HP Pavilion Laptop 14-ce0820nd DA0G7AMB6D0 Rev.D(G7A-2G)
  • ado1125
    • Feb 2013
    • 6
    • belgia
    Need bios.
  • mahmoodjavan
    Banned
    • Mar 2018
    • 584
    • iran
    Re: HP Pavilion Laptop 14-ce0820nd DA0G7AMB6D0 Rev.D(G7A-2G)
    Originally posted by ado1125
    Need bios.
    plz test
    • ado1125
      • Feb 2013
      • 6
      • belgia
      Thank you, mahmoodjavan, there is no voltage on the coil marked in the picture, I wanted to make sure that it would be the same on another bios. I have the same on your bios.
        • 22156
        If your CPU is a i5-8250U ,then try this HP virgin bios with clean ME. If this bios doesn`t work your problem is elsewhere.
        • ado1125
          • Feb 2013
          • 6
          • belgia
          Thank you SMDFlea, is the same on your bios. PWM_AUXI oscillations is missing on the 22 pin of the RT3602AE circuit, what should I check?
            • 22156
            Start a new thread in the main laptop forum,and describe the problem.One of the members will help you. We are tying to keep the bios requests seperate to repairs. Thanks
            • CeeEee4
              • 43
              • EU
              did you solve problem with pavilion 14-ce?
              i have same laptop that does not see SSD. and white led blink 5 times on DC socket.?
              • rasher
                • Dec 2019
                • philipines
                file error
                • mPulse
                  • Jun 2015
                  • Ireland
                  Any solution to the no voltage on that line? I searched but can't find a follow up to it
                  • laptopbariavungtau
                    • Jan 2019
                    • 3
                    • Vietnam
                    i have same laptop not display on, and white led blink 3 times on capslock key, need help.
                    • Pabloomi
                      • Aug 2020
                      So I wanted to share the "solution" that I found ... Basically the RAM slot is defective. In fact, if you try to lightly hold the RAM bank towards the motherboard, you will see that the notebook starts ... Clearly the perfect solution would be to resolder the slot
                      • Anselme
                        • Jul 2016
                        • 21
                        • Ghana
                        Thanks for your suggestion, you were right, i tried it and it worked for me 100%.
                        Anstech gh.
                        • omsonas
                          • Jan 2016
                          • Lithuania
                          Hello, did you find a problem? i have the same failure
                          • prolixo
                            • Jan 2009
                            • 9
                            Hi.
                            Me too...
                            • teckhing79
                              • Nov 2020
                              • 18
                              • malaysia
                              anyone have this EC bios file?
                              • Mhvv
                                • Oct 2020
                                • 4
                                • Việt nam
                                OK.thank!!!!!!!!!
                                • luckyfahad79
                                  • Oct 2020
                                  • 6
                                  • United Kingdom
                                  Yes fixed .. by soldering the memory card slod.
                                  IF Cpu code is heating up. remove the mosfet and check the gate if shorted to ground. follow gate to the controlling ic and check shortage on the ic. Remove ic and shortage gone from the gate. change controlling ic also check if dual mosfet is shorted . change the mosfet if faulty.
                                  • maltahamed
                                    • Jan 2015
                                    • 4
                                    • nigeria
                                    i have same problem, white led blink 3 times on capslock key . after resolding the RAM slot laptop works fine.
                                    • gonga31
                                      • Oct 2017
                                      • 14
                                      • portugal
                                      Originally posted by pabloomi
                                      so i wanted to share the "solution" that i found ... Basically the ram slot is defective. In fact, if you try to lightly hold the ram bank towards the motherboard, you will see that the notebook starts ... Clearly the perfect solution would be to resolder the slot
                                      thanks man
                                      • Zadiq
                                        • Mar 2020
                                        • 7
                                        • Nigeria
                                        Thanks for the tip work perfect after soldering the ram slot
                                          HP Pavilion Pavilion Laptop 15-eh2501sa Notebook 15 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Laptop 15-eh2501sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 15-eh2501sa boardview and Pavilion Laptop 15-eh2501sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-07-2024, 05:50 AM
                                          HP Pavilion Pavilion Laptop 14-dv0631sa Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Laptop 14-dv0631sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv0631sa boardview and Pavilion Laptop 14-dv0631sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          HP Pavilion Pavilion Laptop 14-dv0632sa Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Laptop 14-dv0632sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv0632sa boardview and Pavilion Laptop 14-dv0632sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          HP Pavilion Pavilion Laptop 14-dv2514sa Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Laptop 14-dv2514sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv2514sa boardview and Pavilion Laptop 14-dv2514sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          HP Pavilion Pavilion Laptop 14-dv2513sa Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Laptop 14-dv2513sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv2513sa boardview and Pavilion Laptop 14-dv2513sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
