Acer es1-431-p9j5
  • String2016
    • Nov 2015
    • 2242
    • philippines
    Acer es1-431-p9j5
    Hi Everyone!anyone have a working bios dump file for this model Please I need it urgent. Thank you in advance
  • String2016
    • Nov 2015
    • 2242
    • philippines
    Re: Acer es1-431-p9j5
    Anyone please have a working bios dump file
    • String2016
      • Nov 2015
      • 2242
      • philippines
      Please I need a working bios dump file for this model Sir ridamouh159 please do you have a working bios for this. thanks in advance
      • meritosari
        • Oct 2010
        • 774
        • Indonesia
        from official:
        • String2016
          • Nov 2015
          • 2242
          • philippines
          Thanks Ill try this
          • String2016
            • Nov 2015
            • 2242
            • philippines
            thanks bios is working with adapter 1.8v but the problem now there is no back-light on the screen
            • meritosari
              • Oct 2010
              • 774
              • Indonesia
              - Try re-seat Flex cable
              - if didn't work, measure +LCDVCC voltage (pin 35,36 on CN8)
              - You could also measure on G5243AT11U chips (U6) at pin 1 the voltage should be 3.3v
              - If no voltage on these points, check input voltage on U6 and the enable pin should be 3.3v
              - If the input is present, but have no output, then measure resistance on pin 1 VS GND. Do this to check if this point has shorted. before you do it, you must be disconnect from adapter or battery
              • String2016
                • Nov 2015
                • 2242
                • philippines
                Thanks for the information I already fix it i replace the lcd now the laptop sreen is working.thanls you for the response
                • salawayon
                  • Nov 2012
                  • 578
                  • philippines
                  the posted bios file is working but it doesn't have SN and system model, etc... is there any way i could edit the bios?
                  thanks...
                  • salawayon
                    • Nov 2012
                    • 578
                    • philippines
                    anyone could share another bios dump?
                    thanks..
                    • Citymin
                      by Citymin
                      S/N : 5RNK9FFT70...
                      08-05-2025, 05:12 AM
                    • bondminer009
                      Need Bios for Latitude 7650 (No Original / dump bios file)
                      by bondminer009
                      Good Evening,
                      Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
                      Thank You
                      Salam,
                      Three
                      11-12-2024, 07:48 AM
                    • picouser
                      Looking for HP Envy Laptop 17-cw1003ca (A00XQUA) BIOS dump file
                      by picouser
                      Power off when the laptop is doing a BIOS update. The file seems corrupted, or the DMI data was written in the wrong place. Could someone help me with it? I uploaded the backup file from the BIOS chip and the generic file extracted from the HP website. Thanks!...
                      11-24-2025, 10:31 PM
                    • EbrahimSiami
                      Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                      by EbrahimSiami
                      I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                      **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                      **What I have tried so far:**
                      1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                      07-02-2025, 02:31 PM
                    • cr4zychriss
                      by cr4zychriss
                      • Rebrand: PC Specialist
                      11-14-2025, 04:04 PM
