Acer E5-553 DA0ZABMB6E0-REV.E
  • teqcom
    • Nov 2015
    • 311
    • malasyia
    needed bios Acer E5-553 DA0ZABMB6E0-REV.E
    attach olrdy ori backup
    • 20311
    Re: Acer E5-553 DA0ZABMB6E0-REV.E
    Try this one ,and report .
    • teqcom
      • Nov 2015
      • 311
      • malasyia
      thx working fine
      • Bond0007
        • Mar 2020
        • INDIA
        Can you tell which bios chip should be used in place of the original
        GD25LQ64CBIC chip?
        Can I use any GD25LQ64Cxxx SERIES chip or the chip is system specific?
        Thank You in advance.
        • kayitsiz
          • May 2017
          • 18
          • istanbul
          thanks
          • ElecPCTech
            • Mar 2016
            • 9
            • Portugal
            GD25LQ64CBIC chip?
            Greetings,
            Yes you can replace the BIOS IC with any 8MB (64Mbit) @ 1.8V, but you will need a special adapter for the SPIROM programmer to do it.
            • 2mjunior
              • Sep 2021
              • 3
              • salvador
              thanks
              • yasser toaamh
                • Jul 2019
                • 26
                • konya
                da0zabmb6e0 rev e boardview plese
                  • 20311
                  Laptop schematic requests go here -> https://www.badcaps.net/forum/forumdisplay.php?f=41 .Start a new thread there.
                  • cbk
                    • Mar 2020
                    • Ghana
                    please i need acer e5-553-t7zr(zab da0zabmb6e0 rev e) bios bin AMD A10 7th gen
                    • peste
                      • Dec 2016
                      • 12254
                      • ROMANIA
                      post the original bios even if it is corrupted
                      • lord
                        • May 2011
                        • 319
                        • Croatia
                        I tried on Acer e5-553G-F33P N16Q3 board DA0ZABMB6E0 Rev E
                        MAIN BIOS: turns on but no picture, with old BIOS works good but shut's down randomly
                        EC: no power on
                        • lord
                          • May 2011
                          • 319
                          • Croatia
                          EC: no power on
                          It wasn't the BIOS, chips that i was using were not compatible
                          • testinglaptops
                            • Oct 2022
                            • 72
                            • United Arab Emirates
                            THANK YOU, WORKING 100%
                            • NecroFlex
                              Acer Aspire 1 A115-32-C28P BIOS needed please
                              by NecroFlex
                              I have an Acer Aspire 1 A115-32-C28P laptop that tries to boot for 5s and then shuts off. (Mobo name GH5JJ/GH7JJ LA-K701P Rev C1)
                              I suspect the BIOS might be the issue, but ACER website doesn't come with a BIN file, only an EXE that doesn't contain the full image. I tried searching for a BIOS bin but no luck.
                              I have attached both the bios i read from the chip and the latest ACER bios. Thanks for any help in advance!...
                              02-11-2025, 08:51 AM
                            • Wg188
                              ACER Veriton Z4660G AIO bios help
                              by Wg188
                              I have an Acer veriton Z4660G all in one pc,
                              Model: Z4660G-I5850H1 (VZ4660G_W)
                              Need bios dump and schematic would save my life !
                              to make a long story short I bought this all in one used
                              with a broken lcd, with the objective of making a custom desktop out of it
                              ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
                              06-17-2023, 02:20 PM
                            • cekcons
                              g1 assassin Rev 1 bios dump - main and backup needed
                              by cekcons
                              main and backup ic dead so i cant post corrupt bios cause its 01 all over.
                              thanks
                              01-23-2024, 03:26 AM
                            • kotel studios
                              BIOS needed for acer v65xa (NOT v65x!)
                              by kotel studios
                              As the tile says I need an bios dump for the acer v65xa. My eeprom died on it and I can't fully test the board. With the bios from v65x the board hangs right before initializing video (I think), and the SIO gets hot on the circle marking orientation. So idk if it is the SIO or eeprom.
                              02-24-2025, 12:33 AM
                            • peterhui
                              BIOS PASSWORD UNLOCK NEEDED (ACER TRAVELMATE P645-S)
                              by peterhui
                              Model : TMP645-S-504E
                              S/N: NXVAFEG0085490148C3400
                              like to unlock the bios password:
                              tried biosbugs keygen not working.
                              tried bios-pw unlock key still no luck.
                              Here is the two bios file : (Bios + EC)
                              Will definitely summit donation after that issue solve.
                              Thanks for your help and support
                              I really appreciated....
                              08-12-2024, 09:40 AM
