Asus a456u bios dump NEEDED
  • faz5349
    • Sep 2017
    • 3
    • malaysia
    Asus A456U -bios dump
    PCB : X456UQK REV 2.0
  • peste
    • Dec 2016
    • 12872
    • ROMANIA
    Re: Asus a456u bios dump NEEDED
    try..
    • faz5349
      • Sep 2017
      • 3
      • malaysia
      motherboard does power up after flashing above bios,but i think its another problem that cause blank screen when power on,thanks anyway
      • peste
        • Dec 2016
        • 12872
        • ROMANIA
        try it too
        • HarryPK
          • Mar 2014
          • 210
          • barabai
          • mangga dua
            • Dec 2023
            • 6
            • INDONESIA
            thanks
            • nopek
              • Sep 2023
              • 9
              • indonesia
              try it too
              ok but late display
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • TacticalFahrrad
                [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                by TacticalFahrrad
                I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                06-30-2025, 04:09 AM
              • vinaypundith
                Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                by vinaypundith
                I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                So, I'm looking for a BIOS dump for this machine - a 16MB one....
                08-03-2024, 12:32 PM
