I need a bios HP Mini 110-1169TU
  • angel-boy
    • 550
    • Romania
    i need bios for this board please.
    i press f10 to enter bios and stuck in entering bios setup
  • rookieme
    • Oct 2014
    • 403
    • Greece
    Re: I need a schematic HP Mini 110-1169TU
    Check to see first if there is any sd memory or sd memory adapter at the card reader.
    Can it boot from usb to dos?
    I think I have a dos version bios update.
    • rookieme
      • Oct 2014
      • 403
      • Greece
      Ok, here is the dos version of the bios update and to be sure a bios dump also.
      • angel-boy
        • 550
        • Romania
        i flash the bios but same problem
        enter the bios and stuck.... with or without hdd
        • bluestar77
          • Apr 2015
          • 57
          • sudan
          Remove the Webcam cable from the top of the lcd panal
          • rafik_40150
            • Dec 2016
            • 22
            • algeria
            hello does your files compatible with ( compaq mini 110c-1130ef )
            model of motherboard
            6050A2290801-MB-A03
            -001
            HSTNN-1700
            • lebana
              • Jan 2015
              • 81
              • sudy
              thank u
              • jacospama
                • Aug 2019
                • 245
                • Ghana
                I need a bios firmware of 6050A2290801-MB-A03-001
                can anyone help get this firmware
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                • cr4zychriss
                  by cr4zychriss
                  • Rebrand: PC Specialist
                  11-14-2025, 04:04 PM
                • pirati
                  by pirati
                  10-27-2025, 04:20 PM
                • limann
                  Bios HP EliteDesk 800 G3 Mini 65W
                  by limann
                  I need Bios for HP EliteDesk 800 G3 Mini 65W, please support
                  *Serial No : 8CG7427T48
                  *MB Info : Scorpius MB Rev A
                  16515-1
                  348.06N35.0011
                  *Proplem : No power on - 3 flashing red & 5 white, speaker : beep bep beep
                  Thank you...
                  10-02-2025, 07:53 PM
                • Datahoarder
                  HP Elitedesk 800 G2 DM / Mini -> Can't get BIOS flashed, tried multiple. Update Brick
                  by Datahoarder
                  HP EliteDesk 800 G2 MINI/DM (1L PC)
                  I have 40 of these units. All of which i tried to update bios with HP's utility got bricked. All of them were bios password locked, i used the jumper thing to reset it. Couple updated bios, one of which worked fine for _ONE_ boot. Second is now mixed with rest, i don't know which it is specifically so have not retested it.
                  All had some MESpilock failed errors on (my) first boot of the unit.
                  Photo: https://cdn.discordapp.com/attachmen...018_220853.jpg
                  10-19-2023, 09:33 AM
