dell latitude e7470
    Re: Reflashing Dell E7470 AAZ60 LA-C461P Rev1.0(A00)
    Originally posted by Vesko356 View Post
    Here you are, your original dump with with 1.05.03 version bios update, same as in your corrupted dump, try it and come back with some feedback. If the problem persist, I'll clean the ME firmware additionally.
    Edit: Again, we've replied almost at the same time with Hardware1, I leave the dump I prepared, it is better to try it first, because it is with your factory ME firmware, and for me it is better to stay with it, but if as I said the problem persist, try the Hardware1's one - it has clean ME firmware.
    Thanks for your prompt help. Unfortunately, got no display though all voltages are ok. CPU voltages appear for seconds and then laptop is off.
      You are out of luck, usually the bios region gets corrupted, with the ME firmware it happens much less often, it would be good to stay with the factory one, but what can we do. So we go to option two as a way out. Go ahead.
      Become a Badcaps supporter
      Thanks to all supporters.​
        Have you tried the file in Post #39 as well?
        all donations are welcome,
          Originally posted by hardware1 View Post
          Here's your New BIOS, try it and let me know.
          Service Tag: HYJFKC2.
          First, thanks for your submission. Tried dump, but unfortunately no display.
          Is there any way to fix the attached working dump with no wifi detection ?
            Try this one and see, it has the same version as the working file with WIFI issue.
              Unfortunately, this version gave no ram voltage, so no display.
                Try the dump I've posted for another member- it's unlocked, ME cleaned and confirmed working.
                https://www.badcaps.net/forum/showpo...6&postcount=65
                  First thank you for your continuous help. Unfortunately got no display though all voltages including CPU voltages are ok for seconds then laptop shuts down.
                    Re: dell latitude e7470
                    plss clear me
                      Originally posted by anna1203 View Post
                      plss clear me
                      Try this file ...
                      Good luck ...
                        tnx i try
                        Originally posted by Markus1741 View Post
                        Try this file ...
                        Good luck ...
                        no display,,,,but thanks sir
                        [Mod. Edit-Vesko356] Use if you want to add something instead of posting new reply!
                          Dell E7470
                          Hello Guys
                          i have a dell E7470 has 2 issues not fan spining and not display
                          please can you Clean the bios or Re create the bios
                          Dell E7470
                          Service : JBC5TC2
                            i have changed ram of all frequencies but i have failed to over come the error code of 2amber 3 white for dell e7470. Any one can help me
                              thanks
                              Mohammed Mohan
                                Dell Latitude E7470, clean BIOS
                                Hi, i need a clean BIOS Dump. Thanks :-)
                                Model: Dell Latitude E7470
                                Board: AAZ60 LA-C461P Rev:1.0
                                  Re: Dell Latitude E7470, clean BIOS
                                  Try dudochnicht ....
                                    Thanks, this works for me :-)
                                      Hello - I have Dell e7470 that turns on with no display and shuts off after 30 seconds. I have tried numerous bios in this thread with different results but no display. I wonder if some could take a look at this bios? Service tag is 2PPDVD2. Thanks in advance.
                                        Your backup is messy, and we can't repair it. I think you are using a clip to read the BIOS chip.
                                          Thank you for the quick response. I was using a clip with battery and power disconnected. I will try again after removing the chip.
