Panasonic CF-54 Bios Password
    Re: Panasonic CF-54 Bios Password
    Hi! could someone remove pass?
    Thank you !
      Thank you !
      Try
      Become a Badcaps supporter
      Thanks to all supporters.​
        work, you are the best !!
          Hi! could someone remove pass please ? FZ-M1 MK2
            You are off-topic here, this thread is for Panasonic CF-54.
              Yep, off-topic and already asked for help in another thread ....
              https://www.badcaps.net/forum/showthread.php?p=1061744
                Hi guys
                Could someone look on this bios ?
                It's locked, I read it by neoprogrammer.
                Thanks for any advice, best regards guys
                  Originally posted by ibmlisek View Post
                  Hi guys
                  Unlocked:
                    Hi!
                    Can i get help to remove bios password from CF-54 mk2?
                    Thank you!
                      Originally posted by Jan0132 View Post
                      Hi!
                      Thank you!
                      Unlocked:
                        Unlocked:
                        Working great!
                        Thank you very much!
                          Working great!
                          You're welcome.
                          Congratulations
                            Could please you help me remove password?
                              Off-topic! This thread is for Panasonic CF-54.
                                Sorry ! I am wrong
                                  Clean Bios?
                                  Hi guys, i need help resseting password bios. Best Regards
                                    Re: Clean Bios?
                                    try..
                                      Re: Surface 3 Clean Bios? (noob)
                                      Hi, Bud, thanks for helping, what i realy need is if you can find the password for my bios in bin file because i desoldered the chip to read it, but when i desoldered the chip, a piece of the contact circuit board broke off that makes contact with SI/SIO0, so i had to scrape the board resolder to make contact with ic chip pin number 5 (SI/SIO0), pc is working fine and i dont want to desolder the chip again to write to it again.
                                      Best Regards
                                        @Nesport
                                        Try to use a SOP8 clip to read/write to the chip, it may work, I’ve done it with a ToughBook to read/write bios chip, it worked for me without having to desolder chip, used an EZP2010 programmer.
                                          Originally posted by AAAC View Post
                                          @Nesport
                                          Try to use a SOP8 clip to read/write to the chip, it may work, I've done it with a ToughBook to read/write bios chip, it worked for me without having to desolder chip, used an EZP2010 programmer.
                                          Thanks for reply, i tried with the SOP8 clip but it does not hold on to the bios chip, it jumps out, maybe the clip is faulty, better buy a new one, i use GQ-4x programmer and never had any problems.
