Lenovo IdeaPad 330S-15ARR - 330S_ARR_V06
  • AirbusPc
    • Aug 2024
    • 13
    • colombia
    #121
    Originally posted by kalilinux25
    25Q64XXX what is the complete full chip so I can see the datasheet and confirm if its a 3.3v or 1.8v chip
    Windbond 1853 25q64fwsiq thanks
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      #122
      you need a 1.8v adapater because its a 1.8v chip
      • AirbusPc
        • Aug 2024
        • 13
        • colombia
        #123
        Thank you very much for your help...I just confirmed it...
        • AirbusPc
          • Aug 2024
          • 13
          • colombia
          #124
          Hello, I have problems reading the bios with the ch341a, the software version 1.38 and version 1.34 showed me an initial reading of 1 minute, all in ff, that is, white, and then it tells me that the chip detection fails, my version is 81fb and the bios is w25q64fw 1.8v I use the voltage adapter ahhh and I use the clamp I think the grip may fail although I doubt it... I appreciate your help greetings
          • kalilinux25
            • Mar 2018
            • 2089
            • ZAMBOANGA SIBUGAY
            #125
            you sould try removing the chip , im not a fan of this clips
            • AirbusPc
              • Aug 2024
              • 13
              • colombia
              #126
              I don't want to try to remove the integrated one, I use now the as program v 2.10.13 and ch341a led writing works but when I test the laptop it doesn't show anything waiting 4 or 5 minutes after turning on​
              • eric paris
                • Apr 2024
                • 12
                • france
                #127
                hello,
                desolde the chip it's better
                • AirbusPc
                  • Aug 2024
                  • 13
                  • colombia
                  #128
                  Originally posted by eric paris
                  hello,
                  Hi Eric the software said ... Posible enable protect unlock ... ..
                  Need another spi BIOS ?
                  • eric paris
                    • Apr 2024
                    • 12
                    • france
                    #129
                    I don't know
                    I am not professional
                    but every time I tried to read an eeprom with the clamp it doesn't work.
                    I desolder, I clean the pins and it works on the support​
                    • AirbusPc
                      • Aug 2024
                      • 13
                      • colombia
                      #130
                      I don't know
                      i hope not need another BIOS desolder chip AND do it the process again ...thanks AND sorry for muy bad english
                      • eric paris
                        • Apr 2024
                        • 12
                        • france
                        #131
                        As you wish,
                        clean the pins sometimes the varnish makes poor contact,
                        good luck,
                        my English is not better,
                        google translate helps me​
                        • AirbusPc
                          • Aug 2024
                          • 13
                          • colombia
                          #132
                          As you wish,
                          good luck,
                          Ahhaáhh great
                          • AirbusPc
                            • Aug 2024
                            • 13
                            • colombia
                            #133
                            Hello, how are you? I update my case, I remove the bios from the board, I have a clamp but when I use the asprogrammer... I have tried several programs, it shows me the memory is zero or empty and when I try to write, it carries out the process as in 4 minutes but when reading again it is at zero... if you know anything I appreciate your help my bios is w25q64fw 1.8v and I use the adapter and clamp thank you very much
                            • peste
                              • 12792
                              • ROMANIA
                              #134
                              remove the bios chip from the board, with the clip you have errors.. or stick wires between the programmer and the chip..
                              • AirbusPc
                                • Aug 2024
                                • 13
                                • colombia
                                #135
                                the clip fails....I think the BIOS is damaged I will use a sop8 I must get it I hope that works
                                • Sparklingx
                                  • Jul 2024
                                  • 41
                                  • Bangladesh
                                  #136
                                  Originally posted by Jose Manriquez
                                  Hi, thanks for the interest, I checked the device and it comes with the CH341B chip, my bios is W25Q64FW 1.8v (I am using the voltage adapter). I updated the drivers and now the AsProgrammer 2.0.4 program does not freeze, but it is taking a long time to read the memory to make a backup (it will take about 5 hours). How normal is this, should the bios battery be connected or disconnected ?
                                  I also have a CH341B* chip. havent used it yet. Did your programmer work as intended?
                                  • Sparklingx
                                    • Jul 2024
                                    • 41
                                    • Bangladesh
                                    #137
                                    and what driver and program are you using can you give me too? I cant make mine work
                                    • AirbusPc
                                      • Aug 2024
                                      • 13
                                      • colombia
                                      #138
                                      Hello, how are you? I wanted to update the case of my laptop, I removed the chip from the board and I was about to write it but one of its legs fell off, maybe I removed it incorrectly and damaged it... now my hope is to bring the chips from China, which They arrive in 2 months until then I will be able to repair the equipment I do not see any other possibility I will just tell you how it goes later thank you greetings​
                                      • israelsyouth
                                        • Oct 2024
                                        • Hamilton
                                        #139
                                        Hi, my laptop is stuck in the same state. I'm not sure where to find the proper bios firmware and the Lenovo website only seems to offer an .exe file which must be executed while logged into Windows on the device
                                        • peste
                                          • 12792
                                          • ROMANIA
                                          #140
                                          you need an SPI programmer..here is a video as an example...https://www.youtube.com/watch?v=DWWigscuQDY
                                            Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                            09-07-2024, 05:20 AM
                                            Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 05:00 AM
                                            Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 14ITL6 boardview and IdeaPad 3 14ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
