ASUS X55A - restore serial numbers
  • io00
    • May 2019
    • 10
    • Italy
    I have an ASUS X55A that suffered a bios corruption when i manually changed a bios parameter (enable-disable internal pointing device) and then prompted it to "save and exit".
    I've bought a ch341a programmer, retrieved the dump of the corrupted bios, erased the chip and flashed a working .rom (version v413).
    The laptop booted and i was able to update the bios to the last available version (v417), which i dumped once again.
    I now have these files:
    1. original corrupted bios (v417, i believe)
    2. working bios v413
    3. working bios v417
    Using AMIBCP, I see that file 2 and 3 have generic serial numbers, and i guess they also have generic mac address etc. File 1 crashes AMIBCP. All the files can be open with UEFITools but i can't understand a damn, i'm a newbie. The laptop didn't come with a windows license: i used one of my w7-w8 ones, that got later upgrade to w10.
    Now the questions are:
    a. Will the use of generic serials invalidate my license upgrade?
    b. Is it possible to copy serial numbers and other identification codes from file 1 to file 3?
    c. If yes, how can i do that?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: ASUS X55A - restore serial numbers
    there is windows product code in the original bios, search for it and replace data in new bios dump
    • io00
      • May 2019
      • 10
      • Italy
      Can you suggest a program to inspect the original corrupted bios? amibcp4.53 crashes when i try to open it (it doesn't crash with the other dumps, though)
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3627
        • slovakia
        hex editor or better filealyzer
        • jasko_jacker
          • Oct 2014
          • 1140
          • italy
          There are few information avalaible about this procedure.
          read #9
          https://winraid.level1techs.com/t/ho...ios-dump/32592
          If you have the old bios, I suggest to make a ME clean and try if it solve the problem.
          https://winraid.level1techs.com/t/gu...lization/31277
          • io00
            • May 2019
            • 10
            • Italy
            Thanks for the links. I've already read a lot on that site.
            Using the hex editor in notepad++ i was able to manually recover the block containing the serial number of the machine, along with other interesting strings (maybe UUID and MAC address?). I've already transferred them in the working .rom, and tomorrow morning I'm going to flash the chip once again. However, amibcp doesn't seem to pick the serial up on the modified rom...
            Ill' keep the thread updated if the solution is found
              • 21841
              The DMI area is 2FE50 - 301DF ,(UUID 301B8 - 301C7) Win key area is 33000 - 330FF
              As already suggested by @jasko_jacker its better to just try cleaning the ME area first,it saves a lot of time if its the only thing wrong with the bios,and keeps all the DMI info.
              • io00
                • May 2019
                • 10
                • Italy
                unfortunately, the flash image tool can't load the bricked bios due to corruption...so i cannot perform an ME clean as far as i know.
                However, the info you gave me on the DMI area is quite interesting: does it mean that copying the sectors from 2FE50 to 301DF (included) from the bricked bios to the functional one *might* give me a functioning bios with serials, mac and UUID? (as i already stated in the opening post, win key area is not of main interest)
                • io00
                  • May 2019
                  • 10
                  • Italy
                  Status update:
                  -found a region on the bricked bios with relevant serial numbers (it was different from that suggested by SMDFlea, however)
                  -pasted it on the generic bios
                  - machine serial number and uuid are now showing up in windows
                  The only thing missing in windows is the lan mac address. i have found two strings in the bricked bios with the mac address and i have copy-pasted them, but apparently they are not enough
                  • io00
                    • May 2019
                    • 10
                    • Italy
                    ok i think i got this. the offset of the mac address should be 1000h. I don't know why but in the bricked dump it was 88 88 88 88 87 88, as in the generic .rom. I forced it to my mac (hex, retrieved from a label inside the chassis) and flashed. Now it is showing properly in windows.
                    At this stage:
                    - serial number -> ok!
                    - uuid -> ok!? (it looks fancy, 00000011-0000-0000-0000-MacAddress, but i have seen other asus laptop with similar uuid on the internet, so it might be)
                    - mac address -> ok!
                    i'm sure there are other sn that should be carried over (like chassis, motherboard etc) and i might have already copied them swapping blocks from a rom to another.
                    However, having sorted out the three mentioned above, am i enough "good to go" or should i do something else?
                    Thanks!
                    edit: the mac address on the label is in the form "aabbccddeeff gghh". should i also force the 4 digits following the main 12 in the bios?
                    • Bartoloni
                      • Jul 2018
                      • 140
                      • Italy
                      Just made a tool to retrieve the Windows serial key from dumps...
                      http://www.wcn.it/BIOSdump2license.zip
                      and this is a video about that: https://www.youtube.com/watch?v=OpMWw4WFhaU
                      • piernov
                        • Jan 2016
                        • 4439
                        • France
                        Please don't hijack threads, and MEInject can already do it. (even though it's not a great tool for ME region cleaning)
                        • tomy78
                          Newbie
                          • Jul 2019
                          • 42
                          • Indonesia
                          amazing tool. how about write SN to bios dump?
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Use HxD tool to insert DMI info.
                            • shamaltech
                              • May 2023
                              • 109
                              • Sri Lanka
                              That's awesome & working 100000%
