Acer Spin 5 - SP513-52 Bios unlock code / bin request
  • MrLucifer
    • Oct 2019
    • 10
    • Italia
    Hello there, time ago I set a password on my Acer Spin 5 (SP513-52N) bios, but after I updated it the password is no longer working so I can't access it anymore.
    To make things worse, I tried resetting it by detaching the CMOS battery as well as the Li-Ion battery with no luck: my settings were reset, but password is still there!
    Acer supports wants me to send in the machine and have it repaired out of warranty, even if it's their fault, so this option is not viable: i'm not going to give em a single penny.
    Therefore, i'm left with two options:
    - Differently from older insyde devices, this bios has a 10-digit PasswordKey code, which in my case it's 1288915250. I'd need an unlock key for this code.
    - Use my CH341A programmer to flash the bios clean, chip should be a MX25L6473E. I'm not sure this would work, but i'd need a .bin file to test this out.
    I'd really appreciate any help on the matter, either in the form of experience, suggestion, unlock key or bin file :P
    Thank you for your time and help!
  • peste
    • 13924
    • ROMANIA
    Re: Acer Spin 5 - SP513-52 Bios unlock code / bin request
    save the original and try this one ..
    • MrLucifer
      • Oct 2019
      • 10
      • Italia
      Thanks, i will try that as soon as I get home, as I don't have the programmer with me rn.
      Meanwhile, I tried re-flashing the v1.11 bios (don't want to update..yet) by copying over the flasher's folder from <MyUser>/AppData/Local/Temp and fiddling with platform.ini, tried setting it to override the password but no luck, only result is that the unlock password key changed, now it's 1491353215.
      • MrLucifer
        • Oct 2019
        • 10
        • Italia
        That does not seem to be working: keyboard backlight turns on, but no fan, although if i try plugging in the charger it beeps.
        Is this a modified bios? Imma try the bin extracted from 1.11 .fd now
        UPDATE:
        The 1.11 extracted bios worked, and password is reset, although main page shows wrong information about the system. PIC
        Any idea about how to fix that?
        If it could be of help for anyone else, I attached the extractor used for extracting the .fd
          • 22279
          UPDATE:
          Did you backup your old bios,it will have the DMI info, the serial and UUID .
          • MrLucifer
            • Oct 2019
            • 10
            • Italia
            Of course I did, do you know how to port it to the new one?
              • 22279
              Yes.Post your bios backup.
              • MrLucifer
                • Oct 2019
                • 10
                • Italia
                Here it is
                • MrLucifer
                  • Oct 2019
                  • 10
                  • Italia
                  Hi there, I posted everything requested and no updates as of yet.
                  In the meantime another problem arose: Windows 10 no longer recognizes my laptop as a laptop, so no battery gauge indicator and laptop functionalities, which came to be a big issue.
                  EDIT: I flashed back the backup and used the unlocker by let-def, which worked. Issue solved
                  • peste
                    • 13924
                    • ROMANIA
                    Any help in moving the DMI data from the original password-locked bios backup (which I posted in message #8) to the "clean" one?
                    try this .. update from Acer site + DMI information from post # 8 ..
                    • zenius
                      by zenius
                      12-08-2024, 06:13 AM
                    • kowal0090
                      Acer Chromebook Plus Spin 514 - Bios need
                      by kowal0090
                      I tried to upload the BIOS (for install windows) to an Acer Chromebook Plus Spin 514 laptop but unfortunately it did not work, and the backup done with a script did not work.
                      Does anyone perhaps have access to the bios?
                      Is a chance to fix this dump?
                      "stock-firmware-DOCHI-20240419" was created by script before try to modify bios.
                      "MrChromebox.BIN" its a dump from SPI after brick.
                      Spec:
                      CPE-594-1N-TCO-52GR
                      SNID: 50310924376
                      Board: DA0ZCQMBAD0 Rev D , model: ZCQ...
                      04-29-2025, 04:19 AM
                    • EbrahimSiami
                      Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                      by EbrahimSiami
                      I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                      **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                      **What I have tried so far:**
                      1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                      07-02-2025, 02:31 PM
                    • Wg188
                      ACER Veriton Z4660G AIO bios help
                      by Wg188
                      I have an Acer veriton Z4660G all in one pc,
                      Model: Z4660G-I5850H1 (VZ4660G_W)
                      Need bios dump and schematic would save my life !
                      to make a long story short I bought this all in one used
                      with a broken lcd, with the objective of making a custom desktop out of it
                      ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
                      06-17-2023, 02:20 PM
                    • peterhui
                      BIOS PASSWORD UNLOCK NEEDED (ACER TRAVELMATE P645-S)
                      by peterhui
                      Model : TMP645-S-504E
                      S/N: NXVAFEG0085490148C3400
                      like to unlock the bios password:
                      tried biosbugs keygen not working.
                      tried bios-pw unlock key still no luck.
                      Here is the two bios file : (Bios + EC)
                      Will definitely summit donation after that issue solve.
                      Thanks for your help and support
                      I really appreciated....
                      08-12-2024, 09:40 AM
