need bios dump for hp 17 -e107
  • alas3376
    • Nov 2011
    • 382
    • BENIN
    hello,
    need bios dump for this hp DA0R76MB6D1 REV: D
    Thank
    • 21692
    Re: need bios dump for hp 17 -e107
    Post your bios backup .
    • alas3376
      • Nov 2011
      • 382
      • BENIN
      ok
      here it is
        • 21692
        Try this bios,extracted from the official HP bios update.If this bios doesn`t work your problem is somewhere else.
        • alas3376
          • Nov 2011
          • 382
          • BENIN
          OK thank, i'll try and let you know
          • crownmobile3
            • Feb 2017
            • 34
            • Saudi Arabia
            I tried this BIOS but same, I got 17-e130us with an AMD processor. the board number is da0r76mb6d1.
            • Habble7
              by Habble7
              Suspected Cause:
              Troubleshooting Attempts:
              05-22-2025, 07:28 AM
            • haitham sharabati
              by haitham sharabati
              Hello engineers šŸ˜€,
              I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.šŸ˜
              šŸ”§ Device Info:
              - Model: HP 15-da2007ne
              - Product Number: 8XF55EA#ABV
              - Serial Number: CND0338P0D
              - CPU: Intel Celeron N4000
              šŸ’€ Problem:šŸ˜…
              - Device shows ā€œAdministrator Passwordā€...
              08-07-2025, 04:54 AM
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
            • DynaxSC
              by DynaxSC
              11-17-2023, 10:56 AM
            • greelidd
              K6604J Vivobook RTX 4070 BIOS Dump Request
              by greelidd
              Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
              Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
              09-01-2025, 06:14 PM
