  • tansoftware
                                    • May 2020
                                    • 13
                                    Hi @SMDFlea
                                    I have an update to share.
                                    So I used the HP Unlock Tool to generate an unlocked version of my bios.bin file. I erased the chip, wrote the unlocked bios.bin, and verified that the image was identical to the chip's memory.
                                    This is what happened when I switched the laptop on:
                                    - Caps Lock button blinks 3 times quickly;
                                    - then laptop powers off and powers on;
                                    - then Caps Lock button blinks 5 times slowly;
                                    - then Caps Lock button blinks 3 times quickly;
                                    - and continues looping the blinking sequence on and on.
                                    During this whole process, the screen's backlight is always off and never powers up.
                                    Luckily I had made several verified backups of my original BIOS, which I was able to successfully restore and get it to start up again but unfortunately the laptop continues to ask for the password.
                                    This tells me that the BIOS reading / writing process works, but it seems the HP Unlock Tool somehow messes up or corrupts the BIOS image.
                                    If you could help, I'd really appreciate that.
                                    Thanks again.
                                    • RethoricalCheese
                                      • Mar 2013
                                      • 1519
                                      • Estonia
                                      Because spectre is not probook/elitebook/zbook.
                                      Your password is prot8200
                                      • tansoftware
                                        • May 2020
                                        • 13
                                        I can't thank you enough.
                                        Is this HP's default Administrator password ? because it doesn't look like anything I've used in the past
                                        Anyways, it worked perfectly well, and I was able to reset both the Administrator and Power On passwords successfully.
                                        Thank you all for your help and support. This is a wonderful community.
                                          HP Spectre x360 Spectre x360 - 13-aw0197tu Hybrid (2-in-1) 13 Specification for Upgrade or Repair
                                          This specification for the HP Spectre x360 Spectre x360 - 13-aw0197tu Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 - 13-aw0197tu boardview and Spectre x360 - 13-aw0197tu schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 12:10 PM
                                          HP Spectre x360 Spectre x360 Conv13-aw0054na Hybrid (2-in-1) 13 Specification for Upgrade or Repair
                                          This specification for the HP Spectre x360 Spectre x360 Conv13-aw0054na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 Conv13-aw0054na boardview and Spectre x360 Conv13-aw0054na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-06-2024, 11:50 AM
                                          HP Spectre x360 Spectre x360 - 15-df0068nr Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                                          This specification for the HP Spectre x360 Spectre x360 - 15-df0068nr Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 - 15-df0068nr boardview and Spectre x360 - 15-df0068nr schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 07:20 AM
                                          HP Spectre x360 Spectre x360 - 15-ch050na Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                                          This specification for the HP Spectre x360 Spectre x360 - 15-ch050na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 - 15-ch050na boardview and Spectre x360 - 15-ch050na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 06:21 AM
                                          HP EliteBook x360 1030 G4 + Spectre Tech Tote Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 1030 G4 + Spectre Tech Tote Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G4 + Spectre Tech Tote boardview and 1030 G4 + Spectre Tech Tote schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-06-2024, 11:39 AM
