Re: Lenovo IdeaPad 330S-15ARR - 330S_ARR_V06
The post #29 says:
enter the original bios of the laptop
But as i told you I don't have it. I have also managed to get a donor BIOS from another machine and I know the process explained in that post(already done by me on macbook BIOSes), the problem is that I don't know how to replace the infos I have into the block of the update extracted bios.
You don't need any tool, just a simple hex editor.Leave a comment:
Yes, for sure I learned the lesson.
I tried to edit the DMI info using "DMI EDITOR" both under Windows and as EFI Shell, but I can't write the parameters.
Is there any other tool that works?
I also tried LVAR but the only version I found does not work.Leave a comment:
I hope you learned a lesson from your mistake, next time be sure you have a backup first, and then play with the bios.
Now your option is to take a donor DMI block and edit the information from the stickers on your machine, including the Windows key.Leave a comment:
Just read the whole thread, especially post #29.
Hi, i got a broken 330s and flashed a clean BIOS without backing up the corrupted one. Now i have a working laptop but without Serial number and M/B model in BIOS. Is it possible to manually add them in the BIOS file and reactivate the Win10 License? I read on another forum that this can be done using LVAS64 app but the only one I found is too old and does not work with my machines. Any help will be appreciated. Thank you
Hi, i got a broken 330s and flashed a clean BIOS without backing up the corrupted one. Now i have a working laptop but without Serial number and M/B model in BIOS. Is it possible to manually add them in the BIOS file and reactivate the Win10 License? I read on another forum that this can be done using LVAS64 app but the only one I found is too old and does not work with my machines. Any help will be appreciated. Thank youLeave a comment:
Thanks, with explanations in this thread I was able to restore two 330s-15arr !Leave a comment:
Thanks, fully functional biosLeave a comment:
Thanks aprilbg087!
Tried it out works well.Leave a comment:
you need the HxD program (you can find it for free on the internet), enter the original bios of the laptop and the bios extracted from the update on the site in the program, click on the original bios, top left "search", "find", in the top box "lenovo "(search for lenovo), in the box below it remains (text-string) and check 'all' and press ok ... The DMI information is in the region 1EE000 - 1EE22F, so the length of 230, select this region by left click on mouse and going down, then right click and copy. Now click on the bios extracted from the update and search for the same region in this bios (go directly to 1EE000), select the same region (1EE000 - 1EE22F), right click on the mouse and (paste insert). ready with DMI information. For (key windows) the same procedure but the region is 330250 - 330280 so length 40 ..
I hope this helps ..
I am sorry for the delay in replying.
Thank you very much for your help the other day.
I have a couple of questions about what you taught me.
Does the location and length of that DMI information area vary depending on the manufacturer, brand and model?
Are the ProductName, MTM, lenovo SN, and UUID always in the DMI information?
In this case, you said to search for "lenovo" to identify the area of DMI information, but how do you identify the area of DMI information if the make, model, or model number is different?
Do I need to rewrite anything other than the DMI information?
Please let me know.Leave a comment:
Using the information from you post, the BIOS from post #2, and a dump of my corrupted bios; I was able to fix my Lenov 330S-15ARR. My laptop's screen would initially no longer turn on. Googling revealed that this was likely due to corrupted BIOS. I used a CH341A programmer with a 1.8V adapter board and the AsProgrammer software to write the rebuilt BIOS back to my laptop.Leave a comment:
Thank you very much.
Your work is perfect.
The BIOS is up and running and I was able to activate the OS.
I would like to learn more about BIOS information migration.
I would like to be able to do the migration myself.
I would like to be able to do it myself.
If it's too difficult to teach, can you tell me a site or thread that would be helpful?
This is because there are not many sites in Japanese that can help me.
I hope this helps ..Leave a comment:
This is because there are not many sites in Japanese that can help me.Leave a comment:
Thank you for your reply. Thank you again for your help.
I have confirmed that ProductName and other information has been transferred to the file you provided.
I flashed the file you gave me to the BIOS.
However, the screen remained black and the BIOS did not start up again.
Also, the size of the backup file I attached was 8388608, while the file you gave me was 8388048.
Is it possible that I should be able to just FALSH this?
Please let me know.Attached FilesLeave a comment:
try..next time post the backup of the bios and the pictures here on the site not on another site ..Attached FilesLast edited by SMDFlea; 09-02-2021, 01:27 AM.Leave a comment:
I have a Lenovo ideapad 330S-15ARR (CPU:ADM ryzen 5 2500u).
It powers on and the CPU fan works.
However, the screen remains black and the BIOS won't start up.
The BIOS chip says winbond 25Q64FWSIQ 1821.
I obtained the following BIN file from the Internet, which was created from LENOVO's BIOS update EXE file.
I FLASH'd this BIN file into the BIOS using CH341A and AsProgrammer.
https://drive.google.com/file/d/154O...ew?usp=sharing
The BIOS is now up and running.
However, as shown in the attached image, the ProductName, MTM, LENOVO SN, and UUID became INVALID.
https://drive.google.com/file/d/1erH...ew?usp=sharing
Perhaps because the UUID has changed, I cannot activate the reinstalled Windows 10.
The BIOS backup before FALSH is in the following file.
https://drive.google.com/file/d/1Ibr...ew?usp=sharing
Other than this backup file, there is nothing else that shows the previous UUID, etc.
I want to migrate the previous ProductName, MTM, LENOVO SN and UUID so that the OS can activate the license.
Can someone please help me?
Thank you very much.Leave a comment:
This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...09-07-2024, 05:20 AM
This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 05:20 AM
This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 05:20 AM
This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 05:00 AM
This specification for the Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 14ITL6 boardview and IdeaPad 3 14ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 05:00 AM
- Loading...
