Lenovo IdeaPad 330S-15ARR - 330S_ARR_V06
I am very new to this I have 330s 15arr 81fb I bought ch341a ...with clamp ...I want to know if I need 1.8v adapter to flash BIOS winbond 1853 25Q64XXX or can I try without the Adapter thanks for the help and sorry for my bad EnglishLeave a comment:
thansk for your help
https://articulo.mercadolibre.com.co...7-afdfe8b6d3aa
that function to me case _?
Hello, I have an Ideapad 330S-15ARR (model: 81FB and factory ID: JVHFC1) it does not give video fans on... I try bios update usb but after fn + r for 5 minutes the charging light turns on and off but it does not give no beep , it does not load...... .bin file, how can I access it so that it can load, please help, thank you
https://www.badcaps.net/forum/troubl...96#post3304796
https://www.badcaps.net/forum/troubl...post3305259Leave a comment:
Hello, I have an Ideapad 330S-15ARR (model: 81FB and factory ID: JVHFC1) it does not give video fans on... I try bios update usb but after fn + r for 5 minutes the charging light turns on and off but it does not give no beep , it does not load...... .bin file, how can I access it so that it can load, please help, thank youLeave a comment:
So I need to :
* Buy a SPI programmer,
* Remove the bios chip from the motherboard, or use the clamp if possible
* Backup the original bios !
* Extract some data from it
* Copy the data on the template bios
* Write the new bios on the chip
* Hope it works
Thanks again
My mother's laptop, a Lenovo Ideapad 330S-15ARR (model name : 81FB and factory ID : JVHFC1) is not starting correctly anymore.
If you press the power button, it powers up, you can hear the disk spining (at least an advantage of these old drives !), but nothing is displayed on the screen or on an external display.
Num Lock key is unresponsive too. I tried the Novo button (little hole on the right), same results
I can only shut it down with holding down the power button for a few seconds
So it looks like a corrupted BIOS like others on this thread...
I read all the posts, but some informations seems missing , so here are some questions please :- I got the "template" BIOS from #27, and I understand that I need to Hex edit some values in this file, but how can i retrieve these values from the corrupted BIOS, which prevents me from starting the computer ?
- If I can't extract the old values from the corrupted BIOS, may I get them from the stickers or from another source ? If so, how ?
- If I get these value and set them in the template BIOS, I don't see how the put the new BIOS on the computer after... unless putting the BIN file on a USB stick can work on a dead computer ? Other solution seems to be linked to a "CH341A" item, which seems to be a chip writing tool. Every person that succesfully repaired their BIOS had this tool before ?
Can the bin file on a USB stick works ?
If I need a CH341A tool, do you have tips for choosing one (this one ? https://www.amazon.fr/TECNOIOT-CH341...dp/B07RKXSMKH/)
Thanks for your help, and sorry if my english is not good
FranckLeave a comment:
5 hours to read an 8MB chip is unusual. I don't use the CH341A so I'm not sure, but when reading/writing the chip, I will remove all power sources (including the CMOS battery) because at this time the power supply to the chip is pin 4 (Gnd) and pin 8 (VCC).Leave a comment:
Which type of CH341A did you buy ?
What is the voltage of your bios chip ?
Which program do you use for CH341A ?
https://www.badcaps.net/forum/troubl...rces-and-tools
Dear community, I have the ideapad 330s-15arr model that turns on, does not give image in any way and the fan sounds a lot, after trying to install a nvme. Most likely the bios is corrupted. I bought a CH341 programmer, but when trying to make a backup of the original bios the software freezes without reading the Bios, try several programs and check the drivers, but I can not read the bios, is my CH341 in bad condition?
I am using windows 11.
greetings
https://www.badcaps.net/forum/troubl...rces-and-toolsLeave a comment:
greetings
The PC is working, so I'll take this opportunity to remind everyone of a basic rule that I had forgotten! If the PC boots into the BIOS, make sure to load the default settings before proceeding further. I had forgotten to do this, and my PC was showing the symptoms I described in my previous post. Hopefully, this can help someone. Furthermore, for serial numbers and keys, I followed the procedure of a contributor in this thread using the HxD software, which is super easy. Thanks to all the contributors of this irreplaceable forumLeave a comment:
With the BIOS provided by danito , the 'LENOVO' logo appears and I can boot from my Ventoy SSD, as you can see in the photo. But as soon as I select an application and press Enter, the computer shuts down instantly. The same thing happens if I boot into Ubuntu: I can select the version, but as soon as the desktop is about to appear, the computer shuts down. It's not just the screen; the entire computer shuts down, with no power consumption. I've tried flashing it several times, but the result is the same. Does anyone have another BIOS to suggest?Leave a comment:
This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 05:20 AM
This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 05:20 AM
This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...09-07-2024, 05:20 AM
This specification for the Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 14ITL6 boardview and IdeaPad 3 14ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 05:00 AM
This specification for the Lenovo IdeaPad IdeaPad 3 15IML05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IML05 boardview and IdeaPad 3 15IML05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 05:00 AM
- Loading...
