Thank you again for your assistance and for providing the previous Response Code.
This time, my device behaved differently than before. After I entered the code, it didn’t display any message or error sound. Instead, it simply rebooted on its own — but unfortunately, the BIOS password was still there afterward.
I'm not sure what might have caused this, so if you have any insights into what this behavior could mean, I would truly appreciate your advice.
If possible, I would be very grateful if you could kindly provide a new Response Code so I can try again.
Model: Toshiba PORTEGE WT20-C
PC Serial No. = YH099093H
Challenge Code = AD7FH-CY7CQ-FAWG3-R1F45-GT0QB
Response Code =
Thank you so much for your continued help and support.
Toshiba password
What's the point of publishing codes that don't work...you give people false hope
You provided more than 10 codes and none of them work.
Your generator makes incorrect codes.Last edited by evserv; 08-03-2025, 03:58 AM.Leave a comment:
Generated Response CodeThank you once again for providing the previous Response Code.
I carefully entered it and verified everything to ensure there were no mistakes. Unfortunately, the code did not work. As there is only one attempt allowed, I was unable to retry.
If it’s not too much trouble, may I kindly ask you to generate and provide a new Response Code? I would greatly appreciate your help.
Challenge Code = L65K2-JRMPJ-EQFQA-BRXHR-912PC
Response Code =
Thank you very much for your time and understanding.
Serial Number: YH099093H
Challenge Code: L65K2-JRMPJ-EQFQA-BRXHR-912PC
Response Code: EEA98-66EBC-E2242-405D7-AB7DFLeave a comment:
Response Code = FE421-LBD4U-MYEFD-81QG3-RWQERThank you once again for providing the previous Response Code.
Response Code =
Thank you very much for your time and understanding.Leave a comment:
Response Code =
Thank you very much for providing the Response Code.
I carefully entered it on my device and made sure everything was correct. I double-checked the input and can confirm that I didn’t make any mistakes. Unfortunately, the code did not work, and since there is only one attempt allowed, I was not able to try again.
I would be truly grateful if you could assist me further or possibly provide a new code.
Thank you again for your time and support.Leave a comment:
try this :
I’d like to kindly inform you that my device has remained powered on and responsive since July 29, 2025, at 12:40 PM, and it has not frozen or shut down during this time.
Unfortunately, I was unable to enter the previous Response Code in time, and I sincerely apologize for any inconvenience this may have caused.
Would it be possible to kindly provide a new Response Code? I would greatly appreciate your support.
Thank you in advance for your understanding and assistance.
Challenge Code: 8H0VB-4992B-XPBH9-J1YVY-TXVPK
Response Code: 6S222-AT7XA-QPKQX-LQPQG-JQWVMLeave a comment:
I’d like to kindly inform you that my device has remained powered on and responsive since July 29, 2025, at 12:40 PM, and it has not frozen or shut down during this time.Hello again.
I'm very sorry for the inconvenience, but unfortunately I couldn't enter the response code in time.
My Toshiba tablet-laptop suddenly overheated and froze on the password screen. I was unable to type anything, as it became completely unresponsive.
I've since carefully disassembled the device to prevent this from happening again and it's now running much more stable.
I would truly appreciate it if someone could help me by generating a new response code based on the following challenge:
Challenge Code = 8H0VB-4992B-XPBH9-J1YVY-TXVPK
Response Code =
Thank you so much in advance for your time and patience — I greatly appreciate this amazing community's support!
Thank you in advance for your understanding and assistance.Leave a comment:
Please I need help for my Toshiba that has password
Toshiba Tecra a11
Serial number: 9A163205H
Challenge code: RJAW0-N2YEB-7EJCN-EF11N-VRV96
RESPONSE code:???????
Thank you
Generated Response CodeOriginally posted by ALEXV90....
Serial Number: 9A163205H
Challenge Code: WEW5K-Q2F2X-1JW07-B0EGE-ECCNL
Response Code: 03COH-050LK-00647-0C3EH-03W0JLeave a comment:
se apagó la pc y cambio
ahora es
serial 9A163205H
challenge code
te agradecería la ayudaThe PC turned off and changed
it's now
serial 9A163205H
challenge code
I'd appreciate the helpLeave a comment:
Generated Response CodeOriginally posted by ALEXV90Good morning, could you help me with a Toshiba serial number?
Serial number 9A163205H
Challenge code
CY2VV-8H19U-8Y4LK-6VPVH-CJYGE
Response code: ??????
I would greatly appreciate your help. Thank you.
Challenge Code: CY2VV-8H19U-8Y4LK-6VPVH-CJYGE
Response Code: 07AUF-0K3S7-0H2YH-059LT-01N2LLeave a comment:
I wanted to sincerely thank you for taking the time to help me with the response code — I truly appreciate your support and generosity.
Unfortunately, I must apologize, as I was unable to enter the code in time. My Toshiba device unexpectedly froze on the password screen and became completely unresponsive. Sadly, by the time I was able to troubleshoot the issue, the code had already expired.
I’ve since opened the device and addressed the overheating problem, so this shouldn’t happen again.
I’m really sorry for any inconvenience this may have caused, and I’m very grateful for your kindness and patience. Your willingness to help means a lot.
Hello again.
Response Code =
Thank you so much in advance for your time and patience — I greatly appreciate this amazing community's support!Leave a comment:
Serial Number: YH099093HSorry to bother again, but the key I received didn't work. I'd really appreciate if someone could try generating another one.
Challenge Code = WCM71-9Q6Q3-Q9E22-KJ441-68289
Response Code =
Any help would be greatly appreciated!
Thank you in advance.
Challenge Code: WCM71-9Q6Q3-Q9E22-KJ441-68289
Response Code: 4RJJG-L3BRI-CIO5I-MH6P4-JNI5KLeave a comment:
Response Code =
Thank you in advance.Leave a comment:
This specification for the Toshiba Tecra Tecra X40-E-114 Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Tecra X40-E-114 boardview and Tecra X40-E-114 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...09-06-2024, 06:42 AM
This specification for the Toshiba Tecra C50-E-0C2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C50-E-0C2 boardview and C50-E-0C2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 03:21 PM
This specification for the Toshiba Tecra C50-E-1VU Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C50-E-1VU boardview and C50-E-1VU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 03:21 PM
This specification for the Toshiba Tecra C50-E-1VM Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C50-E-1VM boardview and C50-E-1VM schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 03:21 PM
This specification for the Toshiba Tecra C40-D-00D Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C40-D-00D boardview and C40-D-00D schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 11:50 AM
- Loading...
