HP Elitebook X360 1030 G4 BIOS unlock request
  • RethoricalCheese
    • Mar 2013
    • 1518
    • Estonia
    #41
    Re: HP Elitebook X360 1030 G4 BIOS unlock request
    Might be windows autopilot instead. It can set bios password aswell. In this case, solution would be unlock bios and install Linux
    • mohibr
      • Aug 2012
      • 12
      Hi All,
      Could someone please help me remove the password from my bios dump, its for the Elitebook X360 1030 G4.
      Thank you for the help.
      • mohibr
        • Aug 2012
        • 12
        Here is the 16MB file.
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          #44
          Try & leave feedback:
          Become a Badcaps supporter
          Thanks to all supporters.​
          • mohibr
            • Aug 2012
            • 12
            Thank you so much! That worked great, after flashing the dump back system went into bios recovery, after a few reboots password has been removed.
            Again, thank you for your help, really appreciate it.
            Kind regards.
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              #46
              Kind regards.
              You're welcome.
              Have fun!
              • keczuk
                • 83
                • WWW
                #47
                No solution for this autopilot ?
                • jsmrepairs
                  EXPERT
                  • Apr 2017
                  • 6
                  Hi guys I also have an Elitebook X360 1030 G4 with a bios password can someone help remove password if I upload the bios dumps if so which IC do I need to dump as it look like this has 3 bios IC
                  See image attached
                  • peste
                    • 12887
                    • ROMANIA
                    #49
                    See image attached
                    remove the password yourself using this program...
                    https://www.badcaps.net/forum/showthread.php?t=98539
                    make a copy of the contents of the 16MB bios chip before writing with the new content ...
                    • amine23
                      • Apr 2017
                      • 85
                      • Algeria
                      #50
                      Re: NEED HP Elitebook X360 1030 G4 BIOS unlock
                      Originally posted by Ghamidi
                      need unlock HP Elitebook X360 1030 G4 BIOS
                      thank you
                      try bro
                      • Correedee
                        • Nov 2022
                        #51
                        Originally posted by Ghandy
                        Hi all, sorry I'm clearly missing something in this process- is there a start here guide or can anyone point me in the right direction. Similar situation, I have a 1030 g4 that I bought and it worked to start with but after a reset I got a locked message and now can't get into the bios password area (f10) to remove it. I guessed at the files being something I needed to add to a usb drive as bootable media but no luck.
                        Appreciate I'm a total novice at this, just don't want to be £400 out due to a Gumtree but. The seller obviously knew it was going to happen as they vanished and the mobile number no longer works
                        Hi ghandy , I hope I'm doing this correct , I'm new here and don't quite know what I'm doing however I do hope you are able to see this,
                        I just wanted to know what happened following up on your story,
                        The same exact thing has happened to me literally everything you said and what's more head blowing is I bought it from the same place and the exact same price, the guy now has disappeared the number doe T work and the address I collected from was an Airbnb so I got stitched up, I'm in uni and without this I won't be able to do my work at home so I'm literally terrified.
                        We're you ever able to sort out yours? Or if not what did you do ?
                        Please help me! i tried to pm you but I wasn't able to yet but you might be able to do so to me ? I'm not sure but I look forward to hearing from you hopefully
                        • macadam
                          • Apr 2016
                          • 51
                          #52
                          hi
                          i need a help
                          ive got a elitebook 1030 g4
                          bios was locked and message on full screen while im use that the laptop is blocked by someone
                          i managed to unlock but now every time when i switch on the laptop its shows message product information not valid
                          system is booting in manufacturing program mode ....:1
                          i dont want to enter the original serial number or mac etc because it maybe block again
                          • peste
                            • 12887
                            • ROMANIA
                            #53
                            Originally posted by macadam
                            hi
                            i need a help
                            try this..
                            https://www.youtube.com/watch?v=9T57ktw8n3Y
                            • macadam
                              • Apr 2016
                              • 51
                              #54
                              Originally posted by peste
                              thanks
                              i can enter the info from laptop but the problem is, im thinking if enet the serial number and mac address it can block again when i connect to internet
                              • peste
                                • 12887
                                • ROMANIA
                                #55
                                thanks
                                well, if the password has been deleted, how to get it back...
                                • wolf3d.exe
                                  • Jan 2023
                                  • 33
                                  I can see 3 BIOS chips on laptop, one is smallest in size, the one in the middle is 25c256jveq winbond and the last one next to it is another winbond 16mbs. I have ch341a programmer.
                                  My understanding I also need to reprogram the big winbond chip (I think it is 32mbs). Can my ch341a read this chip?
                                  Also which chips do I need to dump? (32 and 16?)
                                  Last question can I use RCUnlocker for these, if so which dumps needs to be treated (32 and 16?) ?
                                  • hardware1
                                    • Sep 2021
                                    • 2939
                                    • N/A
                                    #57
                                    Use RCUnlocker with your 16MB Chip that's all.
                                    all donations are welcome,
                                      VIP Moderator
                                      • Aug 2018
                                      • 4386
                                      • Bulgaria 🇧🇬
                                      #58
                                      No, your understanding is wrong.
                                      Yes, it can be read by the Ch341a.
                                      16
                                      Yes , you can.
                                      16.
                                      • wolf3d.exe
                                        • Jan 2023
                                        • 33
                                        16
                                        Yes , you can.
                                        16.
                                        Thank you, all done! Flashed 16mb. I was skeptical about 32mb dump because some people asked to post those as well. Also a question about surestart. What does 32mb chip hold? Is there a copy of locked bios? (that could be restored if sure start activated and detects tampering or difference between backup and actual)
                                        • hashmiUNITED
                                          • Mar 2023
                                          • 5
                                          #60
                                          Please can someone check the 16MB bin file below. I tried loading it onto RC_unlocker but get the message - "Wrong chip, try reading and unlocking 16MB chip".
                                          Thanks.
                                            HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) Specification for Upgrade or Repair
                                            This specification for the HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 boardview and EliteBook x360 1030 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 08:27 AM
                                            HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) Specification for Upgrade or Repair
                                            This specification for the HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 (ENERGY STAR) boardview and EliteBook x360 1030 G2 (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-06-2024, 06:40 AM
                                            09-06-2024, 05:33 AM
                                            HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) Specification for Upgrade or Repair
                                            This specification for the HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EquipoEliteBook x360 1030 G4 boardview and EquipoEliteBook x360 1030 G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                            09-06-2024, 11:32 AM
