Dell Precision 7510 7710
  • LBTT1121
    • Nov 2024
    • 739
    • Việt Nam
    #101
    Originally posted by chelsea1155
    please help me fix bios file
    model Precision 7510
    la-c541p
    Bios Build Dell
    • chelsea1155
      • 34
      • vietnam
      #102
      Originally posted by LBTT1121
      Bios Build Dell
      thank you
      • chelsea1155
        • 34
        • vietnam
        #103
        help me fix the bios file is shut down
        la-c541p​
      • prakashbafna
        • Jun 2021
        • 9
        • India
        #104
        Originally posted by ronelex
        Does anyone have solution on this issue? I also have this issue on the unit I am working now.
        I solved it,do you still have problem?
        • emre0634
          • Oct 2021
          • 4
          • Türkiye
          #105
          please, can same cleane ME for my dump. TNX
          reg mode:p53f
          reg type no:p53f001
          seri no;:6GPWNC2
          LA-C541P REV:1.0
          • LBTT1121
            • Nov 2024
            • 739
            • Việt Nam
            #106
            reg mode:p53f
            reg type no:p53f001
            seri no;:6GPWNC2
            LA-C541P REV:1.0
            try and feedback
            • emre0634
              • Oct 2021
              • 4
              • Türkiye
              #107
              try and feedback
              I tried the BIOS, but still couldn't get an image. After 1.5 amps, the device remains at a constant 1 amp. When I don't plug in the external graphics card, the current values ​remain the same. I installed the original BIOS, and the current values ​​remain the same. There is no liquid contact or impact on the motherboard. I applied light heat to the external GPU chip, but the results remained the same. Can you help me find any problems I could address with this motherboard?​
              • LBTT1121
                • Nov 2024
                • 739
                • Việt Nam
                #108
                I tried the BIOS, but still couldn't get an image. After 1.5 amps, the device remains at a constant 1 amp. When I don't plug in the external graphics card, the current values remain the same. I installed the original BIOS, and the current values ​​remain the same. There is no liquid contact or impact on the motherboard. I applied light heat to the external GPU chip, but the results remained the same. Can you help me find any problems I could address with this motherboard?​
                try post 101
                • rddube
                  Aspiring Expert
                  • Jun 2013
                  • 950
                  Got this laptop without the bottom cover so I don't have the service tag number. Bios file seems corrupted because it tries to start, fans spin turns off, turns on again fans spin very fast and it turns off. Attached is the original bios dump and the info I was able to gather from under the battery and the motherboard number.
                  Can anyone help fix this bios?
                  Thank you!
                  • LBTT1121
                    • Nov 2024
                    • 739
                    • Việt Nam
                    #110
                    Thank you!
                    try and feedback
                    • rddube
                      Aspiring Expert
                      • Jun 2013
                      • 950
                      try and feedback
                      Hello LBTT1121, thank you for your reply. Already tried this dump (post 101) and I get no reaction, doesn't read the power button ?? I tried several dumps, but no success. Is my original dump so corrupted it can't be fixed?
                      Any other solutions?
                      Again, many thanks!
                      • Markus1741
                        • Sep 2020
                        • 925
                        • N/A
                        #112
                        Again, many thanks!
                        Hello try this file ....
                        • rddube
                          Aspiring Expert
                          • Jun 2013
                          • 950
                          Unfortunately same behavior, turns on, then off, back on fans spin full blast, then shuts down - with an added twist after this ligths flash 2 amber 1 white for a few rounds, then starts up and does this in a loop.
                          • LBTT1121
                            • Nov 2024
                            • 739
                            • Việt Nam
                            #114
                            2 amber 1 white ---> check hardware
                            • mediadoctor
                              • Oct 2020
                              • 34
                              • UA
                              #115
                              i replaced the motherboard on my 7510, and now I have a different service tag. I have specific software that doesn’t work with the new service tag.
                              Is there any way to help me change it?
                              • LBTT1121
                                • Nov 2024
                                • 739
                                • Việt Nam
                                #116
                                attach bios
                                • mediadoctor
                                  • Oct 2020
                                  • 34
                                  • UA
                                  #117
                                  attach bios
                                  I need this ST: 8KT3HC2
                                  • wandy
                                    • Oct 2018
                                    • 10
                                    • tangerang
                                    #118
                                    Originally posted by Marko2711
                                    Re: Dell Precision 7510
                                    It works but now it doesn't see M2. SSD disk
                                    same with my situation ,any solution?
                                    • LBTT1121
                                      • Nov 2024
                                      • 739
                                      • Việt Nam
                                      #119
                                      attach bios dump
                                      • wandy
                                        • Oct 2018
                                        • 10
                                        • tangerang
                                        #120
                                        attach bios dump
                                        Precision 7510
                                        la-c541p backup DUMP original
                                          DELL Precision 7710 Mobile workstation 7000 Specification for Upgrade or Repair
                                          This specification for the DELL Precision 7710 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7710 boardview and 7710 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Precision...
                                          09-06-2024, 12:25 PM
                                          DELL Precision T3630 Precision 3000 E-2174G Specification for Upgrade or Repair
                                          This specification for the DELL Precision T3630 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision T3630 boardview and Precision T3630 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-12-2024, 03:44 PM
                                          DELL Precision 3630 Precision E-2274G Specification for Upgrade or Repair
                                          This specification for the DELL Precision 3630 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 3630 boardview and Precision 3630 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          DELL Precision T3620 Precision i7-6700 Specification for Upgrade or Repair
                                          This specification for the DELL Precision T3620 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision T3620 boardview and Precision T3620 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          DELL Precision 3431 Precision 3000 E-2224 Specification for Upgrade or Repair
                                          This specification for the DELL Precision 3431 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 3431 boardview and Precision 3431 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
