DELL latitude 7390 bios dump
  • Vesko356
    replied
    Re: DELL latitude 7390 bios dump
    Originally posted by centrino2
    Daz20 la-f311p
    rev:2.0 (a01)
    bios
    Read the rules before posting:
    Post full laptop model number, Service tag, original bios backup, issue description...
  • centrino2
    replied
    Daz20 la-f311p
    rev:2.0 (a01)
    bios
  • Djlol
    replied
    Originally posted by Vesko356
    Read post #47
    i was stupid i wrote oth lines at the same time.... thx Vesko!!!!!!
    stupid question donation is tracked by registered e-mail ? my paypall is different
  • Vesko356
    replied
    Originally posted by Djlol
    could anyone help me?
    i would need password to be removed.
    Read post #47
  • Djlol
    replied
  • darckreign1984
    replied
    Re: DELL latitude 7390 bios dump - dont show nothing, power respond.
    Originally posted by volinakis
    service tag 77QWNN2
    try this bios and feedback
    thanks
    - feedback
    *laptop does same things
    *coils have voltage when power boton its pressed. The coils for cpu vcc_core have voltage - power 0.85v buth only 3-4seconds (until power led goes off)
    Have a nice day
  • volinakis
    replied
    Originally posted by darckreign1984
    service tag 77qvvnn2 - hard to read
    express code15705933230
    can you fix this.
    thanks
    service tag 77QWNN2
  • darckreign1984
    replied
    I tried to follow the tutorial to clean my me bios laptop. However, it still behaves the same way as before. These are the results.
    i use ME_Analyzer_v1.148.4_r209 because MEAnalyzer-r332 - converted to exe give me error about line 25 in phyton.
    thanks.
    old bios
    ║ Family │ CSE ME ║
    ║ Version │ 11.8.92.4222 ║
    ║ Release │ Production ║
    ║ Type │ Extracted ║
    ║ SKU │ Corporate LP ║
    ║ Chipset │ SPT/KBP-LP C ║
    ║ TCB Security Version Number │ 3 ║
    ║ Version Control Number │ 331 ║
    ║ Production Ready │ Yes ║
    ║ Power Down Mitigation │ No ║
    ║ Lewisburg PCH Support │ No ║
    ║ OEM Configuration │ No ║
    ║ Date │ 2022-02-07 ║
    ║ File System State │ Initialized ║
    ║ Size │ 0x603000 ║
    ║ Flash Image Tool │ 11.6.0.3307 ║
    ║ Latest │ Yes
    new bios results
    ║ outimage.bin (1/1) ║
    ║ Family │ CSE ME ║
    ║ Version │ 11.8.93.4323 ║
    ║ Version Control Number │ 341 ║
    ║ Date │ 2022-06-29 ║
    ║ File System State │ Configured ║
    ║ Size │ 0x603000 ║
    ║ Flash Image Tool │ 11.8.50.3460 ║
    ║ Latest │ Yes ║
  • darckreign1984
    replied
    ALL you know is to ask for help, you NEVER helped others! In 12 years on this forum you should have learned how to perform a clean ME. Badcaps veterans explained very well how to do it.
    thanks
    *my account its old, buth i did not was active on this site.
    *and even the older member of this forum, when they help me, they not succeed in the first attept.
    thanks for remind me thr help problem (*i helped me and other with a small donation in the past).
    Have a nice day
  • volinakis
    replied
    update
    - tested other bios.
    -when i press power - keyboard light up
    - fan its spinin some second then turn off, if i pressit again, do same things.
    -if i remove ram, diagnostic led blink white and yellow.
    caps led dont change if i press it
  • darckreign1984
    replied
    update
    Last edited by darckreign1984; 07-28-2023, 07:39 AM. Reason: when power its pressed - usb its active some seconds then turn off (i have a usb memmory with a white led)
  • darckreign1984
    replied
    To "fix" what?! Add issue description.
    *when i press power - power led light up, nothing more.
    no display, no fan that spin, so the laptop respond only when i press power.
  • Vesko356
    replied
    any chance?
    thanks
  • darckreign1984
    replied
    can you fix this.
    thanks
    any chance?
    thanks
  • darckreign1984
    replied
    can you fix this.
    thanks
  • bitmosco1
    replied
    i have dell e7390
    daz20 la-f312p rev3.0 bios bin, after i clear computrace, model change to 7290, pls any help i appriciate thanks
    below is my orginal file
    Service Tag: 6F4HL13
  • gotowiec27
    replied
    I have a Latitude 7390 which does not POST. I believe that it may be an BIOS issue.
    Could someone please check the attached file and let me know if it's corrupted?
    DAZ20 LA-F312P Rev:2.0
    Service Tag: H6V95S2
    Thanks in advance!
  • Vesko356
    replied
    Originally posted by cris_carriaga
    dell latitude 7390 DAZ20 LA-F312p Rev : 2.0
    PLEASE REMOVE PASSWORD
    https://www.badcaps.net/forum/showth...86#post1241586
  • cris_carriaga
    replied
  • Vesko356
    replied
    Originally posted by DZ-Developer
    Dell Latitude 7390
    Reg Model: P28S
    Reg Type: P28S002
    System Number: 909CQQ2-E7AB
    *Service Tag SN: 033759
    Motherboard: DAZ20 LA-F312P Rev: 1.0 (A00)
    *Issue description:
    i need Clean up Password Bios
    Many thanks in advance
    *Original dump
    This is the second time today I am making a remark for you to read the rules!
    BIOS guides, methods, resources and tools
    Password removal by laptop brand
    3.4. Dell
    Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
    See: https://beta.bios-pw.org/ .
    Note: The 6FF1 suffix has a bug,use your service tag with the BF97 suffix instead,Example: 1234ABC-BF97
    There is no publicly available 8FC8 generator available at the moment.
    The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
  • gizaha
    by gizaha
    02-13-2024, 07:18 AM
    DELL Latitude 7390 Notebook 7000 Specification for Upgrade or Repair
    This specification for the DELL Latitude 7390 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7390 boardview and 7390 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7390...
    09-06-2024, 12:20 PM
    DELL Latitude 7390 Hybrid (2-in-1) 7000 Specification for Upgrade or Repair
    This specification for the DELL Latitude 7390 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7390 boardview and 7390 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
    09-06-2024, 11:14 AM
