Hi Everyone!anyone have a working bios dump file for this model Please I need it urgent. Thank you in advance
Acer es1-431-p9j5
Tags: None
Re: Acer es1-431-p9j5
Please I need a working bios dump file for this model Sir ridamouh159 please do you have a working bios for this. thanks in advanceLast edited by String2016; 10-03-2016, 05:19 AM.Comment
from official:Attached Filesif you find these attachements useful please consider making a small donation to the site
thanks bios is working with adapter 1.8v but the problem now there is no back-light on the screenComment
- Try re-seat Flex cable
- if didn't work, measure +LCDVCC voltage (pin 35,36 on CN8)
- You could also measure on G5243AT11U chips (U6) at pin 1 the voltage should be 3.3v
- If no voltage on these points, check input voltage on U6 and the enable pin should be 3.3v
- If the input is present, but have no output, then measure resistance on pin 1 VS GND. Do this to check if this point has shorted. before you do it, you must be disconnect from adapter or batteryLast edited by meritosari; 10-04-2016, 06:14 PM.Comment
Thanks for the information I already fix it i replace the lcd now the laptop sreen is working.thanls you for the responseComment
by CityminHi all,
S/N : 5RNK9FFT70...-
Channel: BIOS Requests ONLY!
by bondminer009Good Evening,
Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
Thank You
Salam,
Three-
by picouserPower off when the laptop is doing a BIOS update. The file seems corrupted, or the DMI data was written in the wrong place. Could someone help me with it? I uploaded the backup file from the BIOS chip and the generic file extracted from the HP website. Thanks!...
by EbrahimSiamiHello everyone,
I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
**Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
**What I have tried so far:**
1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...-
07-02-2025, 02:31 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
- Loading...
