I have big problem with x360 g2 1030 bios
  • layad
    • Nov 2011
    • 244
    Hi there , a laptop came with bios password , checked the laptop inside and found two chips, the first one is 25q80dv1g( number 1 in the pic), and 25q128jvpq (number two in the pic) , first I flashed chip number one with a dump file found it in this forum, nothing changed, the laptop still working and the password still there, I flashed the second chip with the same file the laptop died , the backup file is corrupted , bought a chip from Ebay but still the same , anyway to sort out chip number two ?
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: I have big problem with x360 g2 1030
    What programmer did you use?
    • layad
      • Nov 2011
      • 244
      ch341a, asprogrammer and flashrom
      • piernov
        • Jan 2016
        • 4437
        • France
        I don't have a CH341A, but I've seen people having a lot of problems with 128Mb chips when trying to dump/flash them with CH341A.
        • Vesko356
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          Files for chip 1 and 2 are different, flash the chips with corresponding images, verify the written files to make sure the chips are correctly programmed and you are good to go, nothing hard or special.
          Try AsProgrammer with CH341A support
          DOWNLOAD LINK
          Edit: I'm trying to upload the bios files, but permanently receive same error :
          Become a Badcaps supporter
          Thanks to all supporters.
          • layad
            • Nov 2011
            • 244
            Can you try please to upload them and tell me which file to which
            • Vesko356
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              I just tried again and got the same error . I sent a message to the moderator about the issue. In the afternoon I will try again, if the problem persist I will upload the files to Dropbox and will post a link in the thread.
                • 21307
                The problem is with the 25q128.BIN. It won`t upload zipping it seperately,the file is corrupt somehow
                • Vesko356
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  Originally posted by SMDFlea
                  ...the file is corrupt somehow
                  I don't think so, most probably it's a forum platform bug:
                    • 21307
                    I didn`t mean the ME management engine firmware, i meant the part of the whole file,something isn`t right with it, its not the file attributes or size.It could be NTFS related.
                    Anyway the ME firmware is initialized which means its been booted on another machine already, the ME is "dirty" so it would need cleaning, i tried that,the file is still not uploading. I don`t think its a forum platform bug.
                    • Vesko356
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      I don't think it's a file related, but who knows.
                      If you clean the ME region already, please spare me the additional work and upload the file here, I mean upload the file somewhere and post here the link.
                        • 21307
                        I did try to,but it wouldn`t upload.Still testing uploading files.
                        • Vesko356
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          I also tried many times with no success at all, still same error. Just wanted to tell you to upload cleared ME file somewhere like Dropbox maybe and post the link here for layad, if you saved the cleared file, if not I'll do it myself.
                          • Vesko356
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            @layad as I promised - below is the link to zip file containing bios image, to be more easy for you I've named the file 25q128.bin and as the name suggest this is image you must program to chip 2 (25q128jvpq). As you mentioned the notebook was working with the image in chip1 and stopped working after manipulations with chip2, so for now leave the chip 1 as is. Just program chip 2 with the 25q128.bin file and leave feedback here.
                            Good luck
                            https://www.dropbox.com/s/f681zd0e70...5q128.zip?dl=0
                            • layad
                              • Nov 2011
                              • 244
                              thank you all, the file been uploaded is not working , the laptop acting the same , im not sure anymore the chip number 2 in the pic is the bios chip at all, anyone can confirm what chip is this as i couldint find the schematic? that was my mistake didnt make sure that i have a good backup thanks
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                ...im not sure anymore the chip number 2 in the pic is the bios chip at all...
                                Don't worry, it is the bios chip.
                                OK try these, again the file names match the chip names (I hope you verify the programmed dump after flashing), so again first program chip 2, if that doesn't help again, program also chip 1 with the corresponding bin file:
                                https://www.dropbox.com/s/uww3qb1umt...01030.zip?dl=0
                                • shovenose
                                  Send Doge Memes
                                  • Aug 2010
                                  • 6575
                                  File uploads should be working now, by the way.
                                  • Vesko356
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    No, still same problem:
                                    • shovenose
                                      Send Doge Memes
                                      • Aug 2010
                                      • 6575
                                      Strange, they seem fine on my end. What file are you trying to upload?
                                      • Vesko356
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        This one:
                                        And same problem with the file from this thread.
                                          HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EquipoEliteBook x360 1030 G4 boardview and EquipoEliteBook x360 1030 G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-06-2024, 11:32 AM
                                          HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 boardview and EliteBook x360 1030 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 08:27 AM
                                          HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 (ENERGY STAR) boardview and EliteBook x360 1030 G2 (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-06-2024, 06:40 AM
                                          09-06-2024, 05:33 AM
