I need the BIOS for the GL752VW Rev 2.0 board
  • jotacest
    • Apr 2020
    • 8
    • Spain
    Hello! I need the BIOS for the GL752VW Rev 2.0 board. I got version 2.1 online and it works, but the keyboard does not light up, I don't know if this is the problem, I have installed the appropriate driver "ATKPackage V1.0.0061" but it still does not light up. The problem that my pc had is that it stayed in the ASUS logo, I put the BIOS rev 2.1 and everything except the keyboard lighting began to work. I do not understand what is happening, but if you can pass me the BIOS rev 2.0 I would like to try it. Thank you!!
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: I need the BIOS for the GL752VW Rev 2.0 board
    https://www.badcaps.net/forum/showthread.php?t=69782
    May have to use bt2.exe instead of bt.exe.
    • peste
      • 13924
      • ROMANIA
      try..
      • jotacest
        • Apr 2020
        • 8
        • Spain
        I have tried several versions of BIOS and I do not understand why the keyboard of my pc still does not light up, some keys work for me, for example when I press FN + F2, but it does not work for me when I press FN-F9 so that the touchpad is blocked and neither FN-F3 and FN-F4 if I want to increase or decrease keyboard brightness. I imagine it will be a driver problem, but I'm not sure ... Thank you very much for the help !!
        PHOTO:
        https://drive.google.com/open?id=1-v...6y0URAHLjjFR0T
        • jotacest
          • Apr 2020
          • 8
          • Spain
          Okay, FN + F9 already works! The touchpad driver was missing, but FN-F3 and FN-F4 still don't work ... I don't understand why ....
          Could it be because the flex in the photo is not connected because it is broken?
          PHOTO:
          https://drive.google.com/open?id=1-e...KnwnKpU0DfrbdB
          • jotacest
            • Apr 2020
            • 8
            • Spain
            Hi Piernov, thank you very much for answering, but I don't quite understand how to do the process. I have read the "read me.txt" but I do not understand what it says about "gsod solution", nor do I understand what you are saying about having to do it with "bt2.exe". Could you help me a little more? I think the solution you are proposing is going to be the right one. I am very interested in doing it.
              • 22286
              Have you installed the nvidia drivers from asus support .
              • jotacest
                • Apr 2020
                • 8
                • Spain
                Problem solved!! I have created a bootable pen with MS-DOS using the "HP USB Disk Storage Format Tool 2.2.3" application, setting the format to FAT32 and checking the option "Create a DOS startup disk using system files located at:" and download from Google the "win98boot" folder. Once done I put the files bt2.exe and fixmykb.bat. I restart the pc and boot from the pen drive. I write "bt2.exe -C CNFG / W DD 7C" I hit enter and solved! Thank you very much to all!
                • joby91
                  • Sep 2018
                  • 43
                  • german
                  i have had the same Problem with mine gl752vw Laptop.
                  Backlight is working now thanks to your comment but my problem ist that my touchpad is not working.
                  Can you send me the link where you have found the bios file so i can try to reflash the bios again?
                  My mainboard is also rev. 2.0 and i have flashed bios from rev. 2.1.
                  • peste
                    • 13924
                    • ROMANIA
                    post the backup copy of the original bios and clear pictures with the stickers on the ram memory slot.
                    • soul299
                      • Aug 2023
                      • 38
                      • Philippines
                      I need help, ROG laptop.
                      issue, auto power off after 5secs
                      no short on board.
                      BIOS attached in this message
                      S/N: FBN0CY023692448
                      model: GL752V
                      • DynaxSC
                        by DynaxSC
                        11-17-2023, 10:56 AM
                      • edward card
                        BIOS Request: MSI Raider GE68 HX 14VGG-287US (Board: MS-15M2) - No POST
                        by edward card
                        I'm requesting a working BIOS dump for my MSI laptop, which I plan to provide to a repair technician.
                        Make/Model: MSI Raider GE68 HX 14VGG-287US Board Model: MS-15M2 (Note: I have the serial number ready to be provided to the technician for DMI transfer)
                        Problem Description: The laptop fails to POST. The only sign of life is the GPU fan spinning up after a couple of minutes. The screen remains black.
                        Background / Fault Event: The system was working perfectly. The issue occurred immediately after entering the BIOS advanced menu and exiting with "Discard...
                        10-06-2025, 05:41 AM
                      • cr4zychriss
                        by cr4zychriss
                        • Rebrand: PC Specialist
                        11-14-2025, 04:04 PM
                      • pirati
                        by pirati
                        10-27-2025, 04:20 PM
                        by Vesko356
                        08-11-2023, 03:27 AM
