need remove password lenovo p52
    Re: need remove password lenovo p52
    Originally posted by HoulScreamPL View Post
    Hello, i have problem with removing bios password from Lenovo P52. I've tried lenovo autopatcher method but after injecting patch just black screen and cpu getting hotter. Can u help me ? Original and patched dumps in attachmetns. Thanks
    You must post the Serial number
      Sorry
      S/N: PF-1MR2B2 19/03
      TYPE: 20M9-0017MX
        Any chance for help ?
        try this and follow steps described in autopatcher
        all donations are welcome,
          Still the same issue, i triple checked your patched file and still dont working.
          Just few restarts, black screen, cpu getting hot and beep code. Any other ideas ? I checked laptop still working on original bios file with password without problems.
            did you push cover switch? did you remove cmos battery? use a charger >130W, otherwise will not boot.
              Cover switch is glued and secured by tape, ssd removed, cmos bat. removed, i use 230W Lenovo rectangle charger, tried on fully charged original battery and laptop behave like on charger, 2 restarts, black screen and beeps
                try this clean ME patched bios.
                  On this bios still the same issue but i saw 4 restarts not 2 like before. I checked beep code and it says:
                  0285 - TCG-compliant functionality-related error (might be the TPM initialization failure)
                    read again original bios chipset. I think you read it with errors 1st time.
                      U mean use original bios, turn on laptop etc. and after that read chip again and try patch it again ??
                        ThinkPad P52 NM-B562
                        for someone who need information
                        32 mb bios you must read write mec1653. 1 resistor switch 4 jumper wire.
                          How can you read and write MEC1653? Where is the JTAG ports? I have T580 LTS-2 17812-1 board and cannot find the JTAG to work with the MEC
                            SMDFlea commented
                            Editing a comment
                            Off topic.This thread is only for the ThinkPad P52,and the post above yours is for the NM-B562 motherboard
