HP Elitebook Folio 1040 G3, Password Unlock
  • Mx7Nine
    • Jul 2020
    • 15
    Re: HP Elitebook Folio 1040 G3, Password Unlock
    Hi all. I have a 1040 G3 with both power on and BIOS Admin password. Is it possible to remove both? Thank you to anyone who can help.
    • lapfix
      • Mar 2020
      • 2764
      • my workshop
      Try and give feedback
      • Mx7Nine
        • Jul 2020
        • 15
        Thanks for the amazingly quick response. I have just tried the new file. It has removed the power-on password but the BIOS Admin password is still there.
        Please let me know if it was something I have done wrong of if you need the bin file for the other chip.
        • RethoricalCheese
          • Mar 2013
          • 1519
          • Estonia
          Replace the whole UserCred section with a clean UserCred section.
          • Mx7Nine
            • Jul 2020
            • 15
            Thanks to both of you. I made the same changes to the admin pass section as was made to the power-on and now I'm in.
            Is there anywhere to learn how to do this for different makes/models? It would be nice to be able to help out others with this sort of thing.
            • RethoricalCheese
              • Mar 2013
              • 1519
              • Estonia
              #26
              When you get access, restore security settings to default aswell. This clears everything that might still be there.
              • andresi
                • Nov 2020
                • 160
                • INDONESIA
                #27
                Help Guys >> 1040 G3 Touch, Pass locked
                • RethoricalCheese
                  • Mar 2013
                  • 1519
                  • Estonia
                  #28
                  Is it me or your file(s) seem broken. Try reading again.
                  • andresi
                    • Nov 2020
                    • 160
                    • INDONESIA
                    #29
                    sorry, this one.
                    • qayyum786
                      • Aug 2018
                      • 1959
                      • INDIA
                      #30
                      try
                      • andresi
                        • Nov 2020
                        • 160
                        • INDONESIA
                        #31
                        omg, this work, thank you
                        • barryv4
                          • Feb 2021
                          #32
                          Please send me some instructions on how to do this as I have the same machine.
                          • barryv4
                            • Feb 2021
                            #33
                            Hi, I have the same HP 1040 G3 and the same problem as yours had. What is this .rar file that you sent to the guys that helped you. Please explain? I had a look at the motherboard and saw some numbers similar to what you posted. Can't remember where I saved this info but can look again.
                            • barryv4
                              • Feb 2021
                              #34
                              Re: Hp elitebook 1040 g3 bios password
                              Hi I also have a 1040 G3 that is password locked. how do you generate these dump files that you sent to the forum please?
                              • peste
                                • 13924
                                • ROMANIA
                                #35
                                You need an SPI programmer ...
                                https://www.youtube.com/watch?v=DWWigscuQDY
                                • Didier91
                                  • Feb 2021
                                  • France
                                  #36
                                  Good morning all.
                                  I bought a cheap HP EliteBook Folio 1040 G3 from a brooker.
                                  It works perfectly but the bios is locked and I cannot boot from an external medium (USB key for example) to put everything back OK as new.
                                  How to do?
                                  I read that it is necessary to extract a Bios file from a circuit. But which one? I figured it was in U23 but where is U23 on the motherboard.
                                  Without diagram or implantation of components, not easy.
                                  Does anyone have this card implantation so that I can remove this circuit. In all the discussions that I have read, I cannot find the reference of the chip.
                                  What is his little name.
                                  I specify that I am sufficiently experienced to desolder this component (SO8 I suppose) and I have the equipment either at home or at my work for the welding operations.
                                  I will buy a programmer if necessary (EZP2019). For the software, you can advise me.
                                  Is it possible to extract the bios without desoldering the components. Using special pliers.
                                  Post a bit long for a start but at least everything is settled.
                                  Thank you all for your answers and tips.
                                  Regards,
                                  Didier from France.
                                  • Db24448
                                    • Mar 2021
                                    • Uk
                                    #37
                                    I also have a HP Elitebook 1040 G3 with a password lock on the BIOS. I have tried the HP tool from the forum but with no success, if anyone can help with the attached, I would appreciate it massively.
                                    Kind regards
                                    Dan
                                    • Db24448
                                      • Mar 2021
                                      • Uk
                                      #38
                                      I realised I should have read both chips.
                                      • peste
                                        • 13924
                                        • ROMANIA
                                        #39
                                        upload this, along with the original 8MB of the laptop ...
                                        • Mx7Nine
                                          • Jul 2020
                                          • 15
                                          #40
                                          I've replaced the Usercred section with a clean one. This should work.
                                          Edit: peste beat me to it.
                                            HP EliteBook Folio 1040 G3 Notebook 1040 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook Folio 1040 G3 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G3 boardview and 1040 G3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP...
                                            09-06-2024, 06:06 AM
                                            HP EliteBook Folio 1040 G2 Notebook 1040 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook Folio 1040 G2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G2 boardview and 1040 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP...
                                            09-06-2024, 05:30 AM
                                            HP EliteBook Folio 1040 G1 Notebook 1040 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook Folio 1040 G1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G1 boardview and 1040 G1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP...
                                            09-06-2024, 05:27 AM
                                            HP EliteBook Folio EliteBook Folio G1 Notebook Specification for Upgrade or Repair
                                            This specification for the HP EliteBook Folio EliteBook Folio G1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook Folio G1 boardview and EliteBook Folio G1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 06:34 AM
