Hp 17-x010ur 856693-601 Panini 448.08c01.0011 Bios plz upload i have backup file but locked with password
Re: Hp 17-x010ur 856693-601 Panini 448.08c01.0011 Bios
this is backup of locked Hp 17-x010ur 856693-601 Panini 448.08c01.0011Attached FilesLast edited by SMDFlea; 01-02-2020, 07:06 AM.Comment
Do you get a code if you enter the wrong password 3 times , if so try the password generator - https://bios-pw.org/Last edited by SMDFlea; 01-02-2020, 07:06 AM.Comment
Try this. good LuckAttached FilesLast edited by SMDFlea; 01-02-2020, 07:07 AM.Comment
by Chris_standHello,
i hope to find help her in the forum. It is a littlebit tricky. I searched many Days about disabling IntelME that was may major task. So i have a Clevo PD50PNN motherboard.
At first i tried to Backup the BIOS with tools direcly from Windows(normaly i am a Linux user). But no full success because not every part of the bios was readable. So i bought a modified CH341a for a Backup.
Backup worked but since the backup the Laptop is not booting anymore. I flashed the newest Version oft the BIOS with success, verfiy everything ok.
But the...-
Channel: BIOS Requests ONLY!
by fulaphexhello friends - I have purchased a used Thinkpad X13 Gen 3 AMD variant and only after making the purchase I realised that the BIOS is locked. I have spent a bit of time browsing the forum and from what I understand it's possible the modify the BIOS that is currently on the machine and remove the password from that BIOS. For dumping the BIOS from the laptop I have ordered this ch341a programmer. Below is a photo of the password prompt:
I have taken the cover off the laptop and I found that "serial number" is "GM-0358MB" and "type number" is "21CN-S19U00"....-
by idegeneratedHi everyone,
Thanks for your help in advance. I have an HP 800 G6 that has "Protected by HP Sure Start" on boot. It has a locked BIOS that I'm trying to remove with RCUnlocker, but even after unlocking it and reflashing, it doesn't appear to work. The password is still prompted when I attempt to enter the BIOS.
Using NeoProgrammer in Windows and a CH341a I was able to read two 16MB BIOS chips, a GD25Q127C and a GD25Q128x like this thread here: https://www.badcaps.net/forum/troubl...-desktop-mothe...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
