wana remove password and need to clear me region also
a1502 efi lock
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by trepachkaHello, I have this HP Pavilion X360 14-ek0033dx laptop with bios lock. I am unable to change drive boot order because of it.
Please, help me remove it.
Model: 14-ek0033dx
S/N# 8CG2272ZB5
ProdID 67W83UA#ABA
Original BIOS file is attached. Thank you....-
Channel: BIOS Requests ONLY!
by mactouchPlz anybody remove this bios password
THINKCENTRE M920Z
sn. PC0YCEJK...-
by airbladePlease remove swat lock
HP EliteDesk 800 G4 35W
Serial 8CC912276T...-
- Loading...
