HP Elitebook X360 1030 G3 BIOS and EC unlock request
  • volinakis
    • Jan 2021
    • 2872
    • N/A
    Re: HP Elitebook X360 1030 G3 BIOS and EC unlock request
    Originally posted by livestrong
    After some research I guess I have to flash the 256Mb BIOS chip, should be the MX25L25673G. So I am new in this field, I have to buy some hardware to flash.
    I guess the cheapest way to start is to buy the CH341A set:
    https://www.amazon.de/KeeYees-SOIC8-...language=en_GB
    But unforutnately the MX25L25673G is not in the supported chips list. So does it mean that I can't read/flash the chip with CH341A or does it just mean, that I need another software to read/flash?
    you can use ASProgrammer with CH341A for MX25L25673G but I advice you to buy an RT809F, many had problems to read properly eeproms with CH341A or at least order a similar bios chipset and use it for modified file and leave original bios chipset intact. Do more readings with CH341A and compare them to be sure it was read properly.
    • rusgard
      • Mar 2020
      • 37
      • Ukraine
      Please help, to unlock admin passord
        • 21605
        see post #16 ,try RCUnlocker
        • rusgard
          • Mar 2020
          • 37
          • Ukraine
          Already try, not working, with rcunlocker and hpunlocker
          • hardware1
            • Sep 2021
            • 2946
            • N/A
            Here's your Unlocked Bios.
            Program the both chips together, In the first boot go to Bios Menu and disable security options (Default).
            all donations are welcome,
            • hoaca388
              Badcaps
              • Jan 2022
              • 12240
              #26
              Unlocked
              • Anothere
                • Feb 2023
                • France
                #27
                Good evening, I'm not very good in English, I've read this page and page 1 and 14 to 16 of the RC Unlock section, and I have some questions, above on this page someone has attached two photos, so which chip should be flashed? the one surrounded by "rubber" so the second photo? how does the tool work? I connect my eprom reader via usb and it will automatically detect my chip? I'm sorry if the questions have already been asked, I really don't understand English or I may have missed something, I thank you for your information and your work in advance.
                • Concord2022
                  • Aug 2022
                  • 17
                  • nigeria
                  #28
                  Re: HP Elitebook X360 1030 G3 BIOS unlock request
                  Pls unlock my bios
                  • peste
                    • 13343
                    • ROMANIA
                    #29
                    Originally posted by Concord2022
                    Pls unlock my bios
                    also post the content of the 16 MB chip..
                    • Concord2022
                      • Aug 2022
                      • 17
                      • nigeria
                      #30
                      Here it is sir thank you
                      • Concord2022
                        • Aug 2022
                        • 17
                        • nigeria
                        #31
                        Credit card donations dosnt seem to be working
                          • 21605
                          The Admin only accepts Paypal.
                          • andy1976
                            • Nov 2011
                            #33
                            I have a x360 1030 G3 and tried to remove the admin password with unlocker.
                            First I made a backup of the MX25L25673G and then flashed unlocked.bin.
                            Then the Laptop didn't boot up.
                            I restored the backup but the laptop won't boot up anymore.
                            No screen, caps lock is lit and after a few seconds a very short flickering of the led.
                            Attached the backup which I restored.
                            Would be great if you could help me. Thanks.
                            • Markus1741
                              • Sep 2020
                              • 902
                              • N/A
                              #34
                              Hello try this ME Clean file from your orig Backup.
                              Good luck ...
                              • andy1976
                                • Nov 2011
                                #35
                                Thank you so much.
                                Just tried it. Unfortunately it is not working. The power LED on the side is just blinking every second. No other signals.
                                Perhaps you have another idea ?
                                Thanks.
                                • mepttbblk
                                  • Jan 2022
                                  • 35
                                  • Ukraine
                                  #36
                                  Hi, i've removed password with rcuncloker but still have absolute, help please remove it, post the original with password. Thanks in advance
                                    • 21605
                                    Doesn`t it work if you set a new admin password then disable absolute ? .
                                    • mepttbblk
                                      • Jan 2022
                                      • 35
                                      • Ukraine
                                      #38
                                      unfortunately not, the Absolute item is inactive
                                      • Glytch
                                        • May 2020
                                        • 17
                                        • UNITED KINGDOM
                                        #39
                                        HP x360 1030 G3 Absolute active
                                        Hi All,
                                        I have managed to remove the admin password using the hex editor method in the post, however the absolute is still active. can someone please help me deactivate that. Original dump 32mb and 16mb ec are attached below
                                          Vesko356 commented
                                          Editing a comment
                                          You MUST:
                                          • Read BIOS guides, methods, resources and tools
                                          • Try the method at BIOS guides, methods, resources and tools before requesting help
                                          • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                          • Use search function in case someone already answered your request
                                          • Post under a related thread if it exists
                                          • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                                          • Name your thread with make, full model numbers and request
                                          • Provide a BIOS/EC dump if possible
                                          • Attach files directly to your post instead of linking to external websites
                                          • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms.
                                      • Glytch
                                        • May 2020
                                        • 17
                                        • UNITED KINGDOM
                                        #40
                                        Serial Number: 5CD9093BCM
                                        Last edited by Vesko356; 01-26-2024, 01:11 PM. Reason: Attached files removed. Already posted above.
                                          HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 EliteBook x360 1030 G2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 boardview and EliteBook x360 1030 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 08:27 AM
                                          HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 EliteBook x360 1030 G2 (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook x360 1030 G2 (ENERGY STAR) boardview and EliteBook x360 1030 G2 (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-06-2024, 06:40 AM
                                          09-06-2024, 05:33 AM
                                          HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 EquipoEliteBook x360 1030 G4 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EquipoEliteBook x360 1030 G4 boardview and EquipoEliteBook x360 1030 G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-06-2024, 11:32 AM
