Acer aspire E1-521 24PQ bios needed
  • Romulo
    • Nov 2016
    • 484
    • Philippines
    I need a working bios on this model Acer aspire E1-521 24PQ
    board id:
    Z5WAE LA-B232P
    REV:1.0
    2014 -03 -26
    its amd processor need help please
  • Romulo
    • Nov 2016
    • 484
    • Philippines
    Re: Acer aspire E1-521 24PQ bios needed
    need help please
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      main & EC extracted from acer official update. Good luck
      • Romulo
        • Nov 2016
        • 484
        • Philippines
        thank you ill try this
        • Romulo
          • Nov 2016
          • 484
          • Philippines
          your bios is only 4mb my original is 8mb i have attached the original dump. can someone fix this please
          • Romulo
            • Nov 2016
            • 484
            • Philippines
            need help please can someone fix my original dump
            • rocklover
              • Oct 2012
              • 4
              • iran
              hi.this is 8mb bios.
              • Romulo
                • Nov 2016
                • 484
                • Philippines
                • Romulo
                  • Nov 2016
                  • 484
                  • Philippines
                  thanks i flashed the bios but still the same issue turns on lights come fan is not spinning then lights goes off.I check voltages 19v ok 3.3v and 5v present on each coil and also 3.3v present on power button and bios chip.anyone can help me on this please
                  • rocklover
                    • Oct 2012
                    • 4
                    • iran
                    try this one.
                    • Romulo
                      • Nov 2016
                      • 484
                      • Philippines
                      thanks i flashed the same issue maybe EC kb9022 need to flash but i dont have a programmer for i/o chip. ill try to find first
                        • 20887
                        You meant a "E5-521" .Please try to avoid typo`s .Heres another bios to try, extracted from official acer update.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          What can one do if you type the model number wrong....
                          • knebebelmeyer
                            • Jul 2019
                            • germany
                            Hello there...
                            i have the same Laptop Z5WAE-La232p AMD A6 4Gb 1000HDD
                            Laptop power on and go in blackscreen mode..i saw this with a Torch.
                            with no ram the bios beep code comes. that is a good sign!
                            i use all mods with Bios file to Usb.....power on fn Esc....but nothing...
                            the laptop starts boot with any usb bootable device but no screen output.
                            i desolder the Bios chip and programm this with the correct bin file 8192kb from this forum, but nothing...even with this the beep codes dont come, if i put the rams of.
                            this is a bad sign.
                            i test the usb programmer ch314 with other chip...i do not write the orginal chip!
                            what can i do?? how i have to handle the e5-521 Bios and EC.zip??
                            Bios.bin and EC.bin how i have to use it??
                            i try it with usb drive with indicator light....but the light is on....all the time, no blinking that the drive read something...
                            anyone a solution?
                            • knebebelmeyer
                              • Jul 2019
                              • germany
                              I did it by myself....My fault was, i use a other 8mb64mbit Bios Chip from other Manufacture...Winbond...I guess it doesnt matter how chip u take cause the size match...
                              in this case: i desolder the chip from the brocken bricked Laptopmainboard and write with the file from here...
                              and tadaaaaa.....i have a picture!!
                              in my case it was a z5wae la232p and use the file :BIOS 8MB (Z5WAE LA-B232P REV 1.0)_E5-521-46QC.bin
                              • zurvanielle
                                • Feb 2017
                                • 137
                                • Philippines
                                @SMDFlea,... THANKS... IT WORKS...
                                • muks11
                                  • May 2020
                                  • United Kingdom
                                  @SMDFlea, thanks! This also worked for me to.
                                  • SimeonTempler
                                    • Apr 2018
                                    • Belize
                                    @SMDFlea: Thank you very much.
                                    • Slim_Boss
                                      • Mar 2021
                                      • 7
                                      • PORTUGAL
                                      Hi there,
                                      I have the same problem... my BIOS goes out and I came where and download the files. It was able to flash the bios with the 8MB file, but what do I do with the other file? It is really needed?
                                      After I flash the BIOS, the pc don't turn on... just with the batery... please help me...
                                      Slim_Boss
                                      Soldier Of Fortune
                                      • peste
                                        • Dec 2016
                                        • 12792
                                        • ROMANIA
                                        Originally posted by Slim_Boss
                                        Hi there,
                                        try the bios from post # 12 if you have E5-521.
                                        • EbrahimSiami
                                          Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                                          by EbrahimSiami
                                          I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                                          **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                                          **What I have tried so far:**
                                          1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                                          07-02-2025, 02:31 PM
                                          ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 02:30 PM
                                        • NecroFlex
                                          Acer Aspire 1 A115-32-C28P BIOS needed please
                                          by NecroFlex
                                          I have an Acer Aspire 1 A115-32-C28P laptop that tries to boot for 5s and then shuts off. (Mobo name GH5JJ/GH7JJ LA-K701P Rev C1)
                                          I suspect the BIOS might be the issue, but ACER website doesn't come with a BIN file, only an EXE that doesn't contain the full image. I tried searching for a BIOS bin but no luck.
                                          I have attached both the bios i read from the chip and the latest ACER bios. Thanks for any help in advance!...
                                          02-11-2025, 08:51 AM
                                          ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
