DELL latitude 7390 bios dump
    Re: DELL latitude 7390 bios dump
    Originally posted by Francel View Post
    please Clean ME for may bios 7390, slow to open thanks
    Here's your Clean BIOS, try it.
    all donations are welcome,
      Hi new here I have a dell latitude 7290 with admin password but password is unknown any help (Service Tag 2DV3HR2-E7A8 )
        BIOS guides, methods, resources and tools
        Password removal by laptop brand
        Become a Badcaps supporter
        Thanks to all supporters.​
          Originally posted by imranromi View Post
          Try this and post results.
          DAZ20 LA-F311P rev 2.0 a01 i5-8th fen bios please
            Read the rules before posting:
            Add:
            • Service Tag.
            • Original dump.
            • Issue description.
              Dell Latitude 7390
              Reg Model: P28S
              Reg Type: P28S002
              System Number: 909CQQ2-E7AB
              *Service Tag SN: 033759
              Motherboard: DAZ20 LA-F312P Rev: 1.0 (A00)
              *Issue description:
              i need Clean up Password Bios
              Many thanks in advance
              *Original dump
              Unlock Done
              see the donate button below, at the bottom of the page, or
              >>>>> click on this link to donate via PayPal. <<<<<
              Doctrina est fructus dulcis, radicis amarae
                Originally posted by DZ-Developer View Post
                Dell Latitude 7390
                Reg Model: P28S
                Reg Type: P28S002
                *Issue description:
                *Original dump
                This is the second time today I am making a remark for you to read the rules!
                3.4. Dell
                Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
                See: https://beta.bios-pw.org/ .
                Note: The 6FF1 suffix has a bug,use your service tag with the BF97 suffix instead,Example: 1234ABC-BF97
                There is no publicly available 8FC8 generator available at the moment.
                The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
                  dell latitude 7390 DAZ20 LA-F312p Rev : 2.0
                  PLEASE REMOVE PASSWORD
                    https://www.badcaps.net/forum/showth...86#post1241586
                      I have a Latitude 7390 which does not POST. I believe that it may be an BIOS issue.
                      Could someone please check the attached file and let me know if it's corrupted?
                      DAZ20 LA-F312P Rev:2.0
                      Service Tag: H6V95S2
                      Thanks in advance!
                        i have dell e7390
                        daz20 la-f312p rev3.0 bios bin, after i clear computrace, model change to 7290, pls any help i appriciate thanks
                        below is my orginal file
                        Service Tag: 6F4HL13
                          Re: DELL latitude 7390 bios dump - dont show nothing, power respond.
                          service tag 77qvvnn2 - hard to read
                          express code15705933230
                          can you fix this.
                          thanks
                            can you fix this.
                            thanks
                            any chance?
                            thanks
                              any chance?
                              thanks
                              To "fix" what?! Add issue description.
                                *when i press power - power led light up, nothing more.
                                no display, no fan that spin, so the laptop respond only when i press power.
                                  update
                                  - tested other bios.
                                  -when i press power - keyboard light up
                                  - fan its spinin some second then turn off, if i pressit again, do same things.
                                  -if i remove ram, diagnostic led blink white and yellow.
                                  caps led dont change if i press it
                                  Last edited by darckreign1984; 07-28-2023, 07:39 AM. Reason: when power its pressed - usb its active some seconds then turn off (i have a usb memmory with a white led)
                                    update
                                    ALL you know is to ask for help, you NEVER helped others! In 12 years on this forum you should have learned how to perform a clean ME. Badcaps veterans explained very well how to do it.
                                      thanks
                                      *my account its old, buth i did not was active on this site.
                                      *and even the older member of this forum, when they help me, they not succeed in the first attept.
                                      thanks for remind me thr help problem (*i helped me and other with a small donation in the past).
                                      Have a nice day
                                        I tried to follow the tutorial to clean my me bios laptop. However, it still behaves the same way as before. These are the results.
                                        i use ME_Analyzer_v1.148.4_r209 because MEAnalyzer-r332 - converted to exe give me error about line 25 in phyton.
                                        thanks.
                                        old bios
                                        ║ Family │ CSE ME ║
                                        ║ Version │ 11.8.92.4222 ║
                                        ║ Release │ Production ║
                                        ║ Type │ Extracted ║
                                        ║ SKU │ Corporate LP ║
                                        ║ Chipset │ SPT/KBP-LP C ║
                                        ║ TCB Security Version Number │ 3 ║
                                        ║ Version Control Number │ 331 ║
                                        ║ Production Ready │ Yes ║
                                        ║ Power Down Mitigation │ No ║
                                        ║ Lewisburg PCH Support │ No ║
                                        ║ OEM Configuration │ No ║
                                        ║ Date │ 2022-02-07 ║
                                        ║ File System State │ Initialized ║
                                        ║ Size │ 0x603000 ║
                                        ║ Flash Image Tool │ 11.6.0.3307 ║
                                        ║ Latest │ Yes
                                        new bios results
                                        ║ outimage.bin (1/1) ║
                                        ║ Family │ CSE ME ║
                                        ║ Version │ 11.8.93.4323 ║
                                        ║ Version Control Number │ 341 ║
                                        ║ Date │ 2022-06-29 ║
                                        ║ File System State │ Configured ║
                                        ║ Size │ 0x603000 ║
                                        ║ Flash Image Tool │ 11.8.50.3460 ║
                                        ║ Latest │ Yes ║
                                          can you fix this.
                                          thanks
                                          service tag 77QWNN2
                                          try this bios and feedback
