Gl502vs-ds71
  • niro750
    • Jul 2019
    • 5
    Gl502vs-ds71
    Hi guys, looking for a bios dump for the above.
    I may be out my depth though, I bought a CH341A programmer to try and fix a totalled bios auto update that went wrong and I have nothing left of my old bios.
    I've tried several gl502 bios dumps with no joy at all. As I understand it, I may not be able to fix this because I am missing data from my old bios.
    Any help would be appreciated.
  • cacla
    • Apr 2015
    • 442
    Re: Gl502vs-ds71
    Pls give me sn for your model i will find it in Asus system
    • niro750
      • Jul 2019
      • 5
      Re: Gl502vs-ds71
      Sent PM thanks
      • cacla
        • Apr 2015
        • 442
        Re: Gl502vs-ds71
        Here it si. This is your bios by sn.
        • niro750
          • Jul 2019
          • 5
          Re: Gl502vs-ds71
          Thank you so much!
          Unfortunately I've just had to leave the country for work for a few weeks but I'll let you know how I get on with it.
          I really appreciate your help.
          • niro750
            • Jul 2019
            • 5
            Re: Gl502vs-ds71
            Thanks for the help, your bios started the fan which has not worked before but I have nothing else working so I think it will have to go for repairs.
            • EbrahimSiami
              Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
              by EbrahimSiami
              I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
              **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
              **What I have tried so far:**
              1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
              07-02-2025, 02:31 PM
            • hotcrossedbuns999
              M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
              by hotcrossedbuns999
              My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
              1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
              2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
              3. I could only locate two chips that look like bios chips. Could someone verify this
              01-03-2025, 12:32 PM
              by Vesko356
              08-11-2023, 03:27 AM
            • what_1282105
              Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
              by what_1282105
              Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
              02-14-2025, 07:27 PM
            • jbonavita
              by jbonavita
              Some issues
              Things I tried
              04-29-2025, 09:38 PM
