Microsoft Surface Pro 3 UEFI password
  • Yuranc8
    • Moçambique
    #321
    Re: Microsoft Surface Pro 3 UEFI password
    Hello can You help me password thanks
    • Ghamidi
      • Mar 2020
      • 303
      • France
      #322
      try...
      Password : dan3788
      • mzkstf
        • Jun 2022
        • romania
        #323
        Microsoft Surface Pro 3 bios password pls help
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          #324
          Password ----> 10101
          Become a Badcaps supporter
          Thanks to all supporters.
          • mzkstf
            • Jun 2022
            • romania
            #325
            • beeson76
              • Jul 2022
              Im sorry guys but this isnt making sense. Can someone tell me what file I need to dump my bios for my Surface Pro 3. I downloaded from several different links and names are not matching up with files I need to use.
              Please Help
              I have tried to use the Univeral Backup Toolkit, and I keep getting a "Cannot Identify the Bios" error. I am running it as Administrator.
              • hoaca388
                Badcaps
                • Jan 2022
                • 11773
                #327
                Please Help
                That's " Programmer " . It's a hardware device.
                • madasahatter
                  • Jul 2022
                  • 7
                  • GB
                  #328
                  Hi, was hoping someone could help me retrive password for my Surface pro 3
                  here is the dump file created with fptw64.exe v9.5 r6
                  Thanks in advance
                  • AAAC
                    • Jan 2020
                    • 458
                    • Mexico
                    #329
                    @madasahatter
                    Password is Case-SensitiVE.
                    password: CMWD3v1c3
                    C - CHARLIE ( UPPERCASE )
                    M - MIKE ( UPPERCASE )
                    W - WHISKY ( UPPERCASE )
                    D - DELTA ( UPPERCASE )
                    3 - 3 ( digit )
                    v - victor ( lowercase )
                    1 - 1 ( digit )
                    c - charlie ( lowercase )
                    3 - 3 ( digit )
                    • madasahatter
                      • Jul 2022
                      • 7
                      • GB
                      #330
                      Man that was quick, and works QUDOS... what did you read it with ?
                      thanks
                      • AAAC
                        • Jan 2020
                        • 458
                        • Mexico
                        #331
                        @madasahatter
                        I use UEFITool NE Version (A59), then I do a search for "AMITSESetup" string (untick UNICODE option) to locate the AMITSESetup UEFI variable, in my case is the second result:
                        'ASCII text "AMITSESetup" in NVRAM/AmiTseSetupGuid at header-offset 0Bh'
                        if you double-click it will go to the variable, but on the third column says "LINK", so right-click and select "Go to data", it may take a few seconds and take you to the actual variable data, which in this case is (right-click, then "body hex view"):
                        1893FB2646BA284DF4E054744C07BB9A002E8EC1E95444E89F7BFA0E55A2B0350BC9665CC1EF1C83
                        (copy it and remove the space it's being added to the hex-string)
                        Then you can use the decoder on this hex-string, there's a XLS file on this or other thread.
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11773
                          #332
                          Originally posted by AAAC
                          @madasahatter
                          You are pro.
                          • madasahatter
                            • Jul 2022
                            • 7
                            • GB
                            #333
                            @madasahatter
                            Thanks again for the help.
                            I managed to find the string but when entered into the xls file it doesent seem to work. even tried the string you sent "1893FB2646BA284DF4E054744C07BB9A002E8EC1E95444E89F 7BFA0E55A2B0350BC9665CC1EF1C83" with the same results. I know this is already solved but was just curious how to do it.
                            Any suggestions ?
                            thanks
                            • AAAC
                              • Jan 2020
                              • 458
                              • Mexico
                              #334
                              Did you remove the “ “ empty space that is being added to the hex-string? Copy the hex-string to a text file, remove the “ “ empty space and then copy it to the XLS Excel file.
                              I haven’t tried the XLS file, maybe is giving you Hex output that you may need to convert from Hex to ASCII.
                              • madasahatter
                                • Jul 2022
                                • 7
                                • GB
                                #335
                                yes no spaces or quotes, using surface pro 3 decrypter by mxp
                                thanks
                                • madasahatter
                                  • Jul 2022
                                  • 7
                                  • GB
                                  #336
                                  thanks
                                  just keeps comming back with #NAME?
                                  • madasahatter
                                    • Jul 2022
                                    • 7
                                    • GB
                                    #337
                                    Ok I figured it out. The version of MS Excel was too old. Using Libre Office to open the xls file now works.
                                    thanks
                                    • AAAC
                                      • Jan 2020
                                      • 458
                                      • Mexico
                                      #338
                                      Ok, that must have been the reason. I had downloaded the XLS file found in post #139, was trying to figure out what the problem may be, the sheet is password protected, so I used the creator nickname to unprotect it, that’s as far as I got. I’m also using an old version of MS Excel, so thanks to you too.
                                      There’s a Python script, I have downloaded them, but haven’t tested it either.
                                      • mp3boy
                                        • Mar 2016
                                        • 48
                                        Please could someone extract the password from this dump?
                                        I got as far as pasting the hex string into the decoder but the formatting is broken in LibreOffice and there's a picture over the top of the output field.
                                        Code:
                                        00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 17 93 F2 26 52 BA 22 4D F6 E0 1B 74 4A 07 EB 9A 33 2E 8E C1 E9 54 44 E8 9F 7B FA 0E 55 A2 B0 35 0B C9 66 5C C1 EF 1C 83
                                        • miansh621
                                          Banned
                                          • May 2022
                                          • 133
                                          • pakistan
                                          #340
                                          LDCN1973
