Lenovo IdeaPad 330S-15ARR - 330S_ARR_V06
  • peste
    replied
    Originally posted by gusto
    I want to buy a programmer in a local e-shop. In NTB I have this BIOS 25q64fwsig. This BIOS supposedly works at 1.8V. Do I also need a 1.8V adapter for the programmer?
    The eshop shows that the programmer also supports WINBOND W25Q64.
    yes, if the chip works at 1.8v...
  • gusto
    replied
    commented on 's reply
    Yes, thats correct.
  • gusto
    replied
    I have the exact same laptop as the others, Lenovo IdeaPad 330S-15ARR - 330S_ARR_V06.
    I have exactly the same problem as everyone else. I turn on the laptop and see the power led. I can hear the CPU fan, but the screen is black.
    If I understood correctly, I need a CH341A programmer. With the help of the programmer, I have to get the flood bin from the chip.
    I load the flood bin and bin from the manufacturer into the hex editor.
    From the old bin, I copy what is important (uuid, product name, sn, etc.) to the manufacturer's bin.
    I burn this resulting bin into the chip using the programmer.
    Did I write it correctly?​
  • peste
    replied
    Originally posted by israelsyouth
    Hi, my laptop is stuck in the same state. I'm not sure where to find the proper bios firmware and the Lenovo website only seems to offer an .exe file which must be executed while logged into Windows on the device
    you need an SPI programmer..here is a video as an example...https://www.youtube.com/watch?v=DWWigscuQDY
  • israelsyouth
    replied
  • AirbusPc
    replied
    Hello, how are you? I wanted to update the case of my laptop, I removed the chip from the board and I was about to write it but one of its legs fell off, maybe I removed it incorrectly and damaged it... now my hope is to bring the chips from China, which They arrive in 2 months until then I will be able to repair the equipment I do not see any other possibility I will just tell you how it goes later thank you greetings​
  • Sparklingx
    replied
    Originally posted by Sparklingx
    I also have a CH341B* chip. havent used it yet. Did your programmer work as intended?
    and what driver and program are you using can you give me too? I cant make mine work
  • Sparklingx
    replied
    Originally posted by Jose Manriquez
    Hi, thanks for the interest, I checked the device and it comes with the CH341B chip, my bios is W25Q64FW 1.8v (I am using the voltage adapter). I updated the drivers and now the AsProgrammer 2.0.4 program does not freeze, but it is taking a long time to read the memory to make a backup (it will take about 5 hours). How normal is this, should the bios battery be connected or disconnected ?
  • AirbusPc
    replied
    the clip fails....I think the BIOS is damaged I will use a sop8 I must get it I hope that works
  • peste
    replied
    Originally posted by AirbusPc
    Hello, how are you? I update my case, I remove the bios from the board, I have a clamp but when I use the asprogrammer... I have tried several programs, it shows me the memory is zero or empty and when I try to write, it carries out the process as in 4 minutes but when reading again it is at zero... if you know anything I appreciate your help my bios is w25q64fw 1.8v and I use the adapter and clamp thank you very much
    remove the bios chip from the board, with the clip you have errors.. or stick wires between the programmer and the chip..
  • AirbusPc
    replied
  • AirbusPc
    replied
    Originally posted by eric paris
    As you wish,
    clean the pins sometimes the varnish makes poor contact,
    good luck,
    my English is not better,
    google translate helps me​
    AhhaΓ‘hh great
  • eric paris
    replied
    As you wish,
    good luck,
  • AirbusPc
    replied
    I don't know
    I am not professional
    but every time I tried to read an eeprom with the clamp it doesn't work.
    I desolder, I clean the pins and it works on the support​
    i hope not need another BIOS desolder chip AND do it the process again ...thanks AND sorry for muy bad english
  • eric paris
    replied
    I don't know
  • AirbusPc
    replied
    hello,
    desolde the chip it's better
    Hi Eric the software said ... Posible enable protect unlock ... ..
    Need another spi BIOS ?
  • eric paris
    replied
    hello,
  • AirbusPc
    replied
    I don't want to try to remove the integrated one, I use now the as program v 2.10.13 and ch341a led writing works but when I test the laptop it doesn't show anything waiting 4 or 5 minutes after turning on​
  • kalilinux25
    replied
    Hello, I have problems reading the bios with the ch341a, the software version 1.38 and version 1.34 showed me an initial reading of 1 minute, all in ff, that is, white, and then it tells me that the chip detection fails, my version is 81fb and the bios is w25q64fw 1.8v I use the voltage adapter ahhh and I use the clamp I think the grip may fail although I doubt it... I appreciate your help greetings
    you sould try removing the chip , im not a fan of this clips
    Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
    This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
    09-07-2024, 05:20 AM
    Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
    This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
    Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
    This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
    09-07-2024, 05:00 AM
    Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook 3 Specification for Upgrade or Repair
    This specification for the Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 14ITL6 boardview and IdeaPad 3 14ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
