Lenovo IdeaPad 330S-15ARR - 330S_ARR_V06
  • hoaca388
    replied
    Originally posted by 789852
    Good afternoon. Help to restore the Bios
    S/N: YD0660TM
    AMD Ryzen 3 2200U
    4Gb DDR4 RAM
    330S-15ARR Laptop (ideapad) - Type 81FB
  • 789852
    replied
    S/N: YD0660TM
    AMD Ryzen 3 2200U
    4Gb DDR4 RAM
  • tyl85
    replied
    Serial _ PF1KW1XA
    Oh yeah!
  • tyl85
    replied
    Serial _ PF1KW1XA
    Thanks, let's try this babe
  • hoaca388
    replied
    Originally posted by tyl85
    Serial image was disappear
    Serial _ PF1KW1XA
  • tyl85
    replied
    Serial number ?
  • hoaca388
    replied
    Same notebook 330s-15ARR
    I have black screen solid white power button light
    The lcd goes to dark (every pixel on) backlight off, no image
    Thanks in advance
    Serial number ?
  • tyl85
    replied
    Thanks in advance
  • javo
    replied
    Originally posted by aprilbg087
    Re: Lenovo IdeaPad 330S-15ARR - 330S_ARR_V06
    hi every one
    i had thesame Lenovo IdeaPad 330S-15ARR
    it was no power
    found out it has short on main power rail
    ive tried to find the schematic for the board but failed.
    so i tried to check what is heating up,, found the mosfet frying itself,,
    ive removed the mosfet and injected 19v to the source( not sure yet if what type it is)
    ive done this because there are so much short caps around that area,
    then I found a bad cap very far from where i expected,
    its a filter capacitor,
    when removed, finaly i had charging light but no display, i suspected that i may had a currupted bios
    I did used the posted bios from this thread but didnt work, i looked for another bios chip that is work for 1.8v then I rewrite my old bios file, the the thing came back to life
    note: the mosfet is q5901
    the bad cap has no label, i can send a photo
    I will upload my bios file for the future errors related on bios. this is working bios file
    Thank you very much.It worked for me.
  • gusto
    replied
    I didn't say you were wrong.
    I can't tell if it would work with
    Code:
    00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    but with
    Code:
    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    it definitely works​
    Sorry, I'm not an expert, that's why I'm asking.
  • volinakis
    replied
    Originally posted by gusto
    After some time I came back to it. I did
    1. cut the beginning of the file from 0 to 0000317 (792 bytes) see
    2. cut the end of the file, everything from offset 0080000 to the end 008881D0 (557528 bytes) see
    3. I replaced DMI offset 001EE000 - 001EE220 (560 bytes) see
    Now the file has the correct size 8388608 bytes, but the md5sum does not match your file
    I searched for the problem and compared the files.
    Code:
    BIOS.my BIOS.volinakis differ: byte 11588379, line 126499
    see offset 01EE220
    my
    Code:
    your
    Code:
    There is only a difference between 00 and FF. Either I am wrong or you are.
    for sure i am wrong, that's why "I uploaded the one you gave me to the bios. I started NTB and it works great." ...
  • gusto
    replied
    Originally posted by volinakis
    I don't even know where to start ... read bios guides of this forum, you don't even read what I wrote ...
    my bios start with hex 0100 003e and you cut from 00ee 606c - 48 more bytes ...
    Code:
    see offset 01EE220
    my
    Code:
    your
    Code:
  • gusto
    replied
    Try to insert the clip several times and read again. As I already wrote, I managed to make a clip after 5-6 attempts. If you don't succeed, de-solder the chip with hot air and use an adapter.
    I ordered this and there are more options than flashing the bios
    BTW, I'm not an expert, I'm just a consumer too, just trying to help.​
  • fmarquis
    replied
    Yes I used a clip and the 1.8v adapter, it tooks maybe 7-8 tries for it to work and read something that wasn't full zeroes.
    The extracted BIOS looked fine, I extracted the bytes required and put them on the template bios found on this thread.
    But now, I can't seem to write it back :/
    Is there a way to know if the chip is not dead ?
    If it is, can I order a new blank chip and try to switch it on the motherboard (won't be easy with my fat fingers :/ )
  • gusto
    replied
    Did you use a clip or another method for writing and reading?
