BIOS bin file for Dell latitude 7480
  • maikbi2pro
    • Sep 2021
    • 17
    • Россия
    #81
    Re: BIOS bin file for Dell latitude 7480
    Originally posted by Vesko356
    It means you're wasting the time of the person helping you. You had to say at the beginning what the situation is. Just because you've found a dump from somewhere, and you think it's going to solve your problem, doesn't mean it's going to happen. And because you are lucky to be a Russian - a nation that I like, I will help you. But take a note for the next time. The dump that was pointed out to you has already been unlocked, all you have to do is clean it. With the tools you have already been shown. If you can't handle it, say so, we will help you further. And please, put a capital letter in the town where you living, because it is also the name of the one of greatest writers of all time and the town was named in his honor - Anton Chekhov, it is somehow irritating, at least for me.
    Thank you so much for your support. I have several other similar devices with similar problems. If I need any help, I will definitely contact you.
    • maikbi2pro
      • Sep 2021
      • 17
      • Россия
      #82
      Greetings to all. There is another one of the same board, came without initialization, tried to clean the ME area, the result after cleaning the laptop starts, current consumption +- 0,500-0,600 mA, the indicator flashes orange twice and white once, the consumption drops to 0.300 mA and turns off. I threw out the chip from another board (it has a short circuit), a long initialization occurs, a picture appears, but it does not enter the Bios and turns off after a while. I tried to pour the old bios into the second chip, and with a clean ME area, the result is the same, there is no initialization, and the indicator is flashing. Can you tell me what I'm doing wrong, I'm attaching all the files.
      • Ferimonka
        • Nov 2019
        • 40
        #83
        Hi there. My laptop is password locked and need a clean bios file. Would you be able to help?
        Service tag is GLQQBK3.
        Dump is attached.
        Many thanks.
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          #84
          Dump is attached.
          Many thanks.
          First of all read forum rules, secondly why you asking 7420 questions in a 7480 thread? Third, the dump you've uploaded is not OK, and fourth, the laptop is under warranty until 2024, so just call Dell support for assistance.
          Become a Badcaps supporter
          Thanks to all supporters.
          • bepom
            • May 2019
            • 8
            • bosna i hercegovina
            #85
            Is it possible to unlock it, I can enter the bios, but my options are all locked so that I can adjust it in the bios, so if it can be unlocked
            • satishkumar
              • Sep 2015
              • 164
              • India
              #86
              Originally posted by bepom
              is it possible to unlock it, i can enter the bios, but my options are all locked so that i can adjust it in the bios, so if it can be unlocked
              • bepom
                • May 2019
                • 8
                #87
                the bios you sent me is without the ser tag and other data
                • Ankitk
                  • Jan 2021
                  • 8
                  • India
                  #88
                  La-e121p me cleen bios
                  • satishkumar
                    • Sep 2015
                    • 164
                    • India
                    #89
                    enter the details manually
                    • zzomm
                      • Mar 2012
                      • 21
                      • Estonia
                      #90
                      Hey, can somebody help me ? Turning laptop on, tpm device is not detected alert occuring.
                      I allready tested and flashed from bios from 1.25 to oldest version 1.4.6 - still no TPM device.
                      Even new version 1.26.0 not helped.
                      Here is Bios image and TAG: J7BG2G2
                      https://drive.google.com/file/d/14dL...ew?usp=sharing
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11870
                        #91
                        Try this file, next time post your file directly to the forum without using external links (use winrar or 7zip compress the file before posting).
                        • zzomm
                          • Mar 2012
                          • 21
                          • Estonia
                          #92
                          Tnx, tested your bios, but not worked. After startup Bios itself recoverd back to previous version, still also no TPM.
                          Also in BIOS Restore defaults menu has only one option- Bios default, no other options.
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11870
                            #93
                            Maybe your tpm module is dead
                            • zzomm
                              • Mar 2012
                              • 21
                              • Estonia
                              #94
                              It happend after BIOS update, from ver 1.12-1.18 to version 1.25. Maybe it broke TPM firmware, witch was to old. Need to find TPM on motheboard.
                              • zzomm
                                • Mar 2012
                                • 21
                                • Estonia
                                #95
                                Hi, I also checked the computer conf that came from the factory and it has not been in the TPM since the beginning. But why is there still a TPM error in the computer startup?
                                • ludo28
                                  • Aug 2022
                                  • 37
                                  • france
                                  #96
                                  Hello
                                  Looking for help to remove the bios password for:
                                  Latitude 7480
                                  System number: 77P3VN2-0001
                                  CAZ20 LA-E131P
                                  Rev 2.0 ( A01 )
                                  2017 -10 -13
                                  Thank you.
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11870
                                    #97
                                    Originally posted by ludo28
                                    Hello
                                    Latitude 7480
                                    CAZ20 LA-E131P
                                    Rev 2.0 ( A01 )
                                    2017 -10 -13
                                    Thank you.
                                    Try
                                    • ludo28
                                      • Aug 2022
                                      • 37
                                      • france
                                      #98
                                      Do you have to delete the old file before uploading the new one?
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 11870
                                        #99
                                        Yes.
                                        • ludo28
                                          • Aug 2022
                                          • 37
                                          • france
                                          #100
                                          Originally posted by hoaca388
                                          Yes.
                                          ok i test that
                                            DELL Latitude 7480 Notebook 7000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 7480 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7480 boardview and 7480 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7480...
                                            09-06-2024, 08:01 AM
