Panasonic CF-C1 MK1, please for working bios dump. Our bios is corrupt, and we will try flash a working bios bin file. Thanks a lot.
Re: Panasonic CF-C1 MK1, please for working bios dump
you can use search button.Last edited by bachir2004; 02-27-2019, 06:44 AM.
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by sedat88Hi,
I'm looking for Panasonic CF-54 bios dump.
Flash memory with bios is damaged and is not possible to recover any information from it.
Model Name - CF-54DY024NG
S/N: 6DTSA61473
Thank You...-
by CityminHi all,
S/N : 5RNK9FFT70...-
- Loading...