    I managed to clip after 5-6 attempts.​
  • fmarquis
    replied
    Originally posted by fmarquis
    I read all this thread again and again, bought a.programer and managed to read my corrupted chip. I extracted all required data and put them on one of the template Bios from this forum.
    But now I can't seem to write the chip with the new bios. I think that I may have burnt it :/ The software can't detect it.
    What can I do ?
    Buy a new chip and try to replace it on the motherboard ?
    Is there a way to confirm that the current chip is burnt ?
    hello, anyone with an advice on the best next step in my case ?
    Thx
    replied
    Originally posted by mt418
    hepl me disable ram onboard ideapad 330s-15arr
    Try this --> https://www.badcaps.net/forum/troubl...20#post3232220 .If it doesn`t work or you can`t get it to work post your backup and laptop serial number
  • mt418
    replied
  • volinakis
    replied
    I followed post number 29. I found the region 1EE000 - 1EE22F and replaced it.
    However, I do not know if it is enough to replace only this region 1EE000 - 1EE22F (I did not replace the Win key)
    The BIOS you sent me starts in the hex editor like this
    I edited the BIOS in the hex editor as it is written in # 29. However, it is not written anywhere that I have to cut the beginning and end of the file.
    I am also attaching pictures and a file that I edited. It should match the one from volinakis (however md5sum doesn't match).
    I don't have NTB at the moment, so I can't check if mine is correct.
  • gusto
    replied
    Code:
    00000000: 0100 003e ffff ffff ffff ffff ffff ffff ...>............
    00000010: ffff ffff ffff ffff ffff ffff ffff ffff ................
    00000020: ffff ffff ffff ffff ffff ffff ffff ffff ................
    00000030: ffff ffff ffff ffff ffff ffff ffff ffff ................
    00000040: ffff ffff ffff ffff ffff ffff ffff ffff ................
    00000050: ffff ffff ffff ffff ffff ffff ffff ffff ................
    00000060: ffff ffff ffff ffff ffff ffff ffff ffff ................
    00000070: ffff ffff ffff ffff ffff ffff ffff ffff ................
    00000080: ffff ffff ffff ffff ffff ffff ffff ffff ................
    00000090: ffff ffff ffff ffff ffff ffff ffff ffff ................
    000000a0: ffff ffff ffff ffff ffff ffff ffff ffff ................
    000000b0: ffff ffff ffff ffff ffff ffff ffff ffff ................
    000000c0: ffff ffff ffff ffff ffff ffff ffff ffff ................
    000000d0: ffff ffff ffff ffff ffff ffff ffff ffff ................
    000000e0: ffff ffff ffff ffff ffff ffff ffff ffff ................
    000000f0: ffff ffff ffff ffff ffff ffff ffff ff0f ................
    00000100: 5048 434d 0007 0002 0000 0e00 9503 0e00 PHCM............
    00000110: 9003 0000 8000 0000 0000 0000 0000 0000 ................
    00000120: 0000 0000 0000 0000 0000 0000 0000 0000 ................
    00000130: 0000 0000 0000 0000 0000 0000 0000 0000 ................
    00000140: 37f4 50b9 456a 82bf 44cf 1024 35f5 af3b 7.P.Ej..D..$5..;
    00000150: 9397 2339 2ba1 212d 9943 4b36 f4e3 874e ..#9+.!-.CK6...N
    And the one I extracted via innoextract starts like this
    Code:
    00000000: d3af 0be2 1499 4f4f 9537 3129 e090 eb3c ......OO.71)...<
    00000010: 5000 0000 0000 0100 f084 8800 0000 0000 P...............
    00000020: 0000 0000 0000 0000 0000 0000 0000 0000 ................
    00000030: 0000 0000 0000 0000 0000 0000 0000 0000 ................
    00000040: 0000 0000 0000 0000 0000 0000 0000 0000 ................
    00000050: 0000 0000 0000 0000 0000 0000 0000 0000 ................
    00000060: 78e5 8c8c 3d8a 1c4f 9935 8961 85c3 2dd3 x...=..O.5.a..-.
    00000070: a084 8800 0000 0000 5f46 5648 fffe 0400 ........_FVH....
    00000080: 4800 1eec 6000 0002 a084 8800 0100 0000 H...`...........
    00000090: 0000 0000 0000 0000 ffff ffff ffff ffff ................
    000000a0: ffff ffff ffff ffff b6aa f000 6802 00f8 ............h...
    000000b0: d95f e99c 196e e740 9a8f ebad 7f78 e0c5 ._...n.@.....x..
    000000c0: 5002 0000 3c02 0200 e889 9d0f 5992 764f P...<.......Y.vO
    000000d0: a5af 0c89 e340 23df 3802 0000 0002 f10e .....@#.8.......
    000000e0: 1474 71a7 16c6 7749 9420 8447 12a7 35bf .tq...wI. .G..5.
    000000f0: de59 aa51 f2fd a34e bc63 875f b784 2ee9 .Y.Q...N.c._....
    00000100: bd0a bca2 7da0 2f53 f808 c6b0 1b76 d316 ....}./S.....v..
    If I can see correctly, I looked for the PHCM sequence in BIOS.cap and it looks like this (region starts at 00000310):
    Otherwise, I have to delete everything up to line 0300 (including)
    Code:
    00000300: 00ee 606c 16c3 954c a684 cdc7 e703 3311 ..`l...L......3.
    00000310: 07aa 0100 1800 80f8 0100 003e ffff ffff ...........>....
    00000320: ffff ffff ffff ffff ffff ffff ffff ffff ................
    00000330: ffff ffff ffff ffff ffff ffff ffff ffff ................
    00000340: ffff ffff ffff ffff ffff ffff ffff ffff ................
    00000350: ffff ffff ffff ffff ffff ffff ffff ffff ................
    00000360: ffff ffff ffff ffff ffff ffff ffff ffff ................
    00000370: ffff ffff ffff ffff ffff ffff ffff ffff ................
    00000380: ffff ffff ffff ffff ffff ffff ffff ffff ................
    00000390: ffff ffff ffff ffff ffff ffff ffff ffff ................
    000003a0: ffff ffff ffff ffff ffff ffff ffff ffff ................
    000003b0: ffff ffff ffff ffff ffff ffff ffff ffff ................
    000003c0: ffff ffff ffff ffff ffff ffff ffff ffff ................
    000003d0: ffff ffff ffff ffff ffff ffff ffff ffff ................
    000003e0: ffff ffff ffff ffff ffff ffff ffff ffff ................
    000003f0: ffff ffff ffff ffff ffff ffff ffff ffff ................
    00000400: ffff ffff ffff ffff ffff ffff ffff ffff ................
    00000410: ffff ffff ffff ff0f 5048 434d 0007 0002 ........PHCM....
    00000420: 0000 0e00 9503 0e00 9003 0000 8000 0000 ................
    00000430: 0000 0000 0000 0000 0000 0000 0000 0000 ................
    00000440: 0000 0000 0000 0000 0000 0000 0000 0000 ................
    00000450: 0000 0000 0000 0000 37f4 50b9 456a 82bf ........7.P.Ej..
    00000460: 44cf 1024 35f5 af3b 9397 2339 2ba1 212d D..$5..;..#9+.!-
    00000470: 9943 4b36 f4e3 874e 0000 0000 0000 0000 .CK6...N........
    This looks more like the BIOS you uploaded to the forum.
    However, it still does not match 8388608 bytes.
    So I moved to the end of the file (extracted from the original BIOS (NTB)) and saw that at the end offset 007FFFF0. I deleted everything from offset 00800000.
    Code:
    00800000: 83fb 0076 2950 5152 b806 0000 800f a2c1 ...v)PQR........
    00800010: e910 662b 0f66 8b5f 0466 03d9 5a59 580f ..f+.f._.f..ZYX.
    00800020: b7db c1e3 0a3b c376 058b c30f 6ed8 5251 .....;.v....n.RQ
    00800030: 2500 80ff ff0f bdc8 0f84 d100 0000 510f %.............Q.
    00800040: b3c8 5060 b801 0000 000f a2c1 eb18 81e3 ..P`............
    Now the file matches closely with what I extracted from NTB.
    Code:
    -rw-r--r-- 1 gusto gusto 8388608 okt 31 10:42 BIOS_test.cap
    Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
    This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
    09-07-2024, 05:20 AM
    Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
    This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
    Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
    This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
    09-07-2024, 05:00 AM
    Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook 3 Specification for Upgrade or Repair
    This specification for the Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 14ITL6 boardview and IdeaPad 3 14ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
